Increase Outlet Pressure to 1.5 bar in Retrofitted Process Line
  • Thread starter Thread starter Faizal
    Pressure
The discussion centers on retrofitting a process line to achieve an outlet pressure of 1.5 bar. The current setup includes an open tank and a pump producing an outlet flow of 33 liters per minute (LMH) through a 1.5-inch pipe. Participants suggest that the pump's specifications should be reviewed to determine its capability to reach 1.5 bar. Recommendations include upgrading the pump, elevating the water tank by approximately 10 meters to increase pressure, and using larger exit pipes to reduce friction.
  • Understanding of Bernoulli's Equation and fluid dynamics
  • Familiarity with pump specifications and performance metrics
  • Knowledge of pressure measurement and conversion (e.g., bar to meters)
  • Experience with hydraulic systems and pipe sizing
  • Research pump specifications to identify suitable models capable of achieving 1.5 bar
  • Learn about the impact of elevation on fluid pressure in hydraulic systems
  • Investigate methods for reducing friction in piping systems
  • Explore best practices for retrofitting process lines for optimal performance
Engineers, process line technicians, and anyone involved in hydraulic system design and optimization will benefit from this discussion.
Faizal
Hi all !
I currently in the process of retrofitting an old process line in which I require the outlet pressure to be 1.5 bar.
The design just includes an open tank connected to a pump as shown in attachment. The water level of the tank is leveled with the pump outlet. The pump is currently operating to produce an outlet flow of 33 LMH in a 1.5 in pipe.
By using Bernoulli's Equation, shown in attachment as well, I can't seem to increase the pressure by either manipulating outlet flow or reducing pipe size. I sincerely hope you guys can help by pointing out my mistake and a solution to increase the outlet pressure ?
Thank you very much for your kind assistance ! .. :confused:
Welcome to PF Faizal.
Is the pump capable of 1.5 bar? (see the specs)
What do you expect to see if you would get 1.5 bar? Could it be that you get 1.5 bar and without a stop the pressure just does nothing?
The speed of the flow is slow and there is a pump there so the two sides are not truly communicating. I see no need for the Bernoulli equation.
Options for increasing the exit pressure:
Overwork the pump/change the pump with something better. An overall clean-up will sometimes "up" the pressure.
Move the water tank to a higher elevation, approximately 10m => 1bar.
Make the exit pipes bigger for less friction.
IMO the main culprit is the pump if you do not get 1.5 bar.
Have fun!
18K
