Role of Dark Matter in the Evolution of Large Scale Structure
  • Context: Undergrad
  • Thread starter Thread starter hkyriazi
    Dark matter
The discussion revolves around the role of dark matter, particularly cold dark matter (CDM), in the formation and evolution of large-scale structures in the universe. Participants explore theoretical aspects, implications for cosmological models, and the distinctions between different types of dark matter, including hot dark matter (HDM) and warm dark matter (WDM).
  • Some participants propose that dark matter's lack of interaction with photons allows it to coalesce gravitationally, forming the scaffolding for regular matter after photon pressure decreases.
  • Others argue that dark matter must be cold to prevent the destruction of large-scale structures, as simulations indicate that CDM is necessary for explaining observed galaxy formations.
  • A participant expresses confusion regarding the difference between "cold" and "dark" matter, questioning whether dark matter must be cold to form charge-neutral "dark matter molecules" that can coalesce gravitationally.
  • Another participant clarifies that "cold" refers to a temperature low enough to be negligible in the universe's dynamics, while all matter is currently considered "cold" by this criterion.
  • One argument highlights that simulations of the universe's history require cold dark matter to achieve the necessary clumping for structure formation, which baryonic matter alone fails to provide.
  • Some participants challenge the necessity of cold dark matter, noting that ordinary matter can be hot yet still engage in gravitational attraction, questioning the assumptions behind the cold requirement.
  • A later reply discusses the classification of dark matter types based on particle mass and velocity, suggesting that the mean velocity of dark matter particles is crucial for their role in structure formation.
  • Participants mention the "freeze out" scenario as a potential explanation for the current amount of dark matter, involving initial conditions of thermal equilibrium in the early universe.
Participants express various viewpoints on the nature and requirements of dark matter, particularly regarding its temperature and role in structure formation. There is no consensus on the necessity of cold dark matter, and the discussion remains unresolved with competing perspectives.
Limitations include varying definitions of "cold," "dark," and "hot" matter, as well as assumptions about the interactions and behaviors of dark matter particles. The discussion also reflects differing levels of familiarity with the subject matter among participants.
hkyriazi
Is the basic idea behind the CDM theory regarding the production of the Universe's large scale structure simply that dark matter, being dark, doesn't interact with photons, and thus was able to coalesce gravitationally soon after the Big Bang, forming the scaffolding toward which regular matter only later was attracted (after "photon pressure" fell below some critical level)?
Space news on Phys.org
The main idea is that DM must be cold, because if it were not, it would destroy the large scale structure that we see.
A secondary idea is that adding CDM promotes the formation of large-scale structure. HDM is excluded based on what we see, and CDM is favored over no DM based on what we see,
I may have to display some ignorance here, as I'm unclear on the functional difference between "cold" matter and "dark" matter. Clearly we can postulate a new type of matter that doesn't interact with photons regardless of its vibrational, rotational, or linear kinetic energy (temperature). (I assume this is why we call it "dark.") Must it be cold so that it can form postulated charge neutral "dark matter molecules" that can then coalesce gravitationally (rather than colliding and recoiling from each other)? Just guessing here...
"Cold" just means "at a temperature low enough that it can be assumed to be zero as far as the overall dynamics of the universe is concerned." Or, from a mathematical point of view, "cold" means "zero pressure in the Friedmann equations". At present all of the matter in the universe is "cold" by this criterion.
One argument for the necessity of (cold) Dark Matter is that, if you do simulations of the history of our Universe using the standard cosmological model you need that part of the matter content to get "enough clumping" to explain the structure formation of galaxies, galaxy clusters, etc. in the right way. With "baryonic", i.e., "usual matter" alone, that doesn't work out right:
https://en.wikipedia.org/wiki/Millennium_Run
https://arxiv.org/abs/astro-ph/0504097
Vanadium 50 said:
"The main idea is that DM must be cold, because if it were not, it would destroy the large scale structure that we see."
