Prove that ## 4\tan^{-1}\left[\dfrac{1}{5}\right]- \tan^{-1}\left[\dfrac{1}{239}\right]= \dfrac{π}{4}##
The discussion revolves around proving the equation ## 4\tan^{-1}\left[\dfrac{1}{5}\right]- \tan^{-1}\left[\dfrac{1}{239}\right]= \dfrac{π}{4}##, which involves concepts from trigonometry and inverse tangent functions.
  • Mixed
  • Participants explore various methods to manipulate the tangent and inverse tangent functions, including using identities and substitutions. Some express uncertainty about their approaches, while others question the validity of assumptions made in the proofs.
The discussion includes multiple perspectives on the problem, with some participants providing calculations and others questioning the steps taken. There is no explicit consensus, but several lines of reasoning are being explored, indicating a productive exchange of ideas.
Some participants express confusion regarding the assumptions made in the problem setup, particularly concerning the validity of letting the equation be true without proof. There are also discussions about the complexity of deriving certain tangent identities.
chwala
Prove that,
Trig. identities
I let,
##\tan^{-1}\left[\dfrac{1}{5}\right]- \dfrac{1}{4}\tan^{-1}\left[\dfrac{1}{239}\right]= \dfrac{π}{16}##
Then i let, ##\tan^{-1}\left[\dfrac{1}{5}\right] = α , \tan^{-1}\left[\dfrac{1}{239}\right]=β##
##⇒\tan α=\left[\dfrac{1}{5}\right],\tan β =\left[\dfrac{1}{239}\right], ##
##\tan (α-\dfrac{β}{4})= \left[\dfrac{\dfrac{1}{5}- \dfrac{1}{239×4}}{1+ \dfrac{1}{5}⋅\dfrac{1}{239×4}}\right]##
##\tan (α-\dfrac{β}{4})= \left[\dfrac{951}{4780} × \dfrac{4780}{4781}\right]##
##\tan (α-\dfrac{β}{4})=\left[\dfrac{951}{4781}\right]##
##\tan^{-1}(\tan (α-\dfrac{β}{4})≅11.25^0 = \dfrac{π}{16}##
##4[\tan^{-1}(\tan (α-\dfrac {β}{4})]≅45^0 = \dfrac{π}{4}##
I had a problem dealing with the ##4## in ##4\tan^{-1}\dfrac{1}{5}##... there may be a better approach...
I think of the calculation procedure
[tex]\tan^{-1}\frac{1}{5}-\tan^{-1}\frac{1}{239}=\tan^{-1}A, A=\frac{117}{598}[/tex]
if my math is good. Then
[tex]\tan^{-1}\frac{1}{5}+\tan^{-1}A=\tan^{-1}B[/tex]
[tex]\tan^{-1}\frac{1}{5}+\tan^{-1}B=\tan^{-1}C[/tex]
[tex]\tan^{-1}\frac{1}{5}+\tan^{-1}C=\tan^{-1}D[/tex]
We expect D=1.
[EDIT]
[tex]\tan(2\tan^{-1}\frac{1}{5})=\frac{5}{12}[/tex]
[tex]\tan(4\tan^{-1}\frac{1}{5})=\frac{120}{119}[/tex]
[tex]\tan(4\tan^{-1}\frac{1}{5}-\tan^{-1}\frac{1}{239})=1[/tex]
I'm not sure what you did ...
What I've done:
Prove that: ## 4\tan^{-1}\left[\dfrac{1}{5}\right]- \tan^{-1}\left[\dfrac{1}{239}\right]= \dfrac{π}{4}##
Let:
##\tan^{-1} \frac{1}{5} = S##...................so................... ##tanS=\dfrac{1}{5}##
##\tan^{-1} \frac{1}{239} = T##..............so................... ##tanT=\dfrac{1}{239}##
So
##4S - T = X## (We want to prove that ##X=\dfrac{π}{4}##)
##tan(4S - T)=tanX##
We know that ##tan(4S-T)=\dfrac{tan(4S)-tanT}{1+tan(4S)tanT}##
So we need to find tan(4S):
##tan(4S)=\dfrac{4tanS(1-tan^{2}S)}{1-6tan^{2}S+tan^{4}S}=\dfrac{(4/5)(24/25)}{1-(6/25)+1/625}=\dfrac{120}{119}##
Now we calculate ##tan(4S-T)## :
##tan(4S-T)=\dfrac{(120/119)-(1/239)}{1+(120/119)(1/239)}=\dfrac{ \dfrac{239*120-119}{119*239} }{ \dfrac{119*239+120}{119*239} }##
##=\dfrac{239*120-119}{239*119+120}=\dfrac{239*119+239-119}{239*119+120}=\dfrac{239*119+120}{239*119+120}=1##
We proved that ##tan(4S-T)=1## so we can say that ##4S-T=\dfrac{π}{4}##.
Remember that ##4S-T =4\tan^{-1}\left[\dfrac{1}{5}\right]- \tan^{-1}\left[\dfrac{1}{239}\right]##.
What I've done:
Let:
So
I am not sure on my working. I could be wrong.
How did you find out that ##tan(\dfrac{\beta}{4})=\dfrac{1}{239*4}##?
It's wrong.
It's wrong.
I divided each term by ##4##.
