How does a cloud chamber respond to 2-slit interference?
  • Level: Undergrad
  • Thread starter Thread starter renormalize
  • Featured
16 replies · 3K views
TL;DR
Using a cloud chamber in a quantum 2-slit experiment gives linear tracks of uniform length that overwhelmingly point back to halfway between the slits (but with a very few outliers) and a track density that exhibits the familiar interference pattern.
The Motivation
Spurred by some interesting back and forth with @PeterDonis in a recent forum thread, I present here my attempt to answer the titular question. I begin with the Schrödinger equation for the wave function ##\psi## of a free charged particle of mass ##m##:$$i\hbar\frac{\partial\psi}{\partial t}=-\frac{\hbar^{2}}{2m}\nabla^{2}\psi\tag{1}$$and define the probability density ##\rho## and the probability-current/flux density ##\vec{J}## in the usual ways:$$\rho\equiv\psi^{\ast}\psi\, ,\;\vec{J}\equiv-\frac{i\hbar}{2m}\left(\psi^{\ast}\nabla\psi-\psi\nabla\psi^{\ast}\right)=\frac{\hbar}{m}\text{Im}\left(\psi^{\ast}\nabla\psi\right)\tag{2a,b}$$The scalar density ##\rho## is of course responsible for the familiar interference-pattern on the target screen of the standard 2-slit configuration. But if that target is switched to a cloud chamber, vector information is required to predict the directions of the tracks therein, and that information resides in ##\vec{J}##. Recall that the differential cross section for single quantum scattering is defined in terms of probability fluxes to be ##d\sigma\left(\theta,\phi\right)/d\Omega=r^{2}\Vert\vec{J}_{\text{scat}}\Vert/\Vert\vec{J}_{\text{in}}\Vert## where ##\vec{J_{\text{in}}}## is the incident flux (see, e.g., Ballentine, Quantum Mechanics: A Modern Development, §16.1). Two common examples of incident fluxes are (proportional to): 1) ##\left(\hbar k/m\right)\hat{z}\,## for an incoming particle-beam plane wave that impacts a target in an accelerator experiment and 2) ##\left(\hbar k/mr^{2}\right)\hat{r}## gives the outgoing spherical wave centered on an alpha-emitter in the Mott analysis of cloud chamber tracks. But these two examples are in no way exhaustive: any ##\vec{J}##-field can serve as an incident flux, including that arising from a 2-slit interferometer bombarding a cloud chamber. As first demonstrated by Mott, if the incident charged particle is sufficiently energetic and interacts only weakly and inelastically with the vapor molecules in the chamber, the resulting ##d\sigma/d\Omega## will be sharply peaked in the forward direction ##\vec{J}_{\text{in}}/\Vert\vec{J}_{\text{in}}\Vert## at the first scattering and then again at each subsequent scattering, until the particle energy is expended, leaving behind a linear trail of ionized vapor having a characteristic length (see Multiple scattering of charged particles by N atoms, §V). Since this "stopping-distance" is governed by the particle's incoming energy, a monoenergetic flux of such particles yields a spatial-distribution of tracks with identical lengths.
Explaining the tracks in a 2-slit interferometer/cloud-chamber system is therefore grounded in the following three principles:
  • The density of tracks is proportional to ##\Vert\vec{J}_{\text{in}}\Vert##.
  • The direction of tracks is given by the unit-vector ##\hat{J}_{\text{in}}\equiv\vec{J}_{\text{in}}/\Vert\vec{J}_{\text{in}}\Vert##.
  • The lengths of tracks are all identical for a monoenergetic flux.
