Mathematical definition of a rigid body
  • Thread starter Thread starter wrobel
The discussion revolves around the mathematical definition of a rigid body, focusing on the need for a rigorous formulation suitable for students in a mathematical department studying classical mechanics. Participants explore various definitions and their implications, as well as the relationship between these definitions and established kinematic formulas.
  • One participant proposes a kinematical definition involving functions that describe the motion of points within a rigid body, questioning the mathematical rigor of the term "motion."
  • Another participant suggests that a rigid body can be defined as a set of particles with constant pairwise distances, but notes that this definition allows for reflections, which may not align with the concept of a rigid body.
  • Some participants emphasize the need for at least three non-collinear points to define angular velocity uniquely.
  • A participant mentions the importance of formalizing the definition to derive the Euler formula for rigid body motion.
  • There is a discussion about whether the definition requires functions of class \(C^2\) or if class \(C\) suffices, with one participant arguing for \(C^2\) due to the necessity of considering velocities and accelerations.
  • Concerns are raised about the implications of rigid body collisions on the continuity of motion described by \(C^2\) functions.
Participants express differing views on the definition of a rigid body, with multiple competing definitions and interpretations presented. There is no consensus on a single rigorous definition, and discussions about the implications of these definitions remain unresolved.
Some definitions presented may depend on specific assumptions about the nature of motion and the properties of functions used to describe it. The discussion highlights the complexity of transitioning from definitions to mathematical formulations in mechanics.
wrobel
Insights Author
I am teaching classical mechanics for students from mathematical dept. Students demand mathematically rigor definition of a rigid body. It is strange but I have not found the one in textbooks.
My attempt :smile::
Df. (kinematical version): Take a non-void open set ##D\subset\mathbb{R}^3## and a pair of functions:
$$ \boldsymbol r_A\in C^2\big([0,T],\mathbb{R}^3\big),
\quad U\in C^2\big([0,T],\mathrm{SO}(3)\big),\quad U(0)=E,\quad \boldsymbol r_A(0)\in \overline D.$$
We shall say that a point ##B## belongs to the rigid body if its motion is described by the following position vector
$$\boldsymbol r_B(t)=\boldsymbol r_A(t)+U(t)\big(\boldsymbol r_B(0)-\boldsymbol r_A(0)\big),\quad t\in[0,T], \qquad(*)$$
where the initial value ##\boldsymbol r_B(0)\in\overline D.##
By definition the rigid body consists of such points ##B##.
My attempt :smile::
Doesn't the definition above assume a mathematically rigorous definition of "motion"?
I am afraid I do not understand the question
I would have said that a rigid body is a set of particles whose pairwise distances from each other are constant.
This definition allows for reflection, while rigid body does not.
Reflection is impossible if each particle obeys Newton's laws of motion.
Sure we must just add that this set contains at least three points that do not belong to the same line. Else the angular velocity vector is not defined uniquely.
I usually use the definition you quoted but I do not know a completely formal way to pass from this definition to derivation of the Euler formula:
$$\boldsymbol v_B=\boldsymbol v_A+\boldsymbol\omega\times \boldsymbol{AB}$$
upd: that is why I propose such a version of the definition in the initial post.
Frabjous said:
You could define strain and set it to zero. This will take care of translation and rotation.
Yes, but the main problem is a way from a definition to the Euler formula.
Frabjous said:
1) Choose a point on the body (not space) as the origin.
2) After motion, this point on the body is still the origin. In space, this point has undergone a translation only.
3) Since the body is rigid, every other point on the body can only undergo a rotation about the origin point.
isn't it a verbal description of the formula (*) from the initial post?
I just noted that if we want to have a mathematically consistent theory without gaps filled with physical intuition, we have to formalize properly the definition of a rigid body and there is a formalization that gives apparently the shortest way to the main formula of the rigid body's kinematic.
A rigid body is a system of particles with fixed locations relative to each other.
see #7
see #7
Two particles could define a rigid body.
There will always be special cases that are inconvenient.
I see no reason to restrict the definition based on what you may, or may not, want to define or compute later.
You may later specify that the body have a centre of mass, and a non-zero volume.
ok
but this is not the main question of the thread.
How do you derive formula of #7 from this:
by pure mathematical means?
Just bring this derivation here.
Frabjous said:
Google found this paper
and this paper is irrelevant
Frabjous said:
Sorry I could not be of more help.
do not be sorry I did not ask for help
There is an interesting definition that can help.
A rigid set is a set with the identity function as its only automorphism.
May I have an example?
See the images below.
Both functions are automorphisms.
Now I see what you mean. Then the same question as stated in #14
The definition in #1 includes the phrase,
which is not mathematically rigorous, I think.
A motion of the point ##B## relative to a frame ##Oxyz## is exactly the mapping $$t\mapsto\boldsymbol r_B(t)=x_B(t)\boldsymbol e_x+y_B(t)\boldsymbol e_y+z_B(t)\boldsymbol e_z.$$
Does the definition need ##C^2## functions? Isn't ##C## sufficient?
Hill said:
Does the definition need C2 functions? Isn't C sufficient?
I impose ##C^2## just because it is mechanics and we must consider velocities and accelerations as well.
I see.
What happens when two rigid bodies collide?
I'm truly sorry that you've ignored my question above and I hope you reconsider and reply. Let me elaborate.
I'm asking about two rigid bodies colliding because as I understand their velocities are discontinuous in this case which contradicts their motion being described by the ##C^2## functions.
Is there a reason why your mathematics threads are in General rather than one of the maths SF? They are all very mathsy!
I guess most people wouldn't see them in Math forums.
  • · Replies 0 ·
  • · Replies 0 ·
  • · Replies 0 ·
