Is 0^0 Equal to 1? An Explanation of Mathematical Concepts and Terminology
  • Context: Undergrad
  • Thread starter Thread starter coolul007
106 replies · 21K views
micromass said:
OK, what do you consider to be "a number"? Do you think -1 is a number? What about pi or i?
I think that 0 is just a "landmark" on the field of numbers. All numbers are calculated with respect to 0. E.g. -1 is defined as a number with difference 1 from 0 in a certain direction (the negative direction).
Mathematics news on Phys.org
dimension10 said:
Isn't a transcendental number defined as an irrational number that is not the multiple of any 2 or more numbers?
No, a transcendental number is defined as a number which is not the root of a polynomial
[tex]a_nX^n+...+a_1X+a_0[/tex]
with an,...,a0 rational.
That said, it is true that q=0 is the only rational number such that q*pi is not transcendental. But that's hardly a good reason to exclude 0 from being a number!
Without 0, we wouldn't have integers (because what would 1+(-1) be?), and without integers, we would have very ugly things. And mathematics would be pretty useless.
I really don't understand why you consider -1 a number, but 0 not. You can't have -1 without having 0!
And 0 is a much more natural concept than -1. Say that I have 8 apples and I give 8 apples away, then I have 0 apples left. What's the problem with this?
language constraints thought. :frown: Negative numbers and zero have different linguistic hurdles to overcome.
With negative numbers, we have to overcome our language's preference to express everything in terms of "magnitude and direction". e.g. to reject the notion of "a surplus of -5" because one would simply say "a deficit of 5".
With zero, we have to overcome our language's preference for using negation. e.g. to reject the notion of "traveled a distance of 0 meters" because one would simply say "didn't travel".
(disclaimer: I am not a psychologist, nor have I actually studied the phenomenon. However, the observation does appear to fit observed fact, and the underlying cause is plausible)
I am not saying that 0 does not exist. I am saying that 0 is not a number.
For example, if you say that a=b+0, we do not say that a and be are unequal do we?
2 is not a prime number. Every other prime number is odd, only 2 stands out. 2 ought to be odd. But it isn't.
So I would say that 2 is more of a "curiosity" than a prime number.
Replace "b plus 0" with "b times 1". Ergo 1 is not a number!
b multiplied by 1 means 1 times of b. Means if you put b 1 time you get 1, right? So, 1 is a number.
But the definition of a prime number, is that, it has only 2 factors. 2 has 2 factors and is thus a prime numbers.
I have provided a sound argument as compared to yours, that "0 is not a number because it does not share a certain property with all other rationals". Believe me, every rational has some property not shared with all other rationals.
2 does similarly not share a property with all other primes, but this provides no basis for denying that 2 is a prime number.
What I'm most interested in is what you consider "a number" is. It is essentially a conventional label (which leaves it up to personal, or more correctly, collective opinion), and no argument could prove that 0 is not a number. This applies to the primes as well. The definition "a natural number which is divisible only by 1 and itself is a prime" corresponds to "an element of Q is a number". We don't leave out 2 as a prime by the same type of reason we don't leave out 0 as a number.
:rolleyes: I think my brain melted...
micromass said:
dimension10, what exactly is your definition of a number?
Thirded. I too would like to know.
Doesn't that make 2 rather odd?
dimension10: you have an opinion on the meaning of the word "number". Your opinion differs from the established usage of the word. That fact will not change no matter how many rationalizations you give.
(moderator hat on) If you wish to continue to try and tell people that they ought to redefine number to match what you want things to be, then do one of the following two things:
  1. Go to another forum
  2. Find a really, strongly compelling reason why such a convention is actually useful
(hint: some minor technical condition you have arbitrarily decided should define "number" does not count as a "compelling reason", especially when lacking motivation)[/color]
dimension 10, what you must realize is that calling something a number doesn't mean that this something suddenly is something magical. It's just another name. That's all it is.
If I would call the integers bazalbieba's, then I could, and everything would still work the same way. But mathematicians have not decided to use the word bazalbieba's, but to use the word number. It's just a name..
I agree that 0 is just a concept, but so are 1,2 and 3. These are all just concepts, which we happen to call "number". Like I said, you can call them something else if you want to, but mathematicians still use the word "number"...
When I call 6 a perfect number, it just means that the sum of it's proper divisors is 6. It means nothing more. It doesn't mean that 6 is suddenly perfection or something. It means exactly what the definition says it means, nothing more and nothing less.
Sorry, Hurk, if a reply wasn't allowed anymore, but I think this could end some confusion.
