Y-Delta conversion for Capacitors
  • Thread starter cupid.callin
    Capacitors
10 replies · 76K views · last reply
cupid.callin
This was a ques in my book ... (Pic)
After thinking a while, i realized that it can be solved using Y-Delta (by converting Y to delta form) conversion. But i couldn't get the answer ... i don't know why ...
I used this http://en.wikipedia.org/wiki/Y-%CE%94_transform"
It is given for resistors ... i guess its same for resistors and capacitors ... Right?
Please tell me if the eqn used is wrong or something else!
  • Circuit schematic (b) of a capacitor network with capacitors labelled 1 µF, 3 µF, 2 µF, 4 µF, 4 µF, 2 µF, 3 µF and 1 µF, with a red box drawn around the upper central section.
Remember how capacitors combined differently in series and parallel than do resistors?
What you can do is convert all your capacitances to their equivalent impedance, then use those formulae. Impedances mix and match like resistances.
cupid.callin said:
How do i find impedance of a capacitor?
[tex]Zc = 1/(j\omega C[/tex])
[tex]\omega[/tex] is the operating frequency. The result is in Ohms, and will be an imaginary value.
Don't panic! You don't need to know the frequency for the math to work out; it's a constant for the given Y to Delta situation. If you do the algebra, a pretty simple result obtains. If the resistor version is:
Ra = (R1*R2 + R2*R3 + R3*R1)/R2
Rb = (R1*R2 + R2*R3 + R3*R1)/R3
Rc = (R1*R2 + R2*R3 + R3*R1)/R1
Then the capacitor version looks like:
Ca = C1*C3/(C1 + C2 + C3)
Cb = C1*C2/(C1 + C2 + C3)
Cc = C2*C3/(C1 + C2 + C3)
And to find Y form,
C1 = (CaCb + CbCc + CcCa) / Cc
Right?
Thanks for the help gneill !
Thanks a lot !
cupid.callin said:
And to find Y form,
Right?
Thanks a lot !
Right.
You're welcome.
gneill said:
... for the given Y to Delta situation. If you do the algebra, a pretty simple result obtains. If the resistor version is:
Circuit schematic (b) of capacitors: 1 μF, 3 μF, 4 μF, 2 μF, 2 μF, 4 μF, 3 μF and 1 μF arranged between two terminals, with a red box around the upper group of 1 μF, 4 μF and 3 μF capacitors.
The three capacitors enclosed in red form a Y. So does the other set of 1, 3, and 4 μF capacitors. Converting each of these sets to Δ configuration, as shown by gneill above, will allow you analyze the circuit as a combination of parallel and series capacitors.
PriyankB said:
Is there a simple result for delta to Y as well?
Sure. Just substitute the appropriate capacitor impedances into the formulas for resistance, stir and serve. Note that a capacitor impedance is of the form [itex]1/(j \omega C)[/itex].
Two circuit diagrams side by side: on the left a delta network of three capacitors labelled Ca, Cb and Cc forming a triangle; on the right a star network of three capacitors labelled C1, C2 and C3 meeting at a central node.
So for example, given that for resistors
[tex]R_1 = \frac{R_a R_b}{R_a + R_b + R_c}[/tex]
then
[tex]\frac{1}{C_1} = \frac{C_c}{C_b C_c + C_a C_c + C_a C_b}[/tex]
and so on.
EDIT: Fixed up the expression. Should have been 1/C1 on the LHS.
  • Two circuit schematics side by side: on the left a delta network with capacitors Ca, Cb and Cc on the three sides of a triangle; on the right a star network with capacitors C1, C2 and C3 on three arms meeting at a central node.
