Undergrad Schrödinger equation and classical wave equation
Schrödinger's equation differs fundamentally from the classical wave equation, primarily being first order in time derivatives compared to the classical equation's second order. Although both equations describe wave-like phenomena, the interpretation of Schrödinger's equation as a quantum wave function emerged later, emphasizing its probabilistic nature. The equation's formulation involved reverse engineering from classical mechanics and optics, but its implications for quantum mechanics were not fully understood at the time of its creation. The presence of Planck's constant in Schrödinger's equation signifies its quantum nature, yet its mathematical structure could resemble classical equations without additional context. Ultimately, while there are similarities, the distinctions highlight the unique characteristics of quantum mechanics compared to classical physics.
  • #31
Meden Agan said:
I can't conclude that Schrödinger's equation is completely different from the classical wave equation.
What does "completely different" even mean? And why do you care?
Meden Agan said:
From this point of view, I don't find the petition of principle that Schrödinger's equation is completely different from classical wave equations to be very well-founded.
Who is even making this claim? And again, why do you care?
Meden Agan said:
All this makes me think that, technically, after all it is a wave equation.
Okay, suppose we say it is "technically" a wave equation (whatever that means). So what? Why do you care?
The reason I keep asking "why do you care" is that none of this has anything to do with actually using the Schrodinger Equation to make predictions. And physics is about making predictions that match experiments. Physics is not about arguing over how we label things, whether the label "wave equation" makes sense, etc., etc. So I'm really struggling to see why you are belaboring all this.
Meden Agan said:
Isn't that a bit contradictory?
I don't see a contradiction. I see you throwing around vague terms and manufacturing imaginary issues out of nowhere. Sorry to be blunt, but that's how I see it. I don't see any actual issue here that needs to be resolved.
Likes Dale and pines-demon
  • #32
I think you're right.
So, although my original question was different and vague, I'd like to analyze some technicalities of Schrödinger's equation.
Is what I said in post #30 correct?
  • #33
You said a lot in post #30. What particular point or points are you asking about?
Likes pines-demon
  • #34
These paragraphs.
Meden Agan said:
What we know since Lagrange is that the eikonal equation governs the geometric limit of wave optics. At the same time, the equation of mechanical "rays" is governed by a similar equation, the Hamilton-Jacobi equation, in which, however, we have a first derivative with respect to time. The difference between the two types of equations in contemporary terms can be attributed to the following.
Light is propagated by individually massless particles, leading to a homogeneous Lagrangian of degree ##1##, which supports a presymplectic formalism and freedom of parameterization with respect to time (from which Fermat's principle derives). Dynamics of material particles, on the other hand, derive from a principle of minimum in which time is not a free parameter.
Schrödinger's intuition was to reverse the process by which we derive the eikonal equation for geometric optics from wave optics, but starting from the Hamilton-Jacobi equation.
Schrödinger was really looking for the oscillations postulated by De Broglie, which accounted for Bohr and Sommerfeld's atomic model. And at first, he thought he had found them. The problem that emerged, however, was that the hypothesis that these were oscillations of a classical type of field was not compatible with Born's law, which was based on solid experimental evidence. At the same time, the problem of explaining the interactions between matter and the electromagnetic field had arisen. Focusing on this problem, Heisenberg developed matrix mechanics. From this, a much broader picture emerged, in which Schrödinger's equation was only one aspect. It was discovered that it was also involved in the phenomenology of electromagnetic waves, which culminated in the Copenhagen interpretation and the unification carried out by Jordan between matrix mechanics and Schrödinger mechanics.
Jordan proved that they were two different but equivalent representations. However, this unification required a change in the paradigm of matter waves initially assumed by Schrödinger, in favor of the probability waves that we now learn about together with the equation.
  • #35
Meden Agan said:
These paragraphs.
Still a lot, and I'm not sure where it's all coming from or why you're asking about it. Some references would be helpful.
If your main point is that the quantity ##\Psi## that appears in the Schrodinger Equation describes a probability amplitude, not an actual "matter wave" or anything like that, yes, I agree with that.
Likes pines-demon and Meden Agan
  • #36
My primary reference is Variational Principles in Dynamics and Quantum Theory by Yourgrau and Mandelstam.
It's possible to see an outline of Schrödinger's original arguments for the time-independent Schrödinger equation in section 8 of Field's paper Derivation of the Schrödinger equation from the Hamilton-Jacobi equation in Feynman's path integral formulation of quantum mechanics.
I was trying to answer my question in post #1
Meden Agan said:
When deriving the classical wave equation for entities such as the electric and magnetic fields, we consider the oscillation of the electric and magnetic fields. Similarly, why did Schrödinger not derive the wave equation for the physical oscillation of an electron? How did he know that there is no physical oscillation in the electron and that it is only a matter of probability, given that AFAIK the probabilistic interpretation of the wave function came two years after his equation?
and I was looking for your confirmation, which I believe I have received.
  • #37
Again, there's a lot in your post #1, and I'm not sure which question you're talking about.
I only confirmed that ##\Psi## is a probability amplitude. I didn't say anything about what Schrodinger was thinking. If the main question you are concerned about is this...
...then the answer, which is a matter of history, not physics, is that, when he came up with his equation, he didn't know that ##\Psi## was a probability amplitude. He thought it was describing some kind of physical "matter wave" associated with the electron. He only found out that ##\Psi## was a probability amplitude when Born came up with the probability interpretation of ##\Psi## two years later. @Demystifier already gave you that answer in post #2 of the thread.
  • #38
pines-demon said:
Feel free to go over the arguments again—sometimes repeating them makes things easier to understand.
I will repeat this once again. I am not the only one that does not get what the main question is.
  • #39
Sorry, I wasn't clear from the very start.
In my academic studies, I've heard some professors say that Schrödinger's equation is a wave equation, and others say that Schrödinger's equation is a diffusion equation.
I was confused by the terminology. I think @PeterDonis is right when he asserts this:
  • #40
"I've heard" is not a valid reference. If you can give us references to actual textbooks or peer-reviewed papers that make statements like these, we can discuss them. But we can't discuss vague allusions to something somebody heard.
I'm closing the thread since it appears that all valid points have been addressed.
Likes bhobba, pines-demon and Meden Agan
  • · Replies 17 ·
  • · Replies 143 ·
11K
