A practical way to vaporize fuel for high MPG?
  • Thread starter Thread starter NTL2009
    Engine efficiency
The discussion revolves around the feasibility of achieving high fuel efficiency, specifically 100 mpg, through the vaporization of fuel in a modified 1970 Ford Galaxy with a 427 cubic inch V8 engine. The video referenced suggests that fully vaporized fuel burns cleaner and can operate at a leaner air-fuel ratio, potentially improving mileage, but at the cost of performance due to reduced power output. A proposed solution involves using a pre-combustion chamber to facilitate vaporization while addressing safety concerns and efficiency issues. However, skepticism remains regarding the practicality of such modifications, as achieving high mpg without sacrificing acceleration and power appears challenging. Overall, the conversation highlights the complexities and limitations of fuel vaporization technology in internal combustion engines.
  • #31
I am not sure we see unburnt fuel in a modern spark ignition engine, so I am doubtful abut the advantage of pre-vapourising the fuel.
  • #32
If there was no unburnt fuel at all, we wouldn't need catalytic converters.
Likes Ranger Mike
  • #33
Absolutely brilliant reply, Jack!
Likes russ_watters and jack action
  • #34
I'm going to be lazy about this: Google AI tells me it's less than 1%.
Likes Ranger Mike
  • #35
russ_watters said:
I think this is a pretty good reason to believe there is next to no benefit:
Just being liquid vs vapor doesn't say much - it doesn't change the amount of energy available by more than a few percent (e.g., you could preheat a liquid fuel). In order for there to be much of a performance hit due to the fuel being liquid, it would have to be not burning or burning very late, and that just isn't happening.
Yes, but there is still a twist here. The author does state that running on vaporized fuel alone would have terrible performance. So modern engines set up with propane or LNG would be tuned differently, and not be talking (supposed) advantage of the lean ratio.
From my reading, it seems that the propane/LNG are delivered to fuel injectors as a liquid. So all the vaporization has to take place in or just before the cylinder. I'm guessing that still has time to vaporize, as it is vapor at normal atmosphere, but maybe not? But if it does have time to vaporize, and this allowed lean ratios, it would seem the computer could adjust for this, and provide lean ratio under light loads only (again, assuming there is a benefit)? So either there is no real benefit (as much of this conversations seems to point to), or there isn't a big enough market of propane/LNG vehicles to research leaner mixtures for low-load, or there are other problems with the lean mix - I think I've read you might need some unburnt fuel for the catalytic converter to handle other pollutants?
  • #36
According to the Wikipedia article, it might sort of be the other way around?
https://en.wikipedia.org/wiki/Catalytic_converter
These "two-way" oxidation converters combine oxygen with carbon monoxide (CO) and unburned hydrocarbons (HC) to produce carbon dioxide (CO2) and water (H2O).
So reducing carbon monoxide. And...
"Three-way" converters, which also reduce oxides of nitrogen .... three-way-converters require fuel-rich or stoichiometric combustion to successfully reduce NO<em>x</em>.
reducing NOx - but some unburnt fuel is needed for the conversion. I think you can have very complete combustion, but with high NOx levels. So that would be a problem, and the 'solution' is - more unburnt fuel! Well, engineering is always a balancing act, right?
Likes jack action
16K
25K
25K
