Getting to the Heart of Entanglement and Locality in Plain English
  • Level: Undergrad
  • Thread starter Thread starter jeffn1
38 replies · 6K views
jeffn1
I understand two particles can be entangled even though they are many millions of miles away.
I understand a simple example of this is a "quantum singlet state":
Singlet State: This is the precise quantum state where two entangled particles have a total spin of zero. Because the total spin must balance out, measuring one particle as spin-up means the other must instantly be spin-down.
I understand that if we measure/disturb/observe one of the entangled particles, we know that the other entangled particle will have the opposite spin.
I understand that, if we do this with one particle, nothing will apparently happen to the other particle. However, when the other particle is measured, it will confirm the opposite spin.
Making this even more interesting, I believe that if we measure/disturb/observe the local particle and then measure/disturb/observe the nonlocal particle, it will confirm the opposite spin, even though, if something were transmitted from the local particle to the nonlocal particle, it could not have reached the nonlocal particle based on the speed of light.
I also understand none of this can be used for faster-than-speed of light communication for reasons that have been discussed in this forum and elsewhere.
I can see two types of explanations:
1. The entangled particles would have always had these two spins when measured. So, when we measure/disturb/detect one of the particle, it is revealing the spin of the local particle. And since the particles are entangled, we also immediately know the spin of the nonlocal particle. This explanation seems very similar to the right and left glove metaphor. I think this type of analysis would be considered a "hidden variable" interpretation (?).
2. The entangled particles did not always have their relative spins. The act of measuring/disturbing/observing the local particle ends the entangled state. In this case, we have to confront the fact (as I understand it) that the nonlocal particle millions of miles away (when measured within less time than the speed of light would require to reach it) shows the opposite spin.
In this cases would a (poor) metaphor of a conveyor belt be helpful? (Even though I think we are dealing with excitations in a universal quantum field.). The conveyor belt stops and immediately stops changes in the spin of the nonlocal particle. The notion would be this is not inconsistent with the speed of light because breaking the entanglement at its source immediately stops changes to the spin. I thought Bill/Bhoppa gave some analogy along these lines? (Sorry I am not explaining it well).
Well, I am hoping this post can stay up a bit to get input.....
Hello @jeffn1 :
First, look up the Bell Inequality experiments. If you don't understand them, post your confusion here and I will attempt to sort it out.
1. The entangled particles would have always had these two spins when measured. So, when we measure/disturb/detect one of the particle, it is revealing the spin of the local particle. And since the particle are entangled, we also immediately know the spin of the nonlocal particle. This explanation seems very similar to the right and left glove metaphor. I think this type of analysis would be considered a "hidden variable" interpretation (?).
No. The notion of "hidden variables" can only be considered an "interpretation" if it can be used to make the same predictions as the QM calculations. I think most in Physics consider the success of "Bell Inequality" experiments - including ones that make the measurements dependent on demonstrably non local events (such as light from galaxies on opposite sides of the sky) - to put "hidden variables" closer to the trash bin than to a real "interpretation".
If you measure both particles along the same axis, you will discover they have opposite spins. In that way, measurements will be consistent. That spin state is independent of other states. So if you "disturb" the particle without affecting the spin state, you haven't started the experiment. Also, if you measure the spin along different axis, you may still find a correlation between the remote and local measurements.
jeffn1 said:
2. The entangled particles did not always have their relative spins. The act of measuring/disturbing/observing the local particle collapses the wave function (or causes a branching in the MWI?). In this case, we have to confront the fact (as I understand it) that the nonlocal particle millions of miles away (when measured within less time than the speed of light would require to reach it) shows the opposite spin.
I am no great fan of MWI, but if you use that interpretation, then in the simplest sense the "first measurement" would split the universe and the second measurement would be consistent with the first because it would be consistent with the universe where that measurement is taken. Of course, there isn't necessarily a "first" and "second" (the measurements might be space-like events). But we can repair that by simply saying that the universe split ahead of time (before either measurement) in preparation for those expected measurements. But that means that two copies of the "hidden variables" were create - one for each universe. This can also be repaired (for example, by abandoning the notion of hidden variables but still trying to differentiate the two child universes another way) - but you probably get the sense of why I am no MWI fan.
I think of it this way:
1) the pair share a single state;
2) the measurement of that state can occur at either particle or with both of them;
3) the results must not challenge the speed-of-light limit on information transfer; and
4) because the two measurements are correlated but random, that speed limit is enforced.
