Confusion on sign convention in X-ray problems
  • Thread starter Thread starter palaphys
    Atomic physics
The forum discussion centers on the interpretation of energy values in X-ray problems, specifically regarding the energy of Molybdenum atoms. Participants clarify that the energy of a bound system can be represented as negative, with the K-electron energy level of Molybdenum being -20.0 keV, while the question references an arbitrary energy value of 27.5 keV. The ambiguity in the final state of the atom, whether it is missing an L-electron or both K and L-electrons, is highlighted as a critical point for accurate problem-solving. Ultimately, the consensus is to assume the first state for calculations, leading to the conclusion that the energy of the atom in the final state can be derived from the difference in energy levels.
  • Understanding of atomic structure and electron shells
  • Familiarity with X-ray physics and ionization energy
  • Knowledge of energy units, specifically keV (kilo-electronvolts)
  • Ability to interpret and analyze physics problems involving energy states
  • Research the concept of ionization energy in transition metals, focusing on Molybdenum
  • Learn about the significance of energy levels in atomic physics
  • Study the principles of X-ray emission and absorption
  • Explore problem-solving strategies for ambiguous physics questions
Physics students, educators, and professionals in the field of atomic and X-ray physics who seek to deepen their understanding of energy states and problem-solving techniques in related scenarios.
palaphys
The Kα X-ray of molybdenum has wavelength 0.071 nm. If the energy of molybdenum atoms with a K electron knocked out is 27.5 keV, the energy of this atom when an L electron is knocked out will be ______ keV. (Round off to the nearest integer)
Energy conservation
The question seems very simple, and its solution is also very simple. But what bothers me is the wording- "energy of Molybdenum atoms" what does that mean?? energy relative to what? also how can the energy of a bound system be positive? and I have never seen "energy of atoms" being used as a terminology before.
Please help me understand what the question is asking for.
Thanks.
This is (IMO) a badly written question for another reason. The final state of the atom is ambiguous. Is it:
a) missing only an L-electron? (call this state-1)? or
b) missing a K-electron and an L-electron (call this state-2)?
For an answer to be possible with the given data, I think we need to assume state-1 is intended.
27.5 keV seems to be an arbitrary energy value with an arbitrary zero reference – think of it simply as the kinetic + potential (external and internal) energy of the singly-ionised molybdenum atom in (let’s call it) state-0.
The atom starts in state-0 with a K-electron missing. Note that if an L-electron drops into the K-vacancy, the atom loses some energy (##E_{photon}##) and is now in state-1.
So, to find the atom’s final (state-1) energy, we just need to subtract the energy lost (the photon energy) from 27.5keV.
Edit - typo's.
Edit - typo's.
I agree that state 1 is the intended state. Also when I thought a bit more about this question, I think I understood it now, they are just saying that the energy of the bound K shell can be thought of as -27.5KeV in a way, so we can use ## E_L- E_K = E_{K_{alpha}} ## hence the "energy of the atom" in the final state mentioned in the will be magnitude of ## E_L##
Please confirm if my thought process is right
Thanks
Thanks
That’s one way of thinking about it. But I’m not convinced that is the intended interpretation.
The ionisation energy of a molybdenum K-electron is 20.0keV, so the K-electron energy level would be -20.0 keV. Why use the value 27.5keV? I think it’s just a badly written question. I hope it’s not from an official examination.
Answering badly written questions is a problem. The best you can do is to state that you think there is a problem (with reason(s)), state any assumption(s) you need to make to answer the question, give an answer based on your assumption(s). In an exam, leave such questions to the end so you answer the 'good' questions first in the limited time.
BTW, upper case ‘K’ is kelvin (temperature unit). Lower case ‘k’ is kilo (prefix). So the correct energy unit is keV, not KeV!
Steve4Physics said:
well, 27.5keV is the value given in the question. Also this question appeared in a previous JEE exam
I think I am satisfied with my solution, so I will continue using this kind of approach for such questions..
