Mystery of a Tensioned Rope Split in Two Places
The discussion revolves around the mechanical failure of a tensioned nylon rope in an Ergotron Workfit station, specifically focusing on how one rope can break in two places simultaneously. Participants explore the mechanics of the rope system, potential causes of failure, and methods for reassembly and repair.
  • Experimental/applied
  • One participant notes the difficulty in understanding how a single rope can snap in two places at once, suggesting that the spring's tension may have caused a secondary break after the first.
  • Another participant compares the mechanism to a garage door spring and pulley system, indicating that the tension dynamics may be similar.
  • There is speculation that the ropes may operate in parallel, with wear concentrated at specific points due to repeated adjustments of the workstation height.
  • Concerns are raised about the potential hazards of attempting repairs without understanding the tension and loading of the ropes.
  • One participant suggests that the nylon ropes may have been fatigued by the pulley system, proposing that a wire-rope surrounded by plastic could be a better alternative.
  • Discussion includes the possibility of using high modulus polyethylene (HMPE) instead of nylon for its strength and low stretch characteristics.
  • Participants express uncertainty about the exact configuration of the ropes and their connections, with some seeking clarification on how specific lines attach to the spindle and other components.
  • There are mentions of planned obsolescence and concerns about the manufacturer's awareness of this failure mode.
Participants generally agree that the mechanics of the rope system are complex and that understanding the interactions between the ropes is crucial for repair. However, multiple competing views exist regarding the materials and configurations of the ropes, as well as the causes of failure, leaving the discussion unresolved.
Participants note the lack of detailed mechanical specifications from the manufacturer, which complicates the understanding of the system. There are also references to potential hazards associated with the tensioned components, emphasizing the need for caution during repairs.
This discussion may be useful for individuals interested in mechanical engineering, product repair, or those specifically dealing with Ergotron Workfit stations and similar tensioned systems.
gary808
TL;DR
A Stand/Sit workstation is tensioned by internal nylon ropes. When one breaks, the internal spring snaps back into a rest state. But how did one rope break in two places simultaneously?
I'm attempting to repair my Ergotron Workfit station. After taking apart, I discovered the problem. A single nylon rope split, releasing the spring's tension. Because it is past the warranty, the manufacturer is recommending I toss the whole assembly and buy a new $650 one. Doesn't seem the sensible thing to do over a $1 rope.
You can see from these photos, there are a total of 3 nylon ropes; one from the spring's base, one through the lower center spindle, and one longer rope just behind and to the right of the lower spindle. I'm sure that one extends up through the wheel next to the spring.
I cannot find any mechanical specs on how these 3 ropes come together and I'm hoping someone here can illustrate so I can reassemble with the new 100lbs, nylon cord.
I just can't imagine how one rope can snap in two places simultaneously. Normally once one section breaks, it relieves all the tension in the remaining cord. There'd be no second break in the same rope.
I think when the first rope broke the spring put tension on the other one and it broke too.
The mechanism reminds me of a garage door spring and pulley setup where the spring counterbalances the door. This may be the case here too.
In the garage door case though usually its the spring that breaks over time and then you hear this explosive sound as it flails around breaking car windows (if there's no cable running through it) and mounting brackets.
For your mechanism it looks like the nylon rope is wrapped around the pulleys and then each end is attached to the spring.
NOTE: THE USER MANUAL SAYS THIS SECTION IS UNDER TENSION AND COULD BE HAZARDOUS.
That may be a good reason NOT to attempt to fix this without some detailed knowledge of how the mechanism works and how it is loaded and primed. I noticed in the manual there were ways to increase and decrease the tension so maybe that's how you install the rope and then increase the tension.
Agreed about lowering the tension. I'm certain that is at least part of the factor when it comes time to reload. I'm just stuck trying to wrap my head around how these ropes interact. The lower rope that broke in two parts, feeds through the center lowest spindle. Then each end of the loops connect to the spindle just behind it.
That still leaves the LONG rope you see extending out the bottom next to the broke ropes - & - the short rope connected to the hook on the spring. Each and every rope ends in a loop which connects to something.
My only guess is that both the short and LONG ropes connect to this lower broken one. That the LONG rope loops over the wheel next to the spring and back down to the base.
Is this LONG rope a reverse tension on the spring somehow?
gary808 said:
Summary: A Stand/Sit workstation is tensioned by internal nylon ropes. When one breaks, the internal spring snaps back into a rest state. But how did one rope break in two places simultaneously?
I don't have a specific answer, but here is a plausible lead-up to the problem.
That may be one continuous piece of rope but it looks like it is installed and operates as two ropes (or strands) in parallel.
For the four breaks to happen in pairs there must have been a concentration of wear at those points, likely due to the vertical position of of the work surface. For instance there were probably two preferred table heights in use.
While it is apart, look for and polish any rough spots that may contact the rope.
The manufacturers page you linked to in the OP has links to various documentation about half way down the page.
The "Recycling Guide" shows an exploded view for all parts EXCEPT the rope.
The link "CAD-2D & 3D DWG" has an Autocad file that may help, but I have nothing to read it with. There are probably free Autocad readers available but I don't have one, others here may have hints about availability.
Cheers,
Tom
Yeah. Mostly I'm scratching my head trying to figure out how the ropes load the spring so that the weight of the monitor zeros out. The manufacturer (out of good legal sense) have left that information out.
