I Commutation of operators for particle in a box
  • Thread starter Thread starter hokhani
The discussion centers on calculating the commutation relation between the Hamiltonian and momentum operator for a particle in a one-dimensional box. Initial assumptions suggest that they commute, but further analysis reveals that the potential energy term complicates this, particularly due to its discontinuity at the walls of the box. It is established that the commutator is generally non-zero, as the potential does not commute with momentum. The eigenfunctions of the particle in a box do not span the entire Hilbert space due to being zero outside the box, which further complicates the analysis. Ultimately, the expectation of finding a common diagonalization for the Hamiltonian and momentum operator is deemed incorrect.
hokhani
TL;DR
How to calculate ##[H, P}## for a particle in a box?
I would like to know how to calculate the ##[\hat{H}, \hat{P}]## for a particle in a 1D box? At the first glance it seems that they commute but they don't get diagonalized in identical basis. How to calculate this commutation?
Does it? We have ##[H,P]=[P^2/2m,P]+[V(x),P]##; the first term is trivially zero but there’s no reason to expect the second one to be.
You can calculate the in general non-zero second term by applying it to an arbitrary test function: what is ##[V(x),P]\psi(x)## when you expand the commutator?
Likes Demystifier and hokhani
Finite walls or infinite walls? Start down by writing the Hilbert space, then the two operators. You may discover that the commutator is not even defined...
Likes hokhani and Nugatory
Well usually ##[f(x),p]=i\hbar \partial f/\partial x ##, for a function ##f(x)##, but the potential here is kind of troublesome.
I don't see why the potential is "troublesome"; it's a function of ##x## whose derivative won't in general be zero, so it won't commute with ##p##.
In which case it's certainly not zero. So either way the OP's expectation of being able to find a common diagonalization for ##H## and ##P## is false.
The potential is not a function that is differentiable in the usual way (at least not for the infinite well, for the finite well you might use Dirac deltas).
Edit: typo
Nugatory said:
Does it? We have ##[H,P]=[P^2/2m,P]+[V(x),P]##; the first term is trivially zero but there’s no reason to expect the second one to be. what is ##[V(x),P]\psi(x)## when you expand the commutator?
Very nice separation of the Hamiltonian. If we take ##\psi(x)=\sum_m a_m \psi_m## where ##\psi_m## are the eigenfunction of the Hamiltonian, then it seems that we have ##[V(x),P]\psi(x)=0## since inside the box (##|x|<L##) the potential is zero ##V(x)=0## and for ##|x| \geq L## we have ##\psi_m=0##!
For infinite walls I did that in the post #8.
Take ##\psi(x)## to be an arbitrary function and expand the commutator. You will end up with a term proportional to ##\frac{dV}{dx}##, which works just fine when ##V## is continuous and is in general non-zero (but is zero where ##V## is constant, which creates the "at first glance" illusion in your original post).
But ##V## is discontinuous at the walls so that derivative is not defined there.
The usual textbook demonstration for ##~[V(X),P]=iV'(X)~## assumes that ##~V(x),~V'(x)~## can be expanded as power series. Can you generalize it to other differentiable (let alone continuous) functions?
So you assume ##~\infty\cdot0=0~## ?
pines-demon said:
The potential is not a function that is derivable in the usual way (at least not for the infinite well, for the finite well you might use Dirac deltas).
What does "derivable" mean? If you mean sometimes you can't derive its form from first principles, so what? That's true of lots of physics problems; you just have to guess the form of a function.
If you mean its derivative isn't always well-defined, yes, that's true--I addressed that case in post #6.
My bad, I meant differentiable.
Right, it is undefined. However, still another problem remains:
The eigenfunctions of the particle in box, ##\psi_m(x)##, should form a complete basis and any function, ##\psi(x)##, seems to be expanded as ##\psi(x)=\sum_m a_m \psi_m(x)## while ##\psi_m(x)## is zero outside the box!
The eigenfunctions of the particle in box, $\psi_m(x)$, should form a complete basis and any function, $\psi(x)$, seems to be expanded as $\psi(x)=\sum_m a_m \psi_m(x)$ while $\psi_m(x)$ is zero outside the box!
The "pathology" of the infinite potential reduces the Hilbert space from ##~\text{L}^2(-\infty,\infty)~## to ##\text{L}^2(-L,L)~,~\psi(\pm L)=0~## . Therefore we should no longer expect to span the functions outside the box.
If you consider finite potentials in the limit that their "height" tends to infinity, you can see that they are all free from the problems you've noted above, and$$\psi(\pm L)\rightarrow 0 \quad,\quad \psi(L<|x|)\rightarrow0$$as expected.
While you are at it, try to find the error in the following argument:$$i\hbar \delta(0)=\langle x |i\hbar| x \rangle=\langle x |[X,P]| x \rangle=\langle x |XP| x \rangle-\langle x |PX| x \rangle=x\langle x |P| x \rangle-\langle x |P| x \rangle x=0$$
BTW: use of the "preview" option before posting is always recommended.
Likes dextercioby
I look for the error in the term ##\langle x |P| x \rangle=-i\hbar \frac{\partial}{\partial x} \delta(0)## which seems undefined.
Thanks for regarding the preview check, but I don't know why my preview sometimes doesn't work!
  • · Replies 17 ·