I didn't think Bell inequalities experiments ruled out nonlocal hidden variables. I thought Bohmian Mechanics is a nonlocal hidden variable interpretation.
Very roughly speaking yes. Bell's theorem ruled out a class of models called local hidden variable models. In my mind, I map your point 1 as pointing in the direction of hidden variables and your point 2 as pointing in the direction of locality vs non locality. But there's some call outs:
1. The notion of hidden variables is not as simple as "revealing the spin" would suggest. You have to account for example for contextuality of measurement. There is a no-go theorem (Bell-Kochen-Specker) attached to this as well.
2. Bell thought his result was strong enough to prove non-locality but this is a (highly) contested point. There are some loopholes. For example, "super determinism".
I don't understand this metaphor.
Some interesting resources:
Bertlemann's socks essay from Bell:
https://cds.cern.ch/record/142461/files/198009299.pdf
SEP entry on Bell's theorem which actually lays out his arguments (and their different versions) pretty well: https://plato.stanford.edu/entries/bell-theorem/
Thank you! The conveyor belt analogy (I suspect others have created a better one) is that the pre-detection environment is "in flux". But, a detection performed at different points in time would result in different spins (so there is no predetermined hidden spin(s)). But, once the measurement/detection is made, the conveyor belt stops (please ignore real world macroscopic issues, like momentum). If you conceive the quantum field as all connected, I think you can take the position that stopping the "flux" (potential change in spin, if measured) locally automatically stops any change in spin immediately for the nonlocal particle as well without violating GR. The analogy (which might not withstand scrutiny involving a real conveyor belt) is that stopping the conveyor belt at the source (locally) immediately stops the conveyor belt nonlocally.
[I will read your linked publications!]
John Bell's 1964 paper described tests to decide whether quantum mechanics could be explained by adding "local hidden variables" to restore classical causality and locality.
You could phrase Bohmian Mechanics as a "nonlocal hidden variable interpretation", but I wouldn't leave out that "nonlocal".
Yes. Super-determinism is why I said it was "closer to the trash bin" rather than in it. For me, super-determinism begs the question "What would the grand logic be that makes the Bell Inequality work?". In other words, I'll grant you super-determinism, but where does that leave us? And the answer to that may not be "nowhere". There might be direction from there. But I think we need to see what the presumed "super determinism" has left us with before we can figure out what it is.
jeffn1 said:
Thank you! The conveyor belt analogy (I suspect others have created a better one) is that the pre-detection environment is "in flux". But, a detection performed at different points in time would result in different spins (so there is no predetermined hidden spin(s)). But, once the measurement/detection is made, the conveyor belt stops ...(please ignore real world macroscopic issues, like momentum). If you conceive the quantum field as all connected, I think you can take the position that stopping the "flux" (potential change in spin, if measured) locally automatically stops any change in spin immediately for the nonlocal particle as well without violating GR. The analogy (which might not withstand scrutiny involving a real conveyor belt) is that stopping the conveyor belt at the source (locally) immediately stops the conveyor belt nonlocally.
We only need to deal with special relativity (SR) for this one.
Right away, we have this problem with that "immediately". Those two measurement events can be either "time like" or "space like".
If they are "time like", then one measurement happened before the other and it can create a signal that will reach the other measurement before it happens. Such a signal would be a "local effect". It could travel at light speed and there is no cause/effect issue.
If the measurements events are "space like", then which one appears to have happen first is dependent on your frame of reference. If you are speeding along in one direction, measurement "A" might look like it happened first. In that same case, someone coming at you in the opposite direction could see "B" happen first. But it doesn't matter because neither A nor B can signal its measurement to the other in time to affect the others measurement. They are too far away from each other and their measurements are being made too close in time for either one to signal the other - something that all observers would agree with no matter their reference frame.
Clearly, we want to address ourselves to the "space like" situation. In such a case, which measurement stops the belt? Neither one is unambiguously first.
If we decide that the signal is "nonlocal", then we also don't need to worry which one is measured first because there will never be a time or place when they are unable to exchange information.
But I would call that "the same state".
I am (purely) curious to know if you would consider "non-locality" (in the sense that Bohmian Mechanics is non local) as a "legitimate out" for Bell's theorem, a loophole, or if it's simply untenable due to relativity, or something else?
It is, but the hidden variables are unobservable particle positions. They are not anything like "the direction of spin". When you measure a particle's "spin", BM says that you're actually measuring particle positions and then telling a story about how they indirectly indicate "spin".
