Does this series converge uniformly?
  • Thread starter Thread starter Lotto
The discussion focuses on the uniform convergence of the series defined by the function f_n on the interval [0, 2π]. It is established that f_n converges to 0 as n approaches infinity, with the supremum of the series tending to 0, indicating potential uniform convergence. However, the application of Dirichlet's test is challenged due to the boundedness of the sine function's partial sums, and the Weierstrass M-test is deemed ineffective. The user seeks advice on demonstrating that the series does not converge uniformly by establishing a specific condition involving epsilon. The conversation highlights the complexity of proving uniform convergence in this context.
Lotto
Does series ##\sum_{n=1}^{\infty} \frac{\sin\left(\frac{n^2}{n+\frac 15}x\right)}{n^{x^2-3x+3}}## converges uniformly on the interval ##[0,2\pi]##?
##\exists \epsilon >0 \, \forall n_0 \, \exists n \geq n_0 \, \exists p \, \exists x \in M: \left|\sum_{k=n+1}^{n+p} f_k(x)\right| \geq \epsilon##
First, I tried to show that ##f_n## converges uniformly on ##[0,2\pi]##, which is true since ##f_n \rightarrow 0## for ##n \rightarrow \infty## and ##\sigma_n=\mathrm{sup}\left| \frac{\sin\left(\frac{n^2}{n+\frac 15}x\right)}{n^{x^2-3x+3}} \right| \leq \frac{1}{|n^{x^2-3x+3}|} \leq \frac{1}{n^{\frac 34}}\rightarrow 0##. I can't use neither Leibnitz's test nor Abel's test. For Dirichlet's test I would need to show, that ##\sin\left(\frac{n^2}{n+\frac 15}x \right)## has partialy bounded sums on ##[0,2\pi]##, which I think is not true. Weierstrass M-test doesn't obviously work.
So I tried to prove that ##\exists \epsilon >0 \, \forall n_0 \, \exists n \geq n_0 \, \exists p \, \exists x \in [0,2\pi]: \left|\sum_{k=n+1}^{n+p} f_k(x)\right| \geq \epsilon ##, because that would mean that my series doesn't converge uniformly. I tried to choose ##n=n_0##, ##p=n_0## and ##x=\frac{1}{n^2_0}##, but that didn't work.
Don't you have any tips how to solve this problem?
FYI please share the plot of the sum as function of x which I ordered to ChatGPT.
##x^2-3x+3>1##
##x<1,2<x##
for these area
$$ \sum_{n=1}^\infty |\sigma_n| < \sum_{n=1}^\infty \frac{1}{n^p} ,p>1$$
so the sum converges. Therefore we may pay our effort for ## 1 < x < 2 ##
PS
anuttarasammyak said:
##x^2-3x+3>1##
##x<1,2<x##
for these area
PS
Ah, I see, so on ##[0,1)## and ##(2,2\pi]## our series converges uniformly according to Weierstrass M-test. So for ##[1,2]## I would use Dirichlet's test. We know that ##\frac{1}{n^{x^2-3x+3}}## converges uniformly to zero on ##[1,2]##. So if we show that ##\sin\left(\frac{n^2}{n+\frac 15} x\right)## has partially bounded sums, then according to Dirichlet's test the series converges uniformly on ##[1,2]## and also on ##[0,2\pi]##.
But how do we show that ##\sin\left(\frac{n^2}{n+\frac 15} x\right)## has partially bounded sums? Using the complex definition of sine isn't good in this case, so how to do it?
From the graph in #7, we observe for |x| >> 1 only n=1 term survives so it is sinusoidal between -1 and 1.
From the graph in #3 , for 1<x<2, S_100 shows vibration. It suggests a toughness of showing a convergence. I have no good idea to solve it.
It may help to note that $$\frac{n^2}{n + \frac15} = n - \frac{1}{5 + \frac 1n}.$$
Likes nuuskur and anuttarasammyak
As for the special case ##x=\frac{\pi}{2}##
for n=0 (mod 4)
$$a_n=-\frac{1}{n^b}\sin c_n$$
for n=1 (mod 4)
$$a_n=\frac{1}{n^b}\cos c_n$$
for n=2 (mod 4)
$$a_n=\frac{1}{n^b}\sin c_n$$
for n=3 (mod 4)
$$a_n=-\frac{1}{n^b}\cos c_n$$
where
$$c_n=\frac{1}{5+\frac{1}{n}}\frac{\pi}{2} = \frac{\pi}{10}(1-\frac{1}{5n}+o(n^{-2}))$$
$$b=(\frac{\pi}
{2}-\frac{3}{2})^2+\frac{3}{4}=0.755501...$$
The partial sum for Dirichlet's test is
$$S_N=\cos c_1 + \sin c_2 - \cos c_3 - \sin c_4 + ...$$
$$ = 2\sin \frac{c_1+c_3}{2}\sin\frac{c_3-c_1}{2}-2\cos\frac{c_2+c_4}{2}\sin\frac{c_4-c_2}{2}+...$$
This seems bounded but should be investigated,
To show that ##\sin (\frac{n^2}{n+a} x)## has partially bounded sums for ##x \in [1,2]##: Write
\begin{align*}
\frac{n^2}{n+a} = n - a + \frac{a^2}{n+a}
\end{align*}
Then
\begin{align*}
\sin (\frac{n^2}{n+a} x) = \sin (n - a + r_n) x , \quad where \quad r_n = \frac{a^2}{n+a}
\end{align*}
Complex exponentials:
\begin{align*}
S_N = \sum_{n=1}^N e^{i (n - a + r_n) x} = e^{-ia x } \sum_{n=1}^N e^{inx} e^{i r_n x}
\end{align*}
Write
\begin{align*}
\sum_{n=1}^N e^{inx} e^{i r_n x} = \sum_{n=1}^N e^{inx} + \sum_{n=1}^N e^{inx} (e^{i r_n x} - 1)
\end{align*}
##\sum_{n=1}^N e^{inx}## is a partialy bounded sum. Then consider the sum:
\begin{align*}
\sum_{n=1}^N e^{inx} (e^{i r_n x} - 1) & = \sum_{n=1}^N e^{inx} i r_n x + \sum_{n=1}^N e^{inx} \sum_{m=2}^\infty \frac{(ix)^m}{m!} \frac{a^{2m}}{(n+a)^m}
\nonumber \\
& = \sum_{n=1}^N e^{inx} i r_n x + \sum_{m=2}^\infty \frac{a^{2m}}{m!} \sum_{n=1}^N e^{inx} \frac{(ix)^m}{(n+a)^m}
\end{align*}
First sum: ##r_{n+1} x \leq r_n x## for all ##x \in [1,2]##. By Dirichlet convergences and hence bounded partial sums. For the second sum:
\begin{align*}
|\sum_{m=2}^\infty \frac{a^{2m}}{m!} \sum_{n=1}^N e^{inx} \frac{(ix)^m}{(n+a)^m}|
& \leq \sum_{m=2}^\infty \frac{x^m a^{2m}}{m!} \sum_{n=1}^N \frac{1}{(n+a)^m}
\nonumber \\
& \leq \sum_{m=2}^\infty \frac{x^m a^{2m}}{m!} \sum_{n=1}^\infty \frac{1}{(n+a)^m}
\nonumber \\
& \leq \sum_{m=2}^\infty \frac{x^m a^{2m}}{m!} \sum_{n=1}^\infty \frac{1}{n^m}
\end{align*}
But ##\lim_{m \rightarrow \infty} \zeta(m) = 1##, so by the limit comparison test we have convergence.
Likes anuttarasammyak and Lotto