The Wave Function
With this preamble out of the way, it's time to "just shut up and calculate" the flux ##\vec{J}\,## incident on a cloud chamber from 2 slits. Given the following (idealized) configuration:
the physical solution of eq.(1) is expressed in terms of the Hankel function ##H_{0}^{\left(1\right)}##:$$\psi\left(x,y,t\right)=Ne^{-2\pi i\nu t}\left(H_{0}^{\left(1\right)}\left(2\pi L_{+}/\lambda\right)+H_{0}^{\left(1\right)}\left(2\pi L_{-}/\lambda\right)\right)\tag{3}$$where ##N## is an arbitrary normalization constant. This solution is singled out because the two terms in (3) embody the required outgoing cylindrical waves, each propagating away from the ##z##-directed line-sources located at ##\left(\mp d/2,0\right)##, that ultimately impinge on the cloud chamber. (I use line-sources to avoid the inessential complication of finite slit-widths.) Since ##N## is arbitrary, I choose it to set the normalized wave function ##\psi_N## to unity "on-axis" at the entrance to the chamber; i.e., ##\psi_N\left(0,D\right)=1##. I can also drop the time-harmonic term ##e^{-2\pi i\nu t}## since it disappears from ##\rho## and ##\vec{J}##. Here is the resulting wave function:$$\psi_{N}\left(x,y\right)=\frac{H_{0}^{\left(1\right)}\left(\pi\sqrt{\left(d+2x\right)^{2}+4y^{2}}/\lambda\right)+H_{0}^{\left(1\right)}\left(\pi\sqrt{\left(d-2x\right)^{2}+4y^{2}}/\lambda\right)}{2H_{0}^{\left(1\right)}\left(\pi\sqrt{d^{2}+4D^{2}}/\lambda\right)}\tag{4}$$along with its gradient:$$\begin{align}&\nabla\psi_{N}\left(x,y\right) =\nonumber \\ & -\frac{\pi}{\lambda}\left(\frac{\left(d+2x\right)H_{1}^{\left(1\right)}\left(\pi\sqrt{\left(d+2x\right)^{2}+4y^{2}}/\lambda\right)}{H_{0}^{\left(1\right)}\left(\pi\sqrt{d^{2}+4D^{2}}/\lambda\right)\sqrt{\left(d+2x\right)^{2}+4y^{2}}}-\frac{\left(d-2x\right)H_{1}^{\left(1\right)}\left(\pi\sqrt{\left(d-2x\right)^{2}+4y^{2}}/\lambda\right)}{H_{0}^{\left(1\right)}\left(\pi\sqrt{d^{2}+4D^{2}}/\lambda\right)\sqrt{\left(d-2x\right)^{2}+4y^{2}}}\right)\hat{x} \nonumber \\ & -\frac{2\pi}{\lambda}\left(\frac{y\,H_{1}^{\left(1\right)}\left(\pi\sqrt{\left(d+2x\right)^{2}+4y^{2}}/\lambda\right)}{H_{0}^{\left(1\right)}\left(\pi\sqrt{d^{2}+4D^{2}}/\lambda\right)\sqrt{\left(d+2x\right)^{2}+4y^{2}}}+\frac{y\,H_{1}^{\left(1\right)}\left(\pi\sqrt{\left(d-2x\right)^{2}+4y^{2}}/\lambda\right)}{H_{0}^{\left(1\right)}\left(\pi\sqrt{d^{2}+4D^{2}}/\lambda\right)\sqrt{\left(d-2x\right)^{2}+4y^{2}}}\right)\hat{y} \nonumber \tag{5}\end{align}$$Equations (4) and (5) are the ingredients I add to (2a,b) to create the density fields ##\rho\left(x,y\right),\vec{J}\left(x,y\right)##, but I won't burden the reader by explicitly displaying their cumbersome analytical forms. It suffices to simply let my Mathematica software deal with the algebra and focus on visualizing the results.
To illustrate, I select the parameters ##d=5\lambda,D=40\lambda## and define the dimensionless relative-flux ##\vec{J}_{R}\left(x,y\right)\equiv\vec{J}\left(x,y\right)/\Vert\vec{J}\left(0,40\lambda\right)\Vert##, calculate the probability density and flux values, and then plot those in a few different ways.
The Probability and Flux Densities
Plot [1] clearly exhibits the interference bands in ##\rho_N## characteristic of the 2-slit configuration, as well as the size and direction of the outflowing probability-flux vectors ##\vec{J_R}##. Note that those vectors (mostly) follow the interference bands and are longer at the blue-white peaks and shorter near the pure-blue valleys of ##\rho_N##. Indeed, plot [2] shows the distributions of ##\rho_N## and ##\Vert\vec{J_R}\Vert## to be virtually identical at the entrance to the cloud chamber, where they differ at most by a few parts in ##10^{-4}##, implying that the track-density in the chamber displays the same band structure as the spot-density on the target of the standard 2-slit experiment.
