Algr
- 921
- 438
- TL;DR
- Coaxial plug/socket for line level power with an extra pin for data or DC.
I was reading about someone building a DC house, because this would make solar+battery more efficient. I was wondering what those plugs would look like, but found that there didn't seem to be any standard for DC 120v plugs and sockets. So I thought I'd try to make one, just for kicks:
This is based loosely on the 12v coaxial cable that most AC/DC adapters use. I figured that for 15A it would need to be bigger. It has four pins and so can carry both AC and DC, or 120v and 240v, or maybe AC and data. In the latter case, I'd figured the inner pin would be hot, while starting from the tip would be neutral, data, and ground. That way any foreign object being inserted in the plug would touch ground before anything else.
Those 12v coaxial connectors can rotate in their sockets. I figured that would be bad at 15 amps, so I made it square instead of round. It still inserts four ways. Any thoughts?
