PF Style 2026
  • Context: Announcement
  • Thread starter Thread starter Greg Bernhardt
269 replies · 16K views
PF style 2026 has been released. It's a warmer, more modern and academic theme. Please thread in your feedback and suggestions. I'll be making numerous tweaks over the coming weeks. We have a dark style to try out. If you select system in the mode selector it will sync with your system settings for dark/light. If you prefer the old style, you are welcome to continue using it till the end of the year by using the style selector at the bottom left of the footer. I've been enjoying using the new style over the past week. I hope you do too!
Reply
Does the new style meet the ADA requirements for accessibility?
Reply
I targeted WCAG 2.1 AA and it should be mostly compliant. If you see something you suspect isn't, let me know.
Reply
Excellent, that is a tough set of criteria.
Reply
It's fine. A bit prettier than the old style and, of course, I thought I had wandered into the wrong place when I first saw it. It has an open, optimistic quality; well done.
Reply
  • Haha
  • Agree
I think it's fine. And about time. Very modern.
Funnily, first I thought I'd arrived at some site which used a domain name close to yours. Took me a couple of tries to understand I was at the right place. Good job.
EDIT: And a new font too. Is this a michieveous attempt to introduce it everywhere? :smile:
Reply
  • Agree
After I get used to what's where and what's new, I think know I'll like it.
Reply
I suspect it's basically still the old site. They just edited the stylesheet! :woot:
EDIT: Oh, and the front page.
Reply
Yep, mostly a new slap of paint
Reply
  • Haha
The font seems significantly smaller to these old eyes. Did it get smaller, or am I just imagining things?
Reply
It may not be smaller but a tighter font with less frills kind of like the difference between Courier and Arial with variable width.
Reply
jedishrfu said:
Wow you even have citations. Are there plans to connect to Zotero?
I don't know about Zotero. Is this a popular tool? Do you use it?
Some area may be technically smaller and tighter. Still accessibility compliant. After a couple weeks I can adjust if we're still feeling like areas are too small. Post content font should be the same if not larger.
I wonder if this will fix that issue I had a few weeks ago where I needed to reload several times before I got everything. PF is the only site that I have this issue with.
Reply
Zotero is a citation tracker that grad students are encouraged to use. It's either an app or plug-in that captures a citation.
It's great for when you need citations for papers you're writing. It keeps them in one place and can generate different citation styles.
I use it to track references I've found for my CS graduate project.
Reply
Ugh! Not a fan of the forest green and earth tones. Also, the font used for "Today, 7:31 AM" in light gray, maybe Courier, is hard on the eyes.
Disagree that it looks modern. More like early 1970s or retro sci-fi.
Reply
Jetbrains Mono
Unfortunately this font is very hard for me to read when surrounded by the other fonts. (I think monospace fonts in general are a bad choice except for very specific applications, like terminal windows or displaying and editing source code, where exactly lining up characters in columns is important.)
Also, I see way too much variation in font size. The font size for displaying ordinary text in individual posts looks OK to me. But all the other font sizes are too small. When I read a post in a thread, the name of the poster is hard to read because it's such a small font compared to the post itself. The same is true for text inside quotes.
Reply
Looks great. Good job!
Reply
  • Love
Definitely an impact. It will take me some time to adjust, but we're humans. Life without change would be dull.
Reply
Same here - the font seems a lot harder to read.
Reply
I bumped quote text, postbit username, and annotations. I'll continue to hone.
Reply
One other comment: it's hard for me to tell now which forums have unread posts. In the old style, there was a color change that made it easy to spot. Now it seems like there's just a weight change that is not at all obvious.
Reply
  • Agree
Well OK. Honest opinion. I may be too hardened from reading the weird font on my own site.
Same comment about individual threads in a forum view: it's hard for me to tell which ones are unread now.
Reply
The status icons on the left are still the primary unread device unless you are meaning something else?
Something about the new style makes it much less readable. I don't know if it's the font? Do we have any control over these things? So far I don't like the change.
Reply
Well, no. I am not able to find the grid of the various sections. It used to be that when you clicked on "Physics Forums" at the upper left, it would take you to the grid that showed all the sections.
Edit: OK, now I've found it. You need to scroll down toward the bottom of the opening page.
Reply
