- 10,442
- 1,606
Jaime Rudas said:Is that "flat plane" two-dimensional or three-dimensional?
Two dimensional
The discussion centers on the implications of Euclidean geometry in the presence of strong gravitational fields, particularly near black holes. It is established that triangles drawn on a flat surface in such regions may not have angles summing to 180 degrees due to the effects of non-Euclidean geometry. Measurements involving spherical shells reveal that the radial distances will exceed Euclidean predictions. Observations made from a distance complicate interpretations due to light's behavior in curved spacetime, but usable data can still be extracted regarding spacetime curvature.
PREREQUISITESPhysicists, cosmologists, and students of general relativity seeking to understand the effects of gravity on spatial geometry and the interpretation of observations near black holes.
If the paper is "hovering" statically, i.e., no radial or tangential motion, frame dragging has no effect.raagamuffin said:Then I read a reference to 'frame dragging' in rotational black holes. What effect, if any, will that have on the 'paper'?
PAllen said:In the side discussion of embedding a piece of a plane smoothly, isometrically, in a 3-sphere (following is part of a response to @pervect 's last post:
I thought I would make explicit the construction in that reference (which is presented it very compactly in any number of dimensions). Making it explicit for flat 2-surface section in a 3-sphere, the mechanism is simply to use a properly sized flat torus. As explained in:
https://en.wikipedia.org/wiki/Clifford_torus
a flat torus of just the right size will smoothly fit in a unit 3-sphere, both embedded in R4. But then, the embedding can be just ignored, and you are left with a smooth embedding of a piece of Euclidean plane in a 3-sphere.
The formalization and generalization of this is the general approach to embedding ##E^n## into higher dimesnsional spheres used in the reference I quoted earlier. The general achievement is a local embedding of ##E^n## into an m-sphere, with ##m=2n-1##.
More precisely, by the Riemann curvature tensor that's derived from a metric via its Levi-Civita connection. There's no problem with that--that's how the term is being used in this discussion.pervect said:I'm viewing curvature as being defined by a metric.
When discussing isometric embeddings, there is a little more to it. The metric of the submanifold is taken to be induced from the manifold metric. This means that, e.g. the distance along a curve on the 2-sphere embedded in E3 is, in fact required to be that same whether you use the manifold metric or the induced metric on the 2-sphere. You get to choose manifold, its metric, and the definition of the submanifold embedded in it as a set of points. You do not then get to choose an arbitrary metric on the submanifold - it is taken to be that induced by the manifold metric.PeterDonis said:The reason it's possible is that the 2-sphere embedded in Euclidean 3-space is a submanifold of that 3-space, and we can define a metric on the submanifold that is curved even though the metric of the 3-space overall is flat. They're simply two different metrics. Note that those metrics give different answers to questions like the distance between two points, even if we restrict the points under consideration to those on the 2-sphere.
Yes. It's important to recognize also that the curve in question is a geodesic of the curved 2-sphere, but it is not a geodesic of the Euclidean 3-space. Considering the implications of that might help @pervect to see what's going on in such cases.PAllen said:the distance along a curve on the 2-sphere embedded in E3 is, in fact required to be that same whether you use the manifold metric or the induced metric on the 2-sphere.
What does "unit" mean in this context?PAllen said:a flat torus of just the right size will smoothly fit in a unit 3-sphere
Radius of curvature = 1Jaime Rudas said:What does "unit" mean in this context?
In what sense the pseudo-sphere isn't "a global embedding – the complete unbounded hyperbolic plane in ##E^3##"? Is it, perhaps, because its "equator" is a "bound" (a singularity)?PAllen said:[...] they state that you can’t smoothly isometrically embed any part of hyperbolic plane in Euclidean 3 space without crinkling or folding, [...] the pseudo-sphere is a trivial refutation of the false claim (the true claim, proved long ago by Hilbert, is about the impossibility of a global embedding – the complete unbounded hyperbolic plane in ##E^3## (Euclidean 3-space)).
No, because its total surface area is finite. It is actually just a small piece of the hyperbolic plane, it just 'looks' big in cartesian coordinates in ##E^3##.Jaime Rudas said:In what sense the pseudo-sphere isn't "a global embedding – the complete unbounded hyperbolic plane in ##E^3##"? Is it, perhaps, because its "equator" is a "bound" (a singularity)?
Ah, yes, now I understand: its area is equal to that of a sphere of the same radius 4πR².PAllen said:No, because its total surface area is finite. It is actually just a small piece of the hyperbolic plane, it just 'looks' big in cartesian coordinates in ##E^3##.