I think the key to understanding, is going to be how the LONGER rope goes over the wheel at the top of the spring. Where it runs and connects from there.
My experience with wire-ropes in motorcycles has been that they always fail by the area were cyclic bending happens, like next to a wrapping element that frequently rotates in both directions.
In your case, both nylon ropes seem to have been fatigued by the bottom pulley and many up and downs adjustments.
Perhaps a wire-rope surrended by plastic (like used in gym machines) could be a better option than original nylon.This may help you:
https://patentimages.storage.googleapis.com/3d/f3/0d/946b5923516afd/US8826831.pdf
  • Wow
Okay. This is a big help! Changes my thought on how they come together. I previously thought lines 3135 & 3161 looped onto line 3132. Clearly, not correct.
Now if only I could figure out where 3135 & 3161 actually attach to. 3135 does pass under the spindle (3130). Is it possible that 3161 somehow attaches to the spindle (3130)?
I am going to reach out to Tom.G's link for additional tips. Thank you everyone!
Don’t forget there is a pulley up by where the spring is attached to the frame, I suspect a rope must loop around it too.
That doesn't look like nylon to me, it looks like high modulus polyethylene (HMPE aka UHMWPE), trade names Dyneema, Spectra etc.) You can confirm this by heating with a flame: nylon will melt and shrink back on itself quickly and can be easily moulded when hot, dyneema is different (difficult to describe, you have to experience it really) and tends to just burn.
Also I would guess that HMPE is specified for this application beacuse it has a very low stretch: if you use nylon the table would bounce as you type. HMPE is also much stronger for a given diameter: a breaking strength of 100lb sounds inadequate for this application (the line in the picture looks about 5mm: this would have a breaking strength of about 2 tons).
To overcome the problem with wear you could use line with a braided polyester sheeth (I would not recommend aramid (Kevlar) or wire for this application as it seems to have some low radius bends).
@gary808 here we are almost a year later and I just had the same thing happen to mine. Were you able to figure this out?
To me, it feels like planned obsolescence is at play.
Either that or they did not realize about this failure mode. If that's the case (and I hope it is) the manufacturers should be taking notes to solve the issue.
I have a monitor stand by Ergotron and managed to look inside. It is much simpler that the full workstation though.
At the top of the column, there is a pulley with two different diameters.
The rope from the spring goes around the smaller diameter section, thru a slot and around the larger diameter section.
The rope then connects to the monitor mounting itself, the part that 'goes up-and-down.'
That patent link found by @Lnewqban in post 7 above looks interesting.
https://www.physicsforums.com/posts/6799067
At 47 pages if you want to understand it you probably need to print it.
Cheers,
Tom
p.s.
By the way, I had to break the latch holding the top cover to get it off. It was piece of plastic that hooks into the internal metal frame and must be bent outward to release. Totally in accessible when assembled.
The tower part has a back cover that has blind attachments that also seem to require destructive disassembly.
@gary808 I managed to replace all 3 ropes and get mine reassembled, and have put together a youtube video illustrating every step. I hope this is helpful to everyone here!
  • Love
This is great. Thank you for taking the time and effort.
I don't even own this piece of furniture but I found the explanation very interesting and well explained.
Besides, it's always nice seeing people trying to repair things in these times when the idea of throwing away and buying a new one is more present than ever.
(minute 4:08)
I was not familiar with the whole thing you explained about knots and spliced ropes. It feels like this knot but using only one end of the rope.
The ropes seem to be a failure point for the mechanism. I wonder if they chose the wrong option for the material by mistake or if there is another reason. From what you're seeing, it's possible to find affordable ropes of similar size that are much stronger in comparison.
(minute 4:28)
What about the splicing tool you designed? To be honest, I don't think I'll ever need it but I'm curious about how it looks within. Also, what's the wire made of?
(8:32)
The new pulley you redesigned looks much sturdier. However, don't you think the rope contacting the screw directly could be a problem in the long run? I'm somewhat involved with systems that are held together by Dyneema rope and then vibrated. The smallest dent it finds can start causing issues with the ropes. Maybe you'd put a bushing with some clearance on top of the screw so the threads don't contact the rope and also acts as somewhat of a bearing to minimize dynamic friction between the bushing and the rope.
(12:21)
Somewhat related to a previous point. Could the zip tie become an issue? Can the rope run over it or is that at an out-of-travel region of the mechanism?So again, great video. You clearly have a talent for doing and explaining these kinds of things. The choice of different colors for the ropes makes the whole explanation much easier to follow.
By the way, nice workshop. I wish I could have a similar one at some point.
I haven't watched the whole video. A couple of points on your eye splices:
  • Pulling the loop through the rope creates a twist in the Brummel knot. You can undo this by pulling the rope back through the knot as shown in the videos I will link below.
  • Recommendations vary for the length buried inside the core: I have never seen less than 50 times the diameter recommended but more often 60 which is what I aim for. The rope you are using looks like 4mm SK78 Dyneema (is that correct?) which implies a bury of 24cm for each end. For these short loops you haven't got room for that so I would just bury as much as I can.
  • You should taper the ends of the rope before burying them: pull out 6 of the twelve strands starting 6 braids away from the end and cut them as shown in the videos below.
There are many sources of information on rope work: the first below is a US supplier and the second a UK manufacturer.
  • · Replies 37 ·
18K
36K
12K
37K