The nonlocality comes from the fact that the wave function, which is part of the equation of motion of the particles, depends, if it is entangled, on all of the positions of the entangled particles. And measuring a particle means making it interact with a measuring device, which affects its position, and in turn affects the equation of motion of all other particles that are entangled with it.
What's this mean? Is it your next sentence?
A little hard to know exactly what you mean by this. Are you suggesting the spin state evolves in time?
I can't parse what this means. I'm unable to map this to any actual physics unfortunately.
Same for this.
Bohemian Mechanics (MB), as I understand it, says that the particle's trajectory can be affect "instantaneous" across long spatial distances. This makes it non-local - which is exactly what the Bell Inequality argues for. So it's not a "loophole", it's completely allowed.
To go on, I have always noted that after the measurement, there is always a way of describing the particle as following a specific trajectory. If (per BM) the trajectory can be affected across large spatial distances, then (per SR) how could you possibly stop it from doing the same thing across time.
I notice that BM insists on being "deterministic" and says that the reason the results are apparently "random" is due to a lack of knowledge of the "exact initial positions". I also like determinism (mostly because leaving things to pure random chance is very much NOT in the spirit of scientific exploration). But, since in some cases we need to loose information to avoid FTL communication, I would have the randomness based on something that cannot be foreseen "in principle" rather than "in practicality".
Same for this.
I think forget about the conveyor belt analogy (and thank you for thinking about it). I don't think it was very good because it is too removed and different from entangled particles.
But, I suppose all I was trying to say was that, if the detection/measurement/merely stops any further correlation in spins and the two particle each are left with opposing spins, this does not seem to require the transmission of anything (beyond the speed of light or otherwise). It simply ends the correlation immediately and the (formerly) entangled particles are left with the spin that follows the dis-entanglment. That was the intended point of the (somewhat weak) conveyor belt analogy. [I appreciate your effort to make sense out of my non-physicist language].
I guess I still am not convinced why causality should not apply to this. I do not think there is much dispute that the measurement/detection causes the particles to dis-entangle. But, I think the causality does not require faster-than-speed-of-light (or any other) communication. I will keep looking into it.
Causality normally implies ordering: the cause has to come before the effect. But with measurements on a pair of entangled particles, the ordering doesn't matter: the results are the same no matter which one is measured first. That makes it very hard to see how the usual concept of causality could apply.
Only in interpretations where collapse is a real process. In an interpretation like the MWI, the entanglement doesn't go away; it just gets spread to the measuring devices as well as the particles.
Thank you, Peter. Maybe the confusion stems from what we are defining as "the cause". I tend to think the detection/measurement/interaction of either particle causes both particles to dis-entangle. Is that helpful?
Again, whether the particles "dis-entangle" depends on the interpretation of QM that you adopt. In the MWI, they don't.
Also, saying that the particles "dis-entangle" assumes an interpretation where the wave function describes individual quantum systems. In a statistical/ensemble interpretation, such as Ballentine's, that is not the case.
Also, even if you are using an interpretation where neither of the above issues apply, if the measurements are spacelike separated, there is no invariant fact of the matter about which one occurs first. So it's not possible to say that either measurement "causes" the disentanglement in the usual sense of "cause".
My question would be, why do you care about "cause"? You don't need to answer any of the questions you're asking about "cause" in order to do the actual physics--make the predictions and compare them with experiment.
Ahh, that's a deeper question. I am not doing "actual physics", but I do want to understand science. Is it fair to say you are in the Niels Bohr school of thought? ;)
I'm not sure "the Niels Bohr school of thought" is well-defined enough to answer that. :wink:
I do think it's important to understand and keep clear the distinction between making predictions and comparing them with experiment, and things that aren't that. "Cause", to me, falls into the latter category.
Even then, "cause" is not quite the same kind of thing as, for example, "electron". We can point to particular mathematical objects in our theoretical models and say that they describe an "electron", a real thing. It's not so clear how that works with "cause", at least not if you want to try to include whatever it is that produces Bell inequality violating correlations in the category of "cause".
Yes, "cause" is an interesting concept; more slippery than one might initially think. In law there are two legal concepts "but for" causation and "proximate" causation. "But for" causation seems to be the relevant one for science.
Proximate cause is used in tort law to say that something that never would have been expected should not legally be considered a cause (triggering liability). AI gives this description/example: Proximate cause acts as a legal limitation, asking whether the link between the action and the result is close and direct enough to be fair.