Again, I may be displaying some ignorance here, but ordinary matter can be quite hot and still engage in strong gravitational attraction. Why is dark matter thought necessarily to be cold (at or near zero Kelvin according to one response) in order to do the same, i.e., to fulfill its role in seeding large scale structure formation during the early time when highly energetic photons kept regular matter from coalescing from gravity?
You can fix this by looking things up, starting with Wikipedia.
You seem to be coming here "gunning for bear" but not from a position of knowledge. That's not going to go over well.
Thanks. I do often read Wikipedia entries, but figured I understood what the words "hot" and "cold" meant. Seems I didn't in this case. Quoting from their entry on "hot dark matter": "As we shall see below, it is useful to differentiate dark matter into "hot" (HDM) and "cold" (CDM) types–some even suggesting a middle-ground of "warm" dark matter (WDM). The terminology refers to the mass of the dark matter particles (which dictates the speed at which they travel): HDM travels faster than CDM because the HDM particles are theorized to be of lower mass.[3]"
Elsewhere it is stated that hot dark matter particles are ultrarelativistic. Thus, it seems their "heat" is postulated to be all in translational motion, and thus such particles are unlikely to clump gravitationally.
I came simply trying to shore up some possible gaps in my understanding of current theory. Why would anyone in a "position of knowledge" ask a question here anyway? Maybe stating my own understanding and asking if I'm correct isn't the best way to ask questions around here.
There are different levels of knowledge. You originally marked this thread as "A" level; that indicates a graduate level knowledge of the subject matter. If you look at other "A" level threads you will see people with that level of knowledge asking questions that are based on that level of knowledge--often questions about newly published papers in open areas of research, papers that require an "A" level of background knowledge to properly understand.
In other words, whatever your level of knowledge, there is always more to learn. No one knows everything.
That is often true, yes. It's much better, at the very least, to have a specific reference on which to base your question--something like "reference A says X but I don't understand the basis for that because of P, Q, R...".
Whether dark matter is "hot", "warm", or "cold" is a function of the mean velocity of dark matter particles of that type. And, because dark matter has little or no interactions with other matter, by hypothesis, once dark matter forms and reaches an equilibrium state, presumably not long after the Big Bang, this mean velocity should stay more or less constant. (This isn't perfectly true, even for truly "sterile" dark matter that has interactions only via gravity, because gravitational interaction can alter the mean velocity of dark matter in dark matter halos, if the dark matter is distributed in a particular way. Cosmologists and astrophysicists usually assume, however, as a first order approximation that this effect is small, even over times on the order of billions of years.)
In the case of "thermal freeze-out" dark matter, mean velocity is related by a virial theorem to the mass of the dark matter particle:
In the universe, today, [assume] there exists some non-zero amount of dark matter. How did it get here? Has this same amount always been here? Did it start out as more or less earlier in the universe? The so-called “freeze out” scenario is one explanation for how the amount of dark matter we see today came to be.
The freeze out scenario essentially says that there is some large amount of dark matter in the early universe that decreases to the amount we observe today. This early universe dark matter
(\chi)
is in thermal equilibrum with the particle bath
(f)
, meaning that whatever particle processes create and destroy dark matter, they happen at equal rates,
\chi \chi \rightleftharpoons f f
, so that the net amount of dark matter is unchanged. We will take this as our “initial condition” and evolve it by letting the universe expand. For pedagogical reasons, we will name processes that create dark matter
(f f \rightharpoonup \chi \chi)
“production” processes, and processes that destroy dark matter
( \chi \chi \rightharpoonup f f)
“annihilation” processes.
Now that we’ve established our initial condition, a large amount of dark matter in thermal equilibrium with the particle bath, let us evolve it by letting the universe expand. As the universe expands, two things happen:
  1. The energy scale of the particle bath
    (f)
    decreases. The expansion of the universe also cools down the particle bath. At energy scales (temperatures) less than the dark matter mass, the production reaction becomes kinematically forbidden. This is because the initial bath particles simply don’t have enough energy to produce dark matter. The annihilation process though is unaffected, it only requires that dark matter find itself to annihilate. The net effect is that as the universe cools, dark matter production slows down and eventually stops.
