Will Water Levels Equalize in Two Connected Tanks Despite Pipe Friction?
Water levels in two connected tanks will equalize despite pipe friction, as the pressure difference drives the flow. The flow rate is initially high when the first tank fills, resulting in significant friction, but as the levels approach equilibrium, the flow rate decreases, reducing friction. Ultimately, the tanks will reach the same water level when the pressure from the liquid height in both tanks equalizes. This phenomenon is governed by the principles of fluid dynamics, specifically the relationship between pressure, flow rate, and friction.
  • Understanding of fluid dynamics principles
  • Knowledge of pressure differentials in fluid systems
  • Familiarity with flow rate and its relationship to friction
  • Basic concepts of hydraulic systems
  • Research the Darcy-Weisbach equation for calculating friction losses in pipes
  • Study the principles of hydrostatics and fluid equilibrium
  • Explore the effects of pipe diameter and length on flow rate and friction
  • Learn about the Bernoulli equation and its applications in fluid flow
Engineers, fluid mechanics students, and anyone involved in designing or analyzing hydraulic systems will benefit from this discussion.
Sameh soliman
TL;DR
I know that water losses pressure as it move throw a pipe due to friction but what is the effect in the following situation
I know that water losses pressure as it move throw a pipe due to friction.
Does that mean that if we have two elevated tanks separated by a great distance but connected throw a perfectly horizontal pipe ,and then we fill the first tank with water till it reaches a certain height, then the height of water in the 2nd tank will not reach the same height in the 1st tank because of pressure lose due to friction in the pipes ?
I am feeling that i am wrong , but i need an explanation
No, but with friction it will take longer than without.
The driving force for the flow is the pressure difference and the opposing force is the friction, which is approximately proportional to the flow squared. So as long as there is a level difference there will be flow to equalize it.
The friction in the horizontal pipe is a function of flow. At first, the flow in the pipe is high as the second tank tries to keep up with the filling of the first tank; friction will be high. The flow is a function of the differential pressure at each of the pipe ends caused by the difference in liquid height. As the levels start to reach equilibrium the flow rate in the pipe reduces...until it finally becomes only a small trickle. At this point, the friction in the pipe (resisting the flow), is approaching zero due to the reduced flow.
The two tanks will reach the same level when the pressure (caused by the height of the liquid) in the two tanks becomes equal.
  • · Replies 26 ·
  • · Replies 17 ·
