Randomness in quantum mechanics
  • Level: High School
  • Thread starter Thread starter gen x
20 replies · 2K views
gen x
What quantum physics(randomness) tells about our reality?
everything is random, there is no cause-effect world?
The probability distribution still has causes and effects.
That there appears to be some inevitable stochasticity in the world.
QFT respects the causal structure of relativity, so has clear chains of cause and effect.
It is not deterministic, if that's what you mean. You can only predict future probabilities, not exact paths. The randomness averages out over many particles, which is why the large scale world appears deterministic.
What is mechanism for randomness?
Determinism is emergent property of random processes?
We dont know what each particle do, how path of one single electron around nucleus looks?
What would it mean for something to be a mechanism for randomness?
Yes.
What does this question mean?
We don't have an answer for that. It's built in to our most fundamental theory. I don't think it's even clear that the question makes sense.
Essentially, yes.
I don't think an electron has a path around the nucleus. It has a probability distribution of being found in different places.
Essentially, yes.
I don't think an electron has a path around the nucleus. It has a probability distribution 9f being found in different places.
Nothing make sense if you go deep enough. But I hope for few hundreds/thousands years things will become more clear.
Some physical laws that governing each particle behaviour
Or if you ask vague enough questions without putting in any effort to actually learn the material.
"A mechanism for randomness [would be] some physical laws that govern[ing] each particle behavior"? What do you mean by this?
gen x said:
Can we prove with experiment that electron is that position as math model predict?
If yes, how?
The math model predicts a probability for a measurement result.
How measurement is done?
If yes, how?
Sure. The easiest is with a phosphor screen or a cloud chamber.
I believe randomness is emergent property of determinism.
Entanglement works by different rules than other interactions so in combination the they produce unpredictable events while at global level everything is still balanced.
No
  • Skeptical
If yes, how?
Here is a nice demonstration of electron diffraction:
How to demonstrate electron diffraction in the classroom (National STEM Centre)
Could be…. And if so would be aesthetically satisfying for many, it’s a major impetus behind consideration of hidden variable theories. But in the absence of a candididate theory there’s no way of knowing.
PeterDonis said:
How so?
I would say that the answer is bound to be highly subjective for such a general question. I guess for me it's more interesting to ponder how randomness could emerge from extremely deterministic deeper reality as an interplay between interactions that strongly depend on distance and entanglement that does not(weakly?) depend on distance (for me it's obvious entanglement should be physical interaction).
On the other side determinism could emerge from fundamental chaos by some generalized law of natural selection. But this is too philosophical and far from topic of this forum ... and even trivial.
On the contrary, there is a well known simple answer for how randomness emerges from determinism: through ignorance of exact initial conditions.
However, that doesn't seem to be what you were referring to. I wouldn't describe your points as subjective so much as vague.
