New muon g-2 calculation consistent with experiment
  • Context: Undergrad
  • Thread starter Thread starter ohwilleke
    Magnetic Muon
The updated BMW calculation of the hadronic vacuum polarization contribution to the muon anomalous magnetic moment aμ is consistent with the experimental measurement of muon g-2, showing an agreement at 0.9 sigma. The new calculation reduces uncertainty by 40%, while the 2023 experimental measurement has 55% less uncertainty, making the agreement more significant. The new value for aμ is 116,592,019(38) × 10−11, which validates the Standard Model to 0.37 ppm. This consistency challenges the justification for next-generation particle colliders, as it diminishes the likelihood of discovering new physics beyond the Standard Model.
  • Understanding of muon g-2 and its significance in particle physics
  • Familiarity with hadronic vacuum polarization calculations
  • Knowledge of lattice QCD and its application in theoretical physics
  • Awareness of experimental methods in particle physics, particularly electron-positron annihilation
  • Research the implications of the latest lattice QCD calculations on muon g-2
  • Explore the role of hadronic vacuum polarization in particle physics
  • Investigate the experimental methodologies used in muon g-2 measurements
  • Study the potential impact of next-generation particle colliders in light of current findings
Particle physicists, researchers in theoretical physics, and anyone interested in the implications of muon g-2 measurements on the Standard Model and future experimental physics initiatives.
ohwilleke
TL;DR
A July 2024 higher precision lattice QCD calculation of muon g-2 is closer than ever to the experimental measurement of muon g-2 last updated in August of 2023.
The updated BMW calculation of the hadronic vacuum polarization contribution to the muon anomalous magnetic moment aμ in the Standard Model is squarely consistent, at 0.9 sigma with the experimental measurement of muon g-2.
This agreement is found to be present despite the fact that its uncertainty in this new and improved HVP calculation is 40% smaller (producing a 31% reduction in the uncertainty of the overall theoretical calculation) and the fact that the 2023 experimental measurement has 55% less uncertainty, making agreement of the two values a harder to hit target.
The experimental value is based upon the first three phases of a six phase experiment. Phase four, whose results are tentatively expected late in 2024 (but could easily be delayed until 2025 or even 2026), will significantly reduce the uncertainty in the experimental result. The improvements from phases five and six are expected to be much smaller. The uncertainty in the experimental result is already about 42% smaller than the uncertainty in the calculation of the Standard Model predicted value. The experimentally measured value will probably continue to have less uncertainty than the Standard Model predicted value calculation for at least several years to come.
The bottom line value for the new 2024 BMW calculation is:
aµ = 116,592,019(38) × 10−11.
Partial calculations confirm the BMW result vis-a-vis the partially experimentally based analysis of the Theory Initiative in the so called "window" part of the calculation (as does the recent CMD-3 experimental measurement of the same experimental inputs that went into the "Theory Initiative" calculation):
The apparent discrepancy between the Theory Initiative calculation of the Standard Model prediction and the experimental results has been the source of countless papers proposing proposals for new physics.
This discrepancy was a result of an inaccurate calculation of the Standard Model prediction for muon g-2 by the Theory Initiative. This was mostly a result of the incorporation of slightly inaccurate experimental data (regarding electron-positron annihilations that produce pion pairs) into their hadronic vacuum polarization calculation. Their source for the experimental data that it used, despite the source's good faith efforts to estimate the uncertainty accurately, understated the uncertainty of that experimental data by roughly a factor of four (as revealed by the spread of the results of subsequent experimental measurements of the same phenomena).
The paper presenting the new lattice QCD calculation of muon g-2 and its abstract are as follows:
We present a new lattice QCD calculation of the leading order hadronic vacuum polarization contribution to the muon anomalous magnetic moment a(μ). We reduce uncertainties compared to our earlier computation by 40%, arXiv:2002.12347. We perform simulations on finer lattices allowing for an even more accurate continuum extrapolation. We also include a small, long-distance contribution obtained using input from experiments in a low-energy regime where they all agree. Combined with other standard model contributions our result leads to a prediction that differs from the measurement of a(μ) by only 0.9 standard deviations. This provides a remarkable validation of the standard model to 0.37ppm.
A. Boccaletti, et al., "High precision calculation of the hadronic vacuum polarisation contribution to the muon anomaly" arXiv:2407.10913 (July 15, 2024).
The new paper also notes that:
In the near future we expect that other lattice collaborations will also provide precise calculations of a(LO-HVP)(µ) that can confirm or refute our results. Also, more data for the e+e− → π+π− cross section is expected soon.
For those of you who aren't visual learners (with values times 1011 shown below):
New BMW calculation (2024): 116,592,019(38)
BMW calculation (2020): 116,591,954(55)
Theory Initiative calculation (2020): 116,591,810(43)
World Experimental Average (2023) : 116,592,059(22)
Fermilab Run 1+2+3 data (2023): 116,592,055(24)
Combined measurement (2021): 116,592,061(41)
Brookhaven's E821 data (2006): 116,592,089(63)
Why Does This Calculation Matter?
