Today I Learned
  • Thread starter Thread starter Greg Bernhardt
6,981 replies · 623K views
DaveC426913 said:
Neither that post nor that thread seems to exist in any form I can find.
They did when I quoted from them. Admin actions? I will try to look according to my level.
ok, #63 by Bandersnatch, in the topic Basic Skills that kids are lacking. He mentioned "long in the tooth".
Again: I don't find any such thread, nevermind post. Nor does a search return any results.
Did my forum membership expire?? :eek:
TIL: there are sections of the forum I have no access to and are apparently invisible to me. Like "dark PF"?
Let me try to post just 1 link.
There, the member mentioning being 'long in the tooth'.
symbolipoint said:
I'm tellin' ya...
I can't think of anything else. I went to the actual posting, used the link tool to copy and paste. The only other thing I can imagine is to go to that post again myself and use snipping tool to take an image and then put this image into a post here.
Main point was someone in another topic made a comment using "long in the tooth" and I learned what that expression meant, and then I made a literal interpretation to give dental care advice.
DaveC426913
Now I believe I know what's going on. If I had thought about permissions and who has which category on the forum I might have said things differently. Are you permitted to view the subforum, Advisors' Lounge?
That is the issue. It's limited to Advisors, Homework Helpers and Mentors.
My fault for not thinking thoroughly enough and taking as granted my ability to read and post there.
Not today I learned, but today I was reminded of something. If you knock out the upper right segment of a seven-segment digit display then 5 and 9 are indistinguishable, as are 6 and 8. The reason I noticed this is that our microwave timer has a slightly italicised seven segment counter slightly recessed into the front panel, and from some angles that one segment is hidden for the last digit. The upshot of this is that as it counts down 9, 8, 7, 6, 5, it's indistinguishable from counting up 5, 6, 7, 8, 9. So every so often I look at the timer at just the wrong moment and panic that it's counting up before I remember I know the illusion.
  • Wow
Yes those damned digital displays are trouble. We need analog displays with "hands" or pointers that turn.
Well, only us old-timers (get it?) can read those confounded analog clocks anyway...
This was (is?) a significant human factors design issue with aircraft cockpit displays. In older or cheaper aircraft the gauges were (are) designed so that if the needle was in the middle (usually up) everything was sort of, mostly, OK. But if you saw a needle off to the left or right, it attracted more focused attention. This enabled a quick scan of many gauges without much detailed thought. It doesn't work so well for a display of digits.
If you have the money, you can design Airbus style systems that will tell you the answer with text. Like "Master Caution! ITT temperature high in engine #2", or such. Gauge scan isn't required, at least at first. But nobody just gives you a list of numbers like a spreadsheet, that's to hard to understand.
Anyway, you shouldn't design this stuff piecemeal. The human brain is an important part of the process. Many engineers don't understand that.
TIL that Flotsam and Jetsam were not only not what I thought they were, but there are two other types:
I think I'll have to hang up my sailor badge for being so daft.
TIL about an analog technique to create amazing fractal-like images. A camera looking at a monitor that is driven from the camera, while you tweak the hue, saturation, brightness, contrast etc.
TIL a new phrase - meat proxy.
A meat proxy is a person who copies and pastes AI-generated text, code, or answers and forwards them to others without reading, checking, or understanding them.
  • Haha
I had someone do that on a tiny subject in which I'm an expert. It gave me a poor impression of AI.