The Flux Direction
Beyond the "near-field" region in plot [1], the flux vectors primarily follow flow lines that more or less point back toward the origin, half-way between the slits. But on close inspection, it's also evident that a few short vectors in the nulls of ##\rho_N## are clearly non-parallel to the overall flow direction; moreover, some of the flow lines apparently "swerve" through a null before resuming their original direction. To investigate this "non-radial" behavior, I use the unit-vector ##\hat{r}\equiv\left(x\hat{x}+y\hat{y}\right)/\sqrt{x^{2}+y^{2}}## to decompose the total flux vector into radial (r) and non-radial (nr) components:$$\vec{J}_{R\left(\text{r}\right)}=\left(\hat{r}\cdot\vec{J}_{R}\right)\hat{r}\;,\quad\vec{J}_{R\left(\text{nr}\right)}=\vec{J}_{R}-\left(\hat{r}\cdot\vec{J}_{R}\right)\hat{r}\tag{6a,b}$$from which it follows that the magnitude of the non-radial flux density at any point is:$$\Vert\vec{J}_{R\left(\text{nr}\right)}\left(x,y\right)\Vert=\Vert\vec{J}_{R}\left(x,y\right)\Vert\sqrt{1-\left(\hat{r}\left(x,y\right)\cdot\hat{J}_{R}\left(x,y\right)\right)^{2}}\tag{7}$$and the angle of deviation of the non-radial flux density from the radial "boresight" direction is:$$\delta_{\left(\text{nr}\right)}\left(x,y\right)=\cos^{-1}\left(\hat{r}\left(x,y\right)\cdot\hat{J}_{R}\left(x,y\right)\right)\tag{8}$$Below are plots of these two quantities evaluated at the entrance to the cloud chamber:
Observe in plot [3] that the non-radial flux density is everywhere merely a tiny fraction of the total flux density. This minuteness is reflected in the expectation value of the total non-radial flux:$$\left\langle \Vert\vec{J}_{R\left(\text{nr}\right)}\Vert\right\rangle =\frac{\intop_{-20\lambda}^{20\lambda}dx\,\Vert\vec{J}_{R}\left(x,40\lambda\right)\Vert\sqrt{1-\left(\hat{r}\left(x,40\lambda\right)\cdot\hat{J}_{R}\left(x,40\lambda\right)\right)^{2}}}{\intop_{-20\lambda}^{20\lambda}dx\,\Vert\vec{J}_{R}\left(x,40\lambda\right)\Vert}=0.00151\approx\frac{1}{661}\tag{9}$$So out of every ##661## chamber tracks, all but ##1## are expected to point directly back to the center between the slits. And just how misaligned is that one exceptional track apt to be? Per plot [4], the deviation angle ##\delta_\text{(nr)}## can be as high as ##87°##, but that's only in narrow bands at the minima of ##\rho_N## where the probability of finding the particle is very low. Elsewhere, the deviation is essentially zero. In fact, the overall expected value of the deviation is just:$$\left\langle \delta_{\left(\text{nr}\right)}\right\rangle =\frac{\intop_{-20\lambda}^{20\lambda}dx\,\Vert\vec{J}_{R}\left(x,40\lambda\right)\Vert\cos^{-1}\left(\hat{r}\left(x,40\lambda\right)\cdot\hat{J}_{R}\left(x,40\lambda\right)\right)}{\intop_{-20\lambda}^{20\lambda}dx\,\Vert\vec{J}_{R}\left(x,40\lambda\right)\Vert}=0.0869°\tag{10}$$ Non-radial tracks are therefore fairly rare and most often only very-slightly misaligned. But that's not to say that tracks with larger deviations don't occur with lower probabilities. For example, the probability ##P\left(\delta_{\left(\text{nr}\right)}\geq5{^\circ}\right)## is ##2.78\times 10^{-5}##; i.e., the observed deviation angle equals or exceeds ##5{^\circ}## about once in every ##36,000## tracks.
The Flux Streamlines
A more refined view of the current flow is available by plotting the streamlines (integral curves) of the ##\vec{J_R}##-vector field:
It's evident in [5a] that the current streamlines bend as they pass near to and cross through a null "valley" of the probability density ##\rho_N##, and then resume their radial path on the opposite side of that valley. This is especially clear in the magnified view [5b] where I explicitly demark the minimum of ##\rho_N## by the deep-blue line. I conclude that the direction of the streamline tangent-vector ##\hat{J}_R## swings dramatically during these crossing transitions, and whenever such a swing occurs near the entrance to the cloud chamber, the resulting track will be non-radial.
(Historical aside: Images akin to plot [5a] are often seen in discussions of Bohm's pilot-wave interpretation of quantum mechanics (https://en.wikipedia.org/wiki/De_Broglie–Bohm_theory) wherein the streamlines of current flux are understood to be the actual trajectories of the particles as they travel away from their source, toward and then into the cloud chamber.)
The Wrap-Up
Below is a schematic representation of the cloud chamber tracks, their bands of varying density, and the locations from which they appear to originate:
I draw these final conclusions:
  • All the chamber tracks have the same length (by virtue of the particles being monoenergetic).
  • The track density varies in exact accordance with the standard 2-slit interference pattern.
  • The tracks overwhelmingly backtrack to an origin point centered between the slits.
  • But there are occasional tracks that emerge, with low probability, from near the interference nulls at angles that point back to "off-center" locations, sometimes markedly so.
Any enthusiastic experimentalists out there who feel up to the challenge of observing these rare, askew tracks that are triggered by bombardment from a matter interferometer? :wink:
The figure you posted reminds me of the first figure I generated when I considered two point sources placed immediately after the slits. I later realized that, in that model, the intensity was effectively the same in all directions and did not decrease with angle.
