Euclidean geometry and gravity
  • Level: Undergrad
  • Thread starter raagamuffin
    Euclidean geometry
169 replies · 21K views · last reply
Jaime Rudas said:
Is that "flat plane" two-dimensional or three-dimensional?
Two dimensional
raagamuffin said:
Then I read a reference to 'frame dragging' in rotational black holes. What effect, if any, will that have on the 'paper'?
If the paper is "hovering" statically, i.e., no radial or tangential motion, frame dragging has no effect.
PAllen said:
In the side discussion of embedding a piece of a plane smoothly, isometrically, in a 3-sphere (following is part of a response to @pervect 's last post:
I thought I would make explicit the construction in that reference (which is presented it very compactly in any number of dimensions). Making it explicit for flat 2-surface section in a 3-sphere, the mechanism is simply to use a properly sized flat torus. As explained in:
https://en.wikipedia.org/wiki/Clifford_torus
a flat torus of just the right size will smoothly fit in a unit 3-sphere, both embedded in R4. But then, the embedding can be just ignored, and you are left with a smooth embedding of a piece of Euclidean plane in a 3-sphere.
The formalization and generalization of this is the general approach to embedding ##E^n## into higher dimesnsional spheres used in the reference I quoted earlier. The general achievement is a local embedding of ##E^n## into an m-sphere, with ##m=2n-1##.
Thank you. Untangling this in terms I can more fully understand will be quite a problem. I'm suspecting the issue is fundamental in that I'm viewing curvature as being defined by a metric. Which isn't necessarily how mathematicains view it.
But I think the discussion has moved outside of what's helpful to the OP's question.
More precisely, by the Riemann curvature tensor that's derived from a metric via its Levi-Civita connection. There's no problem with that--that's how the term is being used in this discussion.
But the metric of what? Take the case of a 2-sphere embedded in Euclidean 3-space. The 2-sphere is curved. The 3-space is flat. But one is embedded in the other. How can that be? Taking what you appear to be trying to say at face value, that should be impossible.
The reason it's possible is that the 2-sphere embedded in Euclidean 3-space is a submanifold of that 3-space, and we can define a metric on the submanifold that is curved even though the metric of the 3-space overall is flat. They're simply two different metrics. Note that those metrics give different answers to questions like the distance between two points, even if we restrict the points under consideration to those on the 2-sphere.
What @PAllen has been describing is simply a case where that works in reverse: you have a curved 3-manifold, the 3-sphere, with a submanifold, the Clifford 2-torus, on which a flat metric can be defined. Again, you simply have two different metrics.
When discussing isometric embeddings, there is a little more to it. The metric of the submanifold is taken to be induced from the manifold metric. This means that, e.g. the distance along a curve on the 2-sphere embedded in E3 is, in fact required to be that same whether you use the manifold metric or the induced metric on the 2-sphere. You get to choose manifold, its metric, and the definition of the submanifold embedded in it as a set of points. You do not then get to choose an arbitrary metric on the submanifold - it is taken to be that induced by the manifold metric.
Yes. It's important to recognize also that the curve in question is a geodesic of the curved 2-sphere, but it is not a geodesic of the Euclidean 3-space. Considering the implications of that might help @pervect to see what's going on in such cases.
What does "unit" mean in this context?
(This is an observation, not a complaint. )
As I examine these ideas , every insight I gain spurs more questions about relationships between entities, which (seems like it) can’t be answered by just knowing some facts. I’m realizing that to really make inferences , a good understanding of the math is unavoidable.
(It’s a shame that the universe can’t stick to algebra, some probability and trig 😉)
Thanks for all your explanations, I may just have to consider more rigorous study.
I can’t seem to let this go, partly because some have asked for how to make the embedding result (part of Euclidean plane in 3-sphere) more comprehensible as well as using only intrinsic metric tools. This post will attempt to address both of these goals head on.
