tbp_Wallbreaker
- 11
- 2
I've been looking closely at the experimental setups for loophole-free CHSH tests, and there's a methodological detail that's bugging me regarding how baseline calibrations rule out hardware artifacts.
Mathematically, we know the local hidden variable bound is |S| ≤ 2. But from a purely metrological standpoint, how do experimentalists actually prove that a measured S → 2.828 is 100% down to quantum entanglement, and not some unmapped systemic bias or artifact in the tabletop apparatus itself? I'm thinking about things like alignment errors, phase-matching cross-talk in the SPDC crystal, or subtle polarization-angle symmetries in the optical path.
The math gives us a theoretical baseline, sure, but one shouldn't just assume the physical outcome of a control group based on the theory you are trying to test. Is it standard practice in the lab to do a control run where the SPDC source is tuned to a non-entangled product state (like parallel or orthogonal polarization mixtures, the kind of classical photon pairs assumed in CH74/CHSH models) just to map the hardware's baseline response on the coincidence counters?
Specifically, are there any foundational or modern peer-reviewed papers that explicitly plot the raw data profiles of these non-entangled, polarization-correlated control runs alongside the entangled ones? If the consensus is that a physical control run is redundant, how is the hardware structurally isolated from classical geometric or polarization-stream biases driving the baseline above 2 (or 0 in CH74) without an actual classical run to prove it?
I'd really appreciate any insights into the lab methodology or literature references on how these baselines are verified. Thanks.