According to you ##\dfrac{tan\beta} {4}=tan\dfrac{\beta} {4} ## but it's not correct.
Fore example :
##\dfrac{1} {4} tan \pi =0##
But ##tan(\dfrac{\pi} {4} )=1 ##
How did you simplify your ##\tan (4S)##? I had tried ##\tan (2S + 2S)## expansion and I noted that it was quite long with the substitutions... Am assuming you used the same approach to realize your rhs.
Try to get tan 2S first. Then you can proceed to tan4S.
That should be easy... I think I had different equations from start... thanks though...
I haven't proved it in the post.
You can google tan4x formula there are plenty of sites which proved the formula. It's not hard.
Did you understand your mistake in post #1?
Yes I did...and I replied in post ##10## that the simplification that I was asking is as easy as abc. I had assumed that it was the same equation that I had in my hard copy book but I just counter checked and realized that my equations were different. Cheers man!
Some comments:
chwala said:
I let,
The first equation above is what you're supposed to prove, so it is generally invalid to assume ("let") a statement you're trying to prove. Only under very specific conditions (*) is it valid to make this sort of assumption.
* Each step is reversible; i.e., by performing a one-to-one operation on each side of the equation or inequality.
This is what you should do first, not assume that the equation you're trying to prove is true.
chwala said:
Relevant Equations:
Trig. identities
Unless you list specific identities you should leave this section blank.
Also, as already mentioned by @MatinSAR ##\dfrac{tan\beta} {4} \ne tan\dfrac{\beta} {4} ##
Mark44 said:
Some comments:
The section you are referring to cannot be left blank. I just tried doing that.
What I've done:
Let:
So
I note that in my proof, i did not have the ##4S## and instead worked with ##S## ... that was wrong. Your working clearly shows that error on my part. Cheers.
chwala said:
Homework Statement: Prove that,
There are four formulas of this kind.
Euler's formula
$$ \arctan\frac12+\arctan\frac13=\frac\pi4 $$
Hermann's formula
$$ 2\arctan\frac12-\arctan\frac17=\frac\pi4 $$
Hutton's or Vega's formula
$$ 2\arctan\frac13+\arctan\frac17=\frac\pi4 $$
Machin's formula
$$ 4\arctan\frac15-\arctan\frac1{239}=\frac\pi4 $$
And all of them can be proved by using the trigonometric identity $$ \tan(\alpha\pm\beta)=\frac{\tan\alpha\pm\tan\beta}{1\mp\tan\alpha\tan\beta} $$ or $$ \arctan x\pm\arctan y=\arctan\frac{x\pm y}{1\mp xy} $$.
Also, they can be proved by using complex numbers. Let us take Herman’s formula as an example.
## \begin{align}
2\arctan\frac12-\arctan\frac17&=\arctan\frac12+\arctan\frac12-\arctan\frac17\nonumber\\
&=\arg(\frac{(2+i)(2+i)}{(7+i)})\nonumber\\
&=\arg((2+i)(2+i)(7-i))\nonumber\\
&=\arg((4+4i-1)(7-i))\nonumber\\
&=\arg(28+28i-7-4i+4+i)\nonumber\\
&=\arg(25+25i)\nonumber\\
&=\frac\pi4\nonumber
\end{align} ##
$$\tan x=\frac{1}{5} \implies \tan2x=\frac{5}{12} \implies \tan4x=\frac{120}{119}$$
$$\tan \left( \tan^{-1} \left( \frac{1}{239} \right)+\frac{\pi}{4}\right)=\frac{1+\frac{1}{239}}{1-\frac{1}{239}}=\frac{120}{119}$$
For an essentially geometric proof (no standard trig' identities used) see this 3 minute (appox.) video.
What I've done:
Let:
So
a different line for ##\tan 4S##
##\tan (4S)= \tan (2S +2S) = \dfrac{\tan 2S + \tan 2S}{1 - \tan^2 (2S)}##
##\tan (2S) = \dfrac{5}{12}##
therefore,
##\tan 4S= \left[ \dfrac{\dfrac{5}{12} + \dfrac{5}{12}}{1-\left[\dfrac{5}{12}\right]^2}\right]##
##\tan 4S= \left[\dfrac{\dfrac{10}{12}}{\dfrac{119}{144}}\right] = \dfrac{10}{12} ×\dfrac{144}{119}= \dfrac{120}{119}##
##\tan (4S-T) =\left[\dfrac{\dfrac{120}{119}-\dfrac{1}{239}}{1+\dfrac{120}{119}×\dfrac{1}{239}}\right] = \dfrac{28561}{28441} × \dfrac{28441}{28561}= 1##
##\tan^{-1} \tan(4S-T) = \tan^{-1} (1)##
##4S-T= \dfrac {π}{4}##
Neat geometric derivation of ##\tan(A+B)=\frac{\tan A + \tan B}{1-\tan A \tan B}## if we divide all terms in ##\frac{ay+bx}{by-ax}## by ##by##.
"All in one" derivation of compound angle formulae - based on the video construction.
  • Wow
Euler's formula
Hermann's formula
Machin's formula
## \begin{align}
\end{align} ##
With complex numbers, it makes it even easier,...
  • · Replies 21 ·
  • · Replies 17 ·
