Undergrad Non-orthogonal bases
  • Thread starter Thread starter geordief
Non-orthogonal basis vectors, such as e and f, are significant in various physical applications, particularly in engineering and relativistic physics. They provide a flexible framework for modeling dynamic systems, where eigenvalues and eigenvectors can simplify analysis despite often being non-orthogonal. Transforming to an orthogonal basis can facilitate mathematical calculations, allowing for easier problem-solving before converting back to the original non-orthogonal basis for interpretation. Real-world examples include crystal structures and mechanical systems, where non-orthogonal coordinates can represent natural behaviors effectively. Understanding the implications of basis choice is crucial, as it can impact the interpretation of results in fields like relativity and material mechanics.
geordief
TL;DR
What are they supposed to model
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes.
I have seen that this is an important subject in maths
My question is what physical applications does such a model apply to?
I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual space and have come away with little understanding.
So,and pardon the pun I am going back to basics and picking up on this particular question (hopefully others will follow if I feel comfortable as I get my answer)
Mathematics news on Phys.org
Unless two variables, X and Y, are not related, they will not be orthogonal. The vast majority of variables related to the same subject of interest will also be somewhat related to each other. More often than not, two variables must be analyzed if one wants to determine components that are not related. The Graham-Schmidt orthogonalization process helps there.
Example: X=arm length, Y=leg length. You can expect them to be related, but not completely. You can find a component of Y=leg length that is independent of X=arm length. That would be an interesting component to study.
I suspect you are asking this in the context of relativistic physics, in which case the answer is that basis vectors don't model anything. They're just a tool and a matter of choice, and you occasionally find it useful to use non-orthogonal basis vectors. An example is a rotating reference frame, where using orthogonal coordinates leads to simultaneity planes that don't close (so some parts of "now" lie in the future of other parts, which is problematic). It can be easier to define non-orthogonal coordinates (and basis vectors) so that "now" isn't multiply-valued. But if you only need to consider a small part of an orbit it can be easier to stick with an orthogonal basis because the problems with it are outside the region you care about. Your choice; some scenarios need more care depending which one you pick.
This appears quite often in engineering. We use eigenvalues and eigenvectors to model dynamic systems to make the analysis easier do and understand. Read a little bit about what these are (you'll study them for real later, I think). These vectors are usually not orthogonal, but the way we want to describe the system behavior at the end is often wrt an orthogonal basis. So we will use linear transforms to switch from one basis to another. One is what we want to measure or control, the other is the way the system naturally responds.
Here's a simpler example that I worked with IRL. Suppose you have to tilt a mirror in a laser system in a desired direction which is describe with orthogonal coordinate basis. The mirror has a fixed pivot point and two actuators located away from that point that can cause it to tilt. However for practical mechanical reasons the triangle formed by these three points that define the mirror plane can't be at right angles. I need to know how much each of the actuators need to be moved to get the desired tilt wrt the orthogonal basis. So, for example, tilt the mirror in the ##\bar x## direction with ##\bar y## unchanged, but my actuators aren't on the ##\bar x## axis, they each change the ##\bar x## and ##\bar y## tilt in different ways.
Anyway, it is a very important tool to understand IMO, you are likely to use it later for real.
There are lots of materials you might run across that naturally have non-orthogonal basis to describe anisotropic behavior like strength or optical properties. Crystals (Quartz, Calcite, etc.) very often have a crystal structure that isn't orthogonal.
The mathematical solutions to many real world problems are much simpler if you arrange your equations to match the natural basis of the system, which is often non-orthogonal. So, it is common to do a simple transform to the natural basis, solve the problem, and do the inverse transform back to the basis you started with. In this way you can solve three simple problems instead of one difficult problem.
A classic example is the evaluation of ##e^{\mathbf A t} \equiv 1 + \frac{\mathbf At}{1!} + \frac{ { ({\mathbf A} t)}^2 }{2!} + \frac{ { ({\mathbf A} t)}^3 }{3!} + ...##, where ##\mathbf A## is a matrix. This is really hard unless you can transform your basis so that ##\mathbf A## is diagonal, then it's trivial. This isn't pedantic, it's the basis for modern control systems solutions in applications like fighter jets and chemical factories. You can search for the terms "modern control systems" or "state transition matrix" if you want to know more.
https://en.wikipedia.org/wiki/Matrix_exponential#Computing_the_matrix_exponential
Likes hutchphd and FactChecker
Thanks very much for those answers So a tool it is but non orthogonal axes do occur in real applications.(the crystals seem obvious now that it has been pointed out)
Yes I am interested in relativistic physics but lack any expertise. Very much a talentless amateur 😀
I would say this a little differently:
There are things (like crystal structure) that are natural to represent using a non-orthogonal basis. For the actual mathematical calculation, transforming to an orthogonal basis can make the calculation easier. Then the solution can be transformed back to the non-orthogonal basis for a natural physical interpretation.
Likes WWGD, Ibix and DaveE
Yes, sometimes. We need to be a bit nimble to select basis and reference frames to make simple calculations as well as further understanding. The common theme is that some basis are easy to understand and some are easy to calculate. Caveat emptor.
I would add that my previous reference to the state transition matrix is generally applicable to any system of linear differential equations, whether it's QM or the strength of a bridge. You could just view this from purely mathematical perspective, like Wolfram Alpha et. al., as a method to solve equations. The "natural" structure will appear in the initial formulation of the equations. I think the math can facilitate deeper understanding, but maybe not if we can't grok the basis used.
Likes FactChecker and Ibix
Agreed.
Many of the "paradoxes" in relativity stem from unknowingly importing intuition from orthogonal coordinates into non-orthogonal ones, or otherwise not realising the implications of your coordinate or basis choice. (Basis and coordinates aren't the same thing, although they're often related, so this example is slightly off-topic.)
Just to point out, though likely obvious to most, that we need to have an inner-product defined in order to define or talk about orthogonality. Else, in a standard vector space , it doesn't apply, make sense to speak of it.
Likes Svein and DaveE
Yes. Also, people (like me) often are assuming linearity, which isn't always true.
A lot o numerical analysis involves dealing with spaces of polynomials of degree at most $$N$$ on $$[-1,1]$$. There are various families of polynomials which can be taken as basis functions, and these will be orthogonal with respect to a particular inner product.
Quite often, one wishes to restrict attention to those polynomials which vanish at the end points. These form a subspace, and the usual way to get a basis for this subspace is to use simple linear combinations of the original family. These will no longer be orthogonal, but this is not a problem.
In analyzing the mechanics of deformable membranes (such as, for example, the deformations and stresses within an automobile tire structure modeled as non-isotropic membrane), it is very convenient to use an embedded material coordinate system in which the material coordinates stretch and become non-orthogonal. This carries over to 3D structures that experience large non-homogeneous deformations.
Likes berkeman, DaveE and FactChecker
  • · Replies 27 ·