The consistency between the experimentally measured value of muon g-2 and the calculation of the value of muon g-2 predicted by the Standard Model, is important because it a strong global test, at high precision, of the accuracy of all parts of the Standard Model at once.
In this test, the experimentally measured result matches the theoretical calculation of muon g-2's value (at a precision of about 4 parts per ten million).
This rules out many kinds of new physics that a next generation particle collider could detect.
While there are still legitimate reasons to build a next generation particle collider (e.g., to refine the precision of the Standard Model's constants, some of which are known to a less than parts per thousand level), the likelihood that a next generation particle collider will reveal new physics beyond the Standard Model is greatly diminished by the current state of the art muon g-2 experimental results and the current state of the art calculation of the Standard Model predicted value for muon g-2. So, the physics justification for a next generation particle collider (which will cost something on the order of $17 billion U.S. dollars if built) as a means of discovering new physics is greatly undermined by this result.
Muon g-2 is less sensitive to new physics at energy scales higher than those of any of the proposed next generation particle colliders, however, so it doesn't rule out new physics at those energies as strongly.
QCD v. Non-QCD Calculations In Muon g-2
The QED + Electroweak (EW) predicted value (omitting the Hadronic Vacuum Polarization (HVP) and Hadronic Light by Light (HLbL) components, and before the latest QED component tweak) is: 116,584,872.53 (101). Thus, it accounts for only about 3% of the total uncertainty in the value of muon g-2. Given the experimental results, the implied combined hadronic (i.e. QCD) contribution to the total is about 7186.47 times 10-11. This is 0.00616% of the total value, despite the fact that it is the source of 97% of the uncertainty in the calculation, because QCD calculations are vastly less precise than QED calculations.
More specifically, in theoretical calculation, the QED calculation is the source of 0.2% of the total uncertainty, the weak force calculation is the source of 2.9% of the total uncertainty, and the QCD calculation is the source of 96.9% of the total uncertainty (with about 10% of the total muon g-2 calculation uncertainty coming from the Hadronic light by light calculation and about 87% of the total muon g-2 calculation uncertainty coming from the Hadronic vacuum polarization calculation).
The QED calculation is the source of 99.994% of the total value of muon g-2, the weak force calculation is the source of 0.00013% (153.6 x 10-11 ± 1 x 10-11), and the QCD calculation is the source of about 0.006% (about 99% of which is from the hadronic vacuum polarization calculation and about 1% of which is from the hadronic light by light calculation).
The relative error in the QED calculation is 0.000 000 0686%, the relative error in the weak force calculation is about 0.65%, and the relative error in the overall QCD calculation is about 0.5%. But since the weak force contribution to the calculation is only about 2% of the magnitude of the QCD contribution to the calculation, greater precision in weak force calculation isn't a priority in improving the precision of the total calculation.
Within the two QCD calculations, the Hadronic Vacuum Polarization calculation has a relative uncertainty of a little less than 0.5% and accounts for the bulk of the QCD contribution to muon g-2 (about 99% of the QCD contribution), while the Hadronic Light by Light calculation has a relative uncertainty of about 20%, but involves a much smaller total contribution to the total value of muon g-2 (about 1.0-1.3% of the QCD contribution and 0.000 08% of the total muon g-2 calculation). The Hadronic Light by Light calculation is the source of a little more than 10% of the uncertainty in the QCD contribution, and of about 10% of the uncertainty in the overall muon g-2 calculation.
These subcomponent breakdowns are spelled out in detail, for example, in T. Aoyama, et al., "The anomalous magnetic moment of the muon in the Standard Model" arXiv (June 8, 2020) (which obviously doesn't include the post-2020 develops in the calculation or in discussion of the experimentally measured value).
Other Tweaks To The Muon g-2 Calculation
Two other tweaks in parts of the muon g-2 calculation have also been made and aren't included in the new paper. They reduce the difference between the theoretical calculation and the experimentally measured calculation to about 0.6 sigma, which is a precision of about 2.2 parts per million.
One is an increase of 14.8 x 10-11, in the Hadronic light-by-light calculation from 2021. The relative uncertainty in this component of the calculation is reduced from 20% to 14%. Including this tweak also reduces the uncertainty in the latest BMW calculation of the total muon g-2 value (including its new HVP calculation) from ± 38 x 10-11 to ± 37 x 10-11.
The other is a reduction of about 0.06 x 10-11 in the QED part of the calculation from April of 2024, which is a five sigma downward shift in that calculation. But it is immaterial to the overall muon g-2 calculation because the original calculation was already so precise.
  • · Replies 0 ·
  • · Replies 83 ·
16K
  • · Replies 46 ·
9K
  • · Replies 96 ·
17K
  • · Replies 17 ·
  • · Replies 30 ·