I therefore made a variant that took this angular dependence into account, although admittedly only in an approximate way.
In any case, this is impressive work. I think the tracks themselves look right; the only thing that may need some adjustment is their intensity, which should decrease as one moves away from the central direction, due to the angular spreading of the outgoing flux.
True, but that's hard to show graphically since the lines all have constant length. In the last figure I attempt to show track-density by placing the intensity pattern behind the red lines. Perhaps the interference pattern could be shown instead by plotting the lines using varying colors or transparencies.
renormalize said:
TL;DR: Using a cloud chamber in a quantum 2-slit experiment gives linear tracks of uniform length that overwhelmingly point back to halfway between the slits (but with a very few outliers) and a track density that exhibits the familiar interference pattern.
Very interesting observation.
Does width of the slits, which affects Py uncertainty, affect on it ?
I think finite-width slits in a matter interferometer have the same effect as in optical interference. The broader single-slit diffraction pattern modulates the 2-slit pattern and removes the higher-order interference bands. But enough nulls still remain to bend the flux streamlines and so "over tilt" some of the tracks in the cloud chamber, just as I show above.
(https://pressbooks.online.ucf.edu/osuniversityphysics3/chapter/double-slit-diffraction/)
An interesting variant of this experiment to consider: what if there is no vacuum region behind the slits? That is, the cloud chamber begins right at the barrier with the slits in it?
If the slits are flush with the chamber entrance, the particles immediately enter the decohering environment of the vapor-filled chamber. I'm no expert on decoherence, but my guess is that this randomizes the relative phases of the slits and eliminates any possibility of developing interference between them. So you'd just observe two sets of tracks, each set originating from a particular slit, but with none of the 2-slit bands of varying track density. But for finite-width slits, I think that two superposed single-slit diffraction patterns would likely still appear.
Is this supported by textbook QM?
For photons, adding smoke would provide an interesting optical analogue: scattering could make the spatial energy-flow pattern visible in 3D, with the local direction determined by the Poynting vector. This would be analogous to visualizing the beamforming pattern of the two-slit field rather than merely observing the final interference pattern on a screen.
P.S.: I've found this link: https://physics.stackexchange.com/questions/233666/will-smoke-affect-youngs-double-slit-experiment
So the basic idea of using smoke to visualize the light between the slits and the screen is not new.
Yes it's supported, but only implicitly in the QM textbooks of which I'm aware. Consider, for example, this excerpt from chap. 5 of Quantum Mechanics (2nd ed.) by R. Shankar:
Now suppose that the mentioned "particle detector" is specifically a cloud chamber. Then to "trigger" means "a linear track is formed", and said linear track defines a particular vector direction ##\mathbf{u}##. To be consistent with the "probability flows" mentioned above, that direction-vector must be ##\mathbf{u}=\mathbf{j}/\Vert\mathbf{j}\Vert##. After all, that's the same way it works for all the other conserved current-densities we deal with in physics: electric, fluid, etc.
Why? Couldn't an ensemble of tracks reproduce probability current direction without each track individually adhering to that direction? E.g. an ensemble of tracks pointing in two opposite directions could produce j = 0.
What you're talking about sounds more like Bohmian mechanics.
For the monochromatic case,
\mathbf{J} \propto \frac{\mathbf{S}}{\hbar\omega},
so ## \mathbf{J} ## and ## \mathbf{S} ## are collinear. The factor ## 1/(\hbar\omega) ## only rescales the magnitude and does not affect the direction.
It therefore seems plausible that the probability current remains collinear with the local Poynting vector even for a general frequency mixture.
Fair point.
The standing-wave case may actually be an example of what you describe. One can have
\mathbf{J}=0,
while the field is naturally interpreted as a superposition of two counter-propagating components. Likewise, the time-averaged Poynting vector vanishes,
\langle \mathbf{S} \rangle = 0,
because opposite contributions cancel.
In that case, the probability current seems to lose information about the underlying counter-propagating components, whereas the electromagnetic field (and the corresponding Poynting-vector description) still retains it.
I think that's inconsistent with Mott scattering. At the first encounter of the charged particle with a vapor molecule something has to define the forward-direction of that first scattering. What is that something if not the direction of the probability flux?
But is that a problem? Doesn't the Bohmian interpretation make the exact same physical predictions as Copenhagen?
The issue is it is introduced as a principle. An argument that justifies it via Mott scattering would be an interesting discussion.
I am not an expert in Bohmian mechanics but my understanding is the Bohmian trajectories inferred from j are unobserved, distinct from perturbed, observable cloud chamber tracks.