I will note, in passing, that these concepts lead to much confusion on the internet. If I ask a couple different AIs these questions, they state that you can’t smoothly isometrically embed any part of hyperbolic plane in Euclidean 3 space without crinkling or folding, nor can you embed any part of a Euclidean plane in a 3-sphere without crinkling or folding. Both of these claims are flat out wrong, but the AIs are only partly to blame – there are a shocking number of superficially reputable websites that make these false claims. I will make no further comment on the hyperbolic plane issue except to note that the pseudo-sphere is a trivial refutation of the false claim (the true claim, proved long ago by Hilbert, is about the impossibility of a global embedding – the complete unbounded hyperbolic plane in ##E^3## (Euclidean 3-space)). The rest of this post will focus on clarifying the case of the Clifford torus in a 3-sphere, which disproves the false statements about embedding part of a Euclidean plane in a 3-sphere.
To start addressing how to make the result more intuitive, consider first, surfaces of revolution in ##E^3## . If you consider any straight line (geodesic) in the xz plane (standard cartesian coordinates) and rotate around the z axis, you get different embeddings of ##E^2## (Euclidean plane) – different from the obvious one. These are cones, inverted cones, or cylinders, all Euclidean flat. Now consider a curve in xz bent away from a straight line with either possible concavity. One of these will produce surfaces of revolution with positive intrinsic curvature, the other with negative intrinsic curvature (and the tractrix will produce a surface with constant negative curvature).
What we will show for the 3-sphere, directly using hyperspherical coordinates and the 3-sphere metric, is that there is a curve in the ##\theta\phi## ‘plane’ (surface of constant ##\psi##) that when rotated by ##\psi## produces a surface with zero curvature – flat intrinsic metric. Of course, it is not a geodesic of the 3-sphere. Relative to this curve, if a curve bends more strongly one direction, you get surfaces of revolution of positive intrinsic curvature, if bending more the other way, you get surfaces of negative intrinsic curvature. Thus, for example, it is possible to smoothly isometrically embed a piece of hyperbolic plane in a 3-sphere, just as in ##E^3##.
Surprisingly, it will be shown that a complete flat torus of just the right size smoothly, isometrically embeds in ##S^3## (3-sphere), even though this is impossible in ##E^3##.
The hyperspherical coordinates form a ‘nearly complete’ chart of a 3-sphere with the following description (the coverage of this chart is sufficient for our purposes, so we need not worry about incompleteness):
$$ds^2=R^2[d\theta^2+\sin^2\theta~d\phi^2+\sin^2\theta\sin^2\phi~d\psi^2]$$
With theta and ##\phi\in(0,\pi)##, ##\theta\in(0,\pi)##,##\psi \in [0,2\pi)##.
Henceforward, we will consider only the unit 3-sphere, with R=1.
Consider a curve in a surface of constant ##\psi## defined by ##\sin^2\theta\sin^2\phi=\frac 1 2##. [This is suggested by looking at the situation from joint embedding in ##E^4##, but now fully divorced from that embedding]. It is easy to verify that within the stated coordinate bounds, this forms a closed curve (sort of a rounded square). We consider the surface revolution formed by taking this curve through all values of ##\psi##. We will demonstrate that the intrinsic geometry of this surface, induced by the spherical metric above, is Euclidean flat. No use of embedding in ##E^4## or any tools beyond the metric will be used. This is, in fact, a complete, smooth, isometric embedding of a flat torus in ##S^3##. Note, that only this one size of flat torus can be completely smoothly embedded.
