Designing a Hydro Generator for my Farm
8 replies · 5K views · last reply
drewk79
Over the past few years I have like many of you become interested in renewable energy.
Over the past few months we have gotten a lot of rain.
We also have a small creek in our pasture and it begins with 2-12 inch field tiles. The end (beginning i guess) has been filling with silt over the past 20 years and has now reached the top of the retaining wall so we need to build a new one a few feet taller.
I am thinking why we are down there working it may be a perfect opportunity to set up a small hydro generator.
I can weld and build basically anything ( I am a home builder) and my brother is a commercial electrician so I think we have the know how. I am just looking for some engineering and design help/suggestions.
OK so while I was down there the other day the 2-12 inch tile were running at what seemed to be full capacity. Maybe 60% full I would think that would be about 1 gal per sec per tile. If anyone has any opinions on that I am guestimating.
It is probably running 20%-30% higher than avg right now. Water weighs about 8 lbs per gallon. So ... I think i can reasonably get to 10 lbs a second avg. And it falls about 1 ft initially out of the tile. We have nice concrete walls on 3 sides and a concrete floor for about 10 ft. I will be adding a illustration soon.
OK I have done some more research and found I have 2-12 inch tile and they can flow 2 cubic ft per sec each. I think avg is probably 1/4 of that. appx 60 lbs per cubic ft. So avg work done is 30lbs drops 1 ft per sec on avg.
30 x 60sec = 1800 lbs 1 ft per minute
550 ft lbs a min = 1 hp
So i have a little over 3 hp
750 watts per hp x 3 = 2250 watts
2250 x 24 hrs a day= 54kWh
Any comments on these assumptions would be great.
Thanks
You're so close to having figured it out yourself (maybe you have, but you put ? in there...). Power is in foot-lb/min and you have information in units of feet, lb, and min. Put them together!
If I'm understanding you correctly, you only have a 1 foot drop to work with? anyway, potential energy is simply weight times height and power is flow rate times height. So if you have 60 lb/min dropping 1 foot, you have 60 ft-lb/min of energy at your disposal. That is about 1/10th hp, or 70 watts.
1 ft of drop seems awfully small, but if that's what it is, ok. Flow rate is pretty easy to find, though, if your water source is coherent: find yourself a 5 gal bucket, direct the water flow into it and measure how long it takes to fill it.
So 2 minutes of research made me redo my assumptions.
As far as the 1 ft of work that is about how far the tile are from the concrete floor. maybe 18 inches but its under water so its hard to see and remember from yesterday.
I did edit my first post so if you could reread it with the new assumptions and let me know what you think so far
Amateur hour again... I don't really know anything about the subject. I am wondering, however, if you could dig the receiving basin a couple of feet deeper to gain more gravitational assistance from the falling water.
Are you calling me an amateur? I know I am. But I am trying to learn and I find this site very helpful. Should I just keep my comments to myself or...
If you were talking about yourself being an amateur I enjoy all points of view.
I have found a micro hydro calculator and I according to it 100 kWh a month are possible in the wetter months. Also since I am at the beginning of the creek I have a perfect opportunity to harness this energy for a very low initial cost.
So far I am imagining a 6 ft radius water wheel a pulley and shaft up to dry land. At that point I could have a mounting plate for 3 generators (or one big one) They could be connected and disconnected very easily.
100 kWh is about the entire farm monthly use. So maybe just a 2-3 year return on investment.
Thank you I had not thought about wiki
I went to the creek again this morning. I was expecting some rain according to the radar but nothing and I am trying to decide how tall to make the new dam for overflow water.
The tiles though where in fact still flowing I would say 80% max. So I think it will be easy to take another piece of 12 in tile and build a small model in the garage and then simply side it into place once completed.
I will keep you updated.
That is indeed the case; I hoped that you would understand that. :smile:
I feel pretty intelligent when I talk to friends and peers but I get a bit intimidated on when I put some ideas out there for others to see.
In reference to the generator I have found there is a small dam about 100 yards doinw the creek. I can lower the water by removing it. This will get me to about 3 ft of head.
Also I have found water wheels are not easily adapted to electric generation so I am looking at a kaplan style turbine.