  2. Dark matter annihilations cease. Due to the expansion of the universe, dark matter particles become increasingly separated in space which makes it harder for them to find each other and annihilate. The result is that as the universe expands, dark matter annihilations eventually cease.
"Hot" dark matter is dark matter whose mean velocity is in the relativistic range or close (perhaps 0.1 c or more, or even as little as 0.001 c). The classic example of "hot" dark matter would be sterile neutrinos with masses comparable to the masses of the neutrinos or perhaps to the electron mass. Basically in the ballpark of 10 eV or less for thermal freeze out dark matter.
"Warm" dark matter in the case of thermal freeze-out dark matter is dark matter with a particle mass on the order of 1-100 keV/c2.
"Cold" dark matter in the case of thermal freeze out dark matter is dark matter with a particle mass on the order of 1 GeV or more, with the favored region being the electroweak mass scale of perhaps 10 GeV to 500 GeV.
This range of dark matter particle masses was initially favored because when the cold dark matter hypothesis was formulated, electroweak scale supersymmetry, which would have created new particles in this mass range that interacted only via the weak force, was expected by many theorists to be right around the corner. At that mass the relic abundance of dark matter, the mass and properties of the predicted lightest supersymmetric particle in a thermal freeze out scenario seemed like an excellent fit to the properties that dark matter needed to have to fit astronomy observations.
Many decades later, we know that this hypothesis has not panned out. Supersymmetric particles with the properties expected from the electroweak scale supersymmetry theories that were favored at the time have been ruled out by collider experiments and direct dark matter detection experiments. And, collisionless cold dark matter (or dark matter that interacts only via gravity and the weak force), generically, leads to dark matter halo shapes that are materially different from what is inferred from the dynamics of ordinary matter.
The Wikipedia explanation of the concept is as follows:
Dark matter can be divided into cold, warm, and hot categories.These categories refer to velocity rather than an actual temperature, indicating how far corresponding objects moved due to random motions in the early universe, before they slowed due to cosmic expansion – this is an important distance called the free streaming length (FSL). Primordial density fluctuations smaller than this length get washed out as particles spread from overdense to underdense regions, while larger fluctuations are unaffected; therefore this length sets a minimum scale for later structure formation.
The categories are set with respect to the size of a protogalaxy (an object that later evolves into a dwarf galaxy): Dark matter particles are classified as cold, warm, or hot according to their FSL; much smaller (cold), similar to (warm), or much larger (hot) than a protogalaxy. Mixtures of the above are also possible: a theory of mixed dark matter was popular in the mid-1990s, but was rejected following the discovery of dark energy.
Cold dark matter leads to a bottom-up formation of structure with galaxies forming first and galaxy clusters at a latter stage, while hot dark matter would result in a top-down formation scenario with large matter aggregations forming early, later fragmenting into separate galaxies; the latter is excluded by high-redshift galaxy observations.
Low mass dark matter candidates were initially disfavored because of the concern that it would be hot dark matter in a thermal freeze out scenario which was the widespread assumption in cosmology circles. But, eventually, it was recognized that dark matter could be created by processes that didn't involve thermal freeze out, so long as the amount of dark matter created and destroyed balanced out neatly, thus breaking the tight link between dark matter particle mass and the mean velocity of particles of that type, which in turn, determines if it is cold, warm, or hot.
Warm dark matter particles with very low mass are attractive because the wave-like behavior of particles starts to become pronounced relative to particle-like behavior of particles at low masses, and this wave-like behavior can help to address some of the problems generic to the dark matter halo shapes we would generically expect in the case of heavier and cold dark matter.
If dark matter particles are indeed low in mass (sometimes called, somewhat ironically "light dark matter") relative to say, thermal freeze-out warm dark matter, then dark matter particles presumably came to be by a means other than thermal freeze-out that may continue to be occurring in equilibrium today.
  • · Replies 40 ·
  • Featured
  • · Replies 20 ·
  • · Replies 18 ·