From the curve definition above, we get by differentiation:
$$\sin^2\phi\cos^2\theta~d\theta^2 = \sin^2\theta\cos^2\phi~d\phi^2$$
Or
$$d\phi^2 = \tan^2\phi\cot^2\theta~d\theta^2$$
From the curve definition, we also have ##\sin^2\phi=\frac 1 {2 \sin^2\theta}##. From these, after some rearrangements we get:
$$d\phi^2 =\frac {\cot^2\theta} {\sin^2\theta-\cos^2\theta} d\theta^2$$
Plugging this into the spherical metric we get
$$ds^2 = d\theta^2 + \frac {\cos^2\theta} {sin^2\theta-\cos^2\theta} d\theta^2 + \sin^2\theta\sin^2\phi~d\psi^2$$
Using the curve definition in the last term, and rearranging we get:
$$ds^2 = \frac {\sin^2\theta} {\sin^2\theta-\cos^2\theta} d\theta^2 + \frac 1 2 d\psi^2$$
This is the intrinsic metric for the torus induced from the spherical metric, using the inherited hyperspherical coordinates on the torus. However, rather than using ##\theta##, it would be better to use a coordinate that is proportional to arclength along the ##\theta\phi## curve. By looking back at the embedding in ##E^4##, a guess can be made to try the following simple coordinate change:
$$\cos\theta=\frac 1 {\sqrt 2 } \cos z$$
We have then, ##\cos^2\theta=\frac 1 2 \cos^2 z##, and ##\sin^2\theta~d\theta^2 = \frac 1 2 \sin^2 z~dz^2##. Plugging this into the prior metric and rearranging gives:
$$ds^2 = \frac 1 2 dz^2 +\frac 1 2 d\psi^2$$
QED. This is the Euclidean flat metric. Recalling that coordinate change can’t change intrinsic geometry, we have demonstrated that the indicated torus surface within the unit 3-sphere is Euclidean flat everywhere.
PAllen said:
[...] they state that you can’t smoothly isometrically embed any part of hyperbolic plane in Euclidean 3 space without crinkling or folding, [...] the pseudo-sphere is a trivial refutation of the false claim (the true claim, proved long ago by Hilbert, is about the impossibility of a global embedding – the complete unbounded hyperbolic plane in ##E^3## (Euclidean 3-space)).
In what sense the pseudo-sphere isn't "a global embedding – the complete unbounded hyperbolic plane in ##E^3##"? Is it, perhaps, because its "equator" is a "bound" (a singularity)?
No, because its total surface area is finite. It is actually just a small piece of the hyperbolic plane, it just 'looks' big in cartesian coordinates in ##E^3##.
Ah, yes, now I understand: its area is equal to that of a sphere of the same radius 4πR².
I returned this to this question earlier this year, and I wanted to add another nuance for your consideration. Let's say that this 'sheet of paper' can be influenced by a magnetic field. If the black hole has a magnetic field (separately, do/should all BHs have a magnetic field?) would a triangle drawn on this sheet of paper be stretched differently? Or are gravitational forces so overwhelming that any magnetic field effects would be negligible?
To follow up, I have been trying to learn the math around BH, to try and develop my own conclusions. Where I started is Einstein’s field equations and am currently meandering through tensor world.
The equations indicate that the curvature of spacetime is dependent on the mass and energy (including EM) in the area of interest (I’m still not sure if that is a point volume or an arbitrary volume).
There are references to the Einstein Maxwell system (still mulling over this), but I didn’t quite grasp what that means for the effect it contributes to the curvature. I also saw solutions around Reissner-Nordstrom , Kerr-Newman etc.
The answer seems to be , it depends on the magnetic field, and I read something about a Schwinger limit which seems to dictate at what scales EM will truly matter.
I think I’m on the right track here.
Although, the math is currently incomprehensible to me, and I blew a couple of fuses trying to decipher it ;) They say patience is a virtue, whether that will translate to actual mathematical understanding remains to be seen :)
Charged rotating black holes can have a magnetic field, yes. We do not expect such fields to be very strong in practice because of the overall electric charge neutrality of the universe - an electrically charged black hole will attract oppositely charged matter and zero out its charge.
However, you can consider strongly charged black holes where the energy of the EM field is a non-negligible source of curvature. Qualitatively, I don't think that it changes anything said in this thread about the triangles you can draw near such black holes; obviously it changes the numerical details.
No, because you can have curvature in vacuum regions. Generally, curvature depends on the distribution of stress-energy throughout the past light cone of the region you are interested in. Or, in the case of black hole spacetimes which are everywhere vacuum, presumably it depends on the presence of singularities.
Yes.