The big case establishing this concept if Palsgraf v. Long Island Railroad (Cardozo): In Palsgraf, a man dropping a package of fireworks while boarding a train caused a distant scale to fall on a woman. It is somewhat related to the scientific concept of the "butterfly effect" which highlights how a tiny, seemingly harmless action can trigger an unpredictable chain of massive consequences.
But, sorry went off on a tangent there.....
But, I think, as you suggest, in science the notion of cause probably requires some type of interpretive model. And in quantum physics right now, things are unsettled with competing "interpretations".
But, as you also (rightly) suggest (maybe even "say"), physicists can accomplish a lot based on knowing the mathematical tools at hand without considering an interpretation ("the story", as you denote it). :)
I think you mean "ends the entanglement" rather than "ends the correlation". A correlation is a property of data sets, not a "thing that exists". The quantum mechanical formalism predicts correlations in data gathered from many repeated trials of running a (Bell-type) experiment. All interpretations of QM (if they are to be called interpretations and not theories) must agree on what the correlations are/will be, given some certain experimental setup.
So, assuming you meant "ends the entanglement", then, as Peter noted, different interpretations (or theories) have different perspectives on what that means. This is, in my view, roughly why Peter keeps saying (something like) there's no cause-effect relationship here but you keep thinking there is. You have a mental model of what "ending entanglement" means that goes beyond what the raw formalism of QM says.
Now talking on a tangent. For example, if you demand an ontological ##\psi## (and complete in the sense of EPR) and that collapse is an objective fact of the matter, you run into Einstein's objections from the 1927 Solvoy conference that your theory would have to be nonlocal. You can see Section 7.1 of https://arxiv.org/abs/quant-ph/0609184 for a brief overview.
Einstein's out was to say the wave function is epistemic, incomplete, and about ensembles of particles.
Note that for the above argument, there is no entanglement at all.
So, a preliminary question for you: what do you think the wave function is? Is it a bookkeeping device for us to run calculations or is it a thing that exists in the world? Or something else? These are, of course, interpretational questions.
We have many no-go theorems that carve out (reject) portions of the space of interpretations, but not enough and not in a way that yields one agreed upon interpretation (or theory).
It can, but you need to be explicit with your definition of causality.
For example, John Bell made the case, in his paper "The Theory of Local Beables" that if you have a certain sense (a reasonable one, but not one without controversy) of local causality then violations of his inequalities means no locally causal theory can reproduce all of QM, and therefore, the world is non-local. But this requires additional machinery (assumptions and theory crafting), and it's not the majority view (afaik) among physicists today. There are certainly many physicists who think the world is local because relativity tells us it is.
At least part of this, though, is a difference in what "local" is taken to mean. In quantum field theory, which is our best current relativistic quantum theory, "locality" means that spacelike separated operators commute. But measurements on entangled particles satisfy that criterion. So they are "local" in that sense, but "nonlocal" in the sense that the correlations they produce can violate the Bell inequalities.
Many discussions on this topic are really different people using different definitions of the same words and talking past each other. (This includes plenty of past PF threads.) That's one reason why, IMO, it's important to understand the math and the experimental predictions without having to use any of those words. Otherwise you keep mixing the basic theory--the machinery that makes the predictions--with interpretation.
Elliott Pearl ( Sp?) was at one point developing a philosophical foundation of causality.
Agreed.
I have also heard the use of the term "micro-causality" for this.
I would agree. And what can make discussions even harder is that there are many versions of Bell Inequalities with similar but subtly different starting assumptions.
A lot of discussions on many topics have this character. 😂 But I would agree that in the physics domain, Bell inequality violations does seem like an area where this is particularly pronounced.
+1 to this.
The math and experimental predictions (for two state systems) given by QM are generally quite clean and simple. The algebra can sometimes be a bit of a grind but it's worthwhile to do it oneself at least once, e.g. to calculate ##\langle \hat{a}\cdot\vec{\sigma}\otimes\hat{b}\cdot\vec{\sigma}\rangle=-cos(\theta_{ab})## starting from ##|\Psi\rangle=\frac{1}{\sqrt{2}}(|01\rangle-|10\rangle)##.
The math on the hidden variables side is not too bad either (depending on version).
It is also useful to see (and discuss) the assumptions in mathematical form. E.g. the factorizability assumption (in notation from the SEP entry cited in post #4):
p_{ab}(s,t|\lambda)=p^1_a(s|\lambda)p^2_b(t|\lambda)
The fact that ##b## does not appear as a subscript on ##p^1## and ##a## does not appear on ##p^2## is what we would say in English "Alice's outcome(s) does not depend on Bob's measurement setting and vice versa".
