Small Hopper and Silo Design for Green Coffee
  • Thread starter Thread starter zleb00
The discussion focuses on designing a small square silo for green coffee with a maximum height of 4'-10" and width of 4'. It establishes that hopper wall slopes should be at least 60° to ensure smooth material flow, as slopes around 35° to 40° cause flow issues. Calculations show a total volume of 41,000 cubic inches and a bulk density of 0.0278 lbs/in³, resulting in an estimated weight capacity of approximately 984 lbs after applying a packing factor of 0.85. Reliable hopper design principles and calculations are critical, and resources like BulkInside and ChemEngOnline provide authoritative guidance. Commercial silo designs typically feature a minimum 60° wall slope and a 4" discharge opening for optimal flow of green coffee beans.
  • Bulk density and packing factor calculations for granular materials
  • Dry material hopper design principles and wall slope requirements
  • Volume calculation methods for bins and hoppers in cubic inches and pounds
  • Understanding of flow dynamics in granular storage systems
  • Study hopper design principles at BulkInside: "Ten Steps to an Effective Bin Design"
  • Review ChemEngOnline's "Hopper Design Principles" for flow optimization
  • Research commercial small silo designs with 60° wall slopes and 4" openings
  • Learn advanced volume and weight estimation techniques for irregular hopper shapes
Small business owners designing green coffee storage, mechanical engineers specializing in bulk material handling, fabricators constructing silos, and anyone involved in hopper design and flow optimization for granular agricultural products.
zleb00
Hey all,
I'm trying to design a small silo for green coffee for my small business. That 4'-10" is my max. height and I want it to be around 4' wide.
This silo will be square since that will be a little easier for my fabricator to put together.
How important is it that the walls be approx. 60 degrees? Will my material still flow smoothly if I go down to 35 degrees and get a little bit more green in there?
How can I calculate how much it will actually hold once the material inside starts to mound up? I need it to hold at least 500 Lbs.
I looked into a little bit and the dubious results I found are in the corner for my original conception of the silo with a 40 degree angle and rounded sheets on it before I was told I need it to be at least 60 for it flow smoothly and that it would be better for it to be square . Here are those calculations shown a little bit more clearly. Hopefully I am on the right track.
volume of bin = 29000 cu in
volume of hopper = 12000
total volume = 41000
bulk density of green = 0.0278 lbs/in^3
total weight = 1139.8 lbs of green
TW* PF = 984 lbs
There is more to hopper design than that. Rather than walk through the design calculations, I suggest the two sites listed below. They do a better job of communicating hopper design than anything I would write.
Good search terms to learn more are dry material hopper design. Those search terms found several good sources, the first of which is https://bulkinside.com/news/ten-steps-to-an-effective-bin-design/. Another good source is https://www.chemengonline.com/hopper-design-principles/?printmode=1.
Many others have been through the design and testing process before you. There are commercial products that you could learn from. Expect a minimum wall slope of 60°, with a 4" opening.
If you are not into maths, or have imperfect data, identify the important factors for your hopper application by asking google something like:
Design of small hopper for green coffee beans?
15K