No. An "eternal" black hole, which truly is vacuum everywhere, is not a physically realistic solution; it's an idealized piece of math. The "mass" of the hole is just a parameter in the math--a constant that shows up in the metric. It is not "located" anywhere in particular, certainly not at the singularity.
Any actual black hole, formed by the gravitational collapse of a massive object like a star, will have nonzero stress-energy in the past light cone, and that is what accounts for the spacetime geometry in the vacuum region, just as you say at the start of your post.
One of the early steps, though perhaps not the very first, would be to pick a textbook appropriate to your background. It's encouraging that you know what a tensor is, though. That suggest to me at least an udergraduate college background.
I will put in a plug for "The meaning of Einstein's equations", by Baez and Bunn, as a short readable introduction that does actually let you do a few minor things. The arxiv abstract is at https://arxiv.org/abs/gr-qc/0103044, and you can access the full pdf document from the abstract page. This may give you some small degree of insight with a minimal investment in bacakground knowledge, though it certainly won't give you a complete understaning.
A couple of particular points here:
baez and bunn said:
Before stating Einstein’s equation, we need a little preparation. We assume the
reader is somewhat familiar with special relativity — otherwise general relativity
will be too hard. But there are some big differences between special and general
relativity, which can cause immense confusion if neglected.
In special relativity, we cannot talk about absolute velocities, but only rel-
ative velocities. For example, we cannot sensibly ask if a particle is at rest,
only whether it is at rest relative to another. The reason is that in this theory,
velocities are described as vectors in 4-dimensional spacetime. Switching to a
different inertial coordinate system can change which way these vectors point
relative to our coordinate axes, but not whether two of them point the same
way.
The second paragraph is a bit murky, sorry, though quite worrthwhile if you can unpack it. The part I particularly wanted to focus on is the first part. This is that you NEED to be familiar with special relativity before proceeding onto GR in any meaningful way. Specifically, you should understand special relativity using 4-vectors, which are essentially tensors. (Not quite, you need a few small baby steps, but they are VERY close). I'd suggest in particular Taylor's book "Space-time physics" for the background treatment of special relativity before even attempting General relativity.
Another point: in the appendix, Baez and Bunn argue about how their approach includes all of general relativity. This is only true if you know how to do things like transform the Riemann tensor between different frames of reference. Reading this paper will NOT give you the knoledge needed to do it, so while I find it an extremely useful palce to start, it won't actually teach you everything you need to know. Which, should really go without saying, considering the length of the paper and the size of the topic.
If you get more serious, you'll need to consider a GR textbook choice. Caroll has some online lecture notes (and a published book). Personally, I am rather fond of MTW's textbook "Gravitation. (MTW are the initials of the authors - Misner, Thorne, and Wheeler). You may get other recommendations. I like their informal style, and when I first started studying it I feel that even when I didn't understand everything, I could understand at least part of it, enough to feel like I'd learned something useful. And, perhaps more importantly, at least have some idea of what I didn't understand. Also , I prefer to focus on the more physical insights first, leaving the differential geometry (which you do have to get around to eventually) for later. MTW does that. Caroll starts out with differential geometry, as I recall.
The first part of MTW's book is essentially treating special relativity with tensors, expanding on the foundation laid by Taylor's book "space-time physics" to fuly convert from four-vectors to true tensors.
And there are some less technical introductions like "Exploring Black Holes". If you search past PF posts, you'll find a lot of textbook recommendations for learning General relativity.
If you are not familiar with electromagnetism and Maxwell's equations already, your prognosis is poor. (I suppose you can consider learning about them, if you have the ambition and interest, I wouldn't want to discourage you away from that). If you are familiar with them already, then a logical course of action is to learn how to solve Maxwell's equations using tensor methods. MTW's textbook will help with that, it has a section on it, but you can also find E&M textbooks that do that if you need more.
Onto an overview:
You can break the task of understanding Einstein's field equations down into two main parts - understanding the left half of Einstein's field equations, which are the curavature of space-time, and understanding the right half of Einstein's equation, which is the stress energy tensor.