For the interested reader, what does the fact that ##p^1## contains no conditioning on ##t## mean?
Yes, I meant entanglement ends. But, to my way of thinking, as a result of this the spins of the two formerly entangled particles are no longer correlated.
I think I've resolved myself to accept nonlocality. QFT, based on (let's call them) infinite quantum fields is so well supported. I tend to side with Art Hobson on this: that the attempt to deny nonlocality has led physics down some dead ends (consciousness-based theories, etc.)
I tend to think the wavefunction is a mathematical device that helps explain/predict real physical phenomena. The model I tend to have in my mind (and you can tell me if experiments place doubt on this) is that, at quantum level, there is some rapid (speed of light) movement of (I would say) energy (I admit I may be using energy more broadly than physicists use the term). The movement of energy is impossible to direct measure directly (at least using our current technology). I suspect the location of energy moving is consistent with the Schrödinger equation. Once the energy interacts with a detection device (or it can be a particle in space, etc.), there is a collapse (I am not a big fan of MWI, so I won't bother using "branch" as another way of looking at it). So, I tend to think the location of the particle when detected has some relationship to the movement of energy before the collapse.
I tend to think the concept of "phase transition" may be helpful here (e.g., rapid change from water to ice, etc.). An analogy to cosmic microwave background might be helpful too. As you guys know (you're real physicists!), the tiny temperature fluctuations (anisotropies) in the CMB—mapped in detail by space missions like COBE, WMAP, and the ESA's Planck Mission—reveal the density seeds that eventually grew into galaxies and large-scale cosmic structures.
I suspect, in a similar way, I suspect tiny differentials in energy moving at the speed of light at a quantum level "resolve" to the location of a particles when they are measured.
(Back to "phase transitions", there are some scientists who believe Cosmic Inflation preceded the Big Bang and the Big Bang was the product of a phase transition.)
Thanks, yep, I think nonlocality is real. I'm not sure if it that much more counterintuitive the GR at the time it was presented. I certainly think far less fantastical and implausible than, for example, the real-world implications of MWI.
[PS: Peter Donis is gonna kill me. Hah!;)]
This is all personal speculation and is off limits here. Please don't do that.
It is also your own home-brewed QM interpretation, which is also off limits here. Not to mention a bad idea to begin with. There is 100 years' worth of literature on QM interpretations. Please don't try to roll your own.
  • Love
There is no need for any of that. And Peter Donis is right it is pure speculation.
The simplest explanation is in line with Ballentine.
In an experiment that involves the creation of photon pairs, spin measurements are made at opposite positions.
Subsequently photons are detected and a pattern emerges.
Just like a pattern emerges in a double split experiment. This pattern can be derived with quantum mechanics, the probabilities can be calculated.
But back to the entanglement; at one end, you do not find a photon with spin up and the next one measured with spin down.
Instead, You find a photon out of a pair with this one having spin up and the partner having spin down.
And the next one you have found a photon out of a pair with this one having spin down and the partner far away has spin up.
It is not possible to tell in advance what it will be for the next one, but the probabilities are known.
There is no causality between the measurements and it is unimportant in which order measurements of a specific pair had been made. It is unimportant how far away they are.
You always find a pair out of the ensemble. No problem with locality either.
It becomes more complicated when the measurement angle in the device is rotated. There is actually not much one can know of the spin of an electron or photon. The only thing to work with is the spin impulsmoment in the z-direction, i.e. the spin up and spin down.
The distribution of the probabilities by (difference in) angle in the measurement, the larger pattern, can be calculated starting with Pauli-spin-matrices ..
But one pair will do this and the next pair will do that and so the pattern builds up.
Forgive me if this is a dumb question, but in the case of a pair of entangled particles in a singlet state, if the spin of one entangled particle is measured (which causes them to disentangle, as I understand it), is the spin of the other particle always the opposite?
Only in some interpretations, as has already been pointed out.
If you measure both spins along the same axis, yes. But not if you measure them along different axes.
This is disputed. What is true is that if you consider only measurements along the same axis or at right angles to each other then a local (hidden variable) theory can reproduce the QM predictions. Bell illustrated this in section 3 of his original 1964 paper.
Yeah, I spoiled the ending to this in post #22.
PeterDonis said:
This is interpretation dependent.
Hi, yesterday I had a computer free day.
So indeed the context was mainly Ballentine.