I like to make a joke that Einstein's field equations are that the left side, which you don't know what it is, is prooportional to the right side, which you also don't know what it is. A general approach is to pick first one side, then the other, and try to master it, then move onto the other. Or, if you multitask, you can do both at once. For narrative focus, it's best to seprate them, however.
Let's take the right hand side first. The energy momentum tensor describes the density of energy and momentum in space-time from ANY source. This includes electromagnetism. What's important is the energy contained in the volume, and momentum.
Baez touches on some of this in the source I recommended earlier, "The Meaning of Einstein's equations", when he talks about the stress energy tensor in terms of flows. The concept of a flow is probably more familiar to mathemticians than physicists, though. It's a sort of continuous transformation.
When we talk about the "density of energy and momentum", the volume element DOES depend on your frame of reference - the orientation of your spatial axes isn't really relevant, but observers moving with different velocites will have a different notion of what their volume element is. This is all accounted for in the tensor maths. The bottom line is that if you have an observer with a 4-velocity u (said 4-velocity being a rank 1 tensor), the density of enery and momentum in the "space" associated with u, which is the part of space-time orthogonal to u, will be given by the contraction of the rank-2 stress energy tensor T, and the 4-velocity u. Tensor transformation rules handle how the stress energy tensor T changes when you change frames of reference/basis vectors.
If you are famliar with tensors, the stress-energy tensor of a swarm of particles can be broken down into the tensor product of the number-flux tensor, and the energy momentum tensor. (I think you have to do some symmeterization of the tensor product too, actually). So if you know what a tensor is, how to take a tensor product, and can also figure out from your knowledge of special relativity what the number-flux tensor is (it's a bit obscure, but wikipedia has an entry on it), and the energy-momentum tensor (which pretty much everyone talks about), you may get some idea of what the right hand side of the equation is, and why people say it represents the "density of energy and momentum". Less mathematically, though, the philsophy is that energy and momentum are closely related in special relativity just as time and space are, and the notion of the density of energy and momentum is what the stress-energy tensor is all about.
The right hand requires understanding the Ricci curvature tensor (which leads to the Einstein curvature tensor), for which you need to understand the Riemann curvature tensor. That's going to be more challenging. And it's the part where you need to get into the differential geometry I mentioned as "skipping over" way back near the beginning of the post.
In general, the standard approach to understanding the Riemann tensor is based on holonomy, which is how vectors rotate when you parallel transport them around a closed curve. Of course, to understand that, you'll need to understand what parallel transport is, which is an early starting point into your venture into the waters of differential geometry.
A less-standard approach is to understanding the Riemann tensor is in terms of geodesic deviation. I haven't seen much on this, though there were a few you tube videos that took this approach.
I will give a link to a youtube video that I found that uses an approach I like using the approach I mentioned, geodesic deviation, to motivate the Riemann tensor. That link is . Warning - this isn't peer reviewed or anything, while I happen to like it it's not a substitute for actual serious study. I'm not quite sure why the author of this video introduced it with fluffy scenes of early airplanes,to be honest.
Note that to understand this video fully, you'll need to understand the geodesic equations, which means understanding geodesics. Which most likely means understanding parallel transport (especially if you want a good foundation, though there are perhaps some shortcuts). But even if youtake all the shortcuts, there is going to be a lot of material to understanding curvature and the left hand side of Einstein's equation fully.
I guess this is the part where I recap. Well, there's too much material to recap, except to say that Baez and Bunn's "The meaning of Einstein" equation is a good place to read a very short introduction to GR. And the rest will have to stand on its own.
pervect,
Thanks ! I appreciate this 'in-depth' overview.
I have done basic undergrad work in physics, mostly to satisfy pre reqs, decades ago. I briefly considered a Math/Physics major (like Planck time briefly ;) ) but I don't think the world would've wanted a lousy (unemployed) physicist. Tensors I've touched upon are multi dimensional arrays in linear algebra.
I will check out the resources and the path that you plotted to see how far I can go. Hopefully quite far, but when I run into trouble, expect some oafish questions here :)
