Thermal Properties/Heat Current
  • Thread starter Thread starter verd
    Current Thermal
The discussion focuses on the thermal properties and heat current in a system involving a mixture of water and ice in thermal equilibrium, with an aluminum rod transferring heat to a higher temperature system. The key calculations include determining the temperature of the mixture (TW), the temperature at the radius change point (T), the total heat current (H), and the rate of ice melting due to the heat transfer. The participants emphasize the importance of showing calculations for verification of results.
  • Understanding of thermal conductivity and its implications in heat transfer.
  • Familiarity with the concepts of thermal equilibrium and heat current.
  • Knowledge of the properties of water and ice, particularly phase changes.
  • Basic mathematical skills for performing calculations related to heat transfer.
  • Study the Fourier's law of heat conduction for better understanding of thermal conductivity.
  • Learn about the principles of thermal equilibrium in closed systems.
  • Research the specific heat capacity of water and the latent heat of fusion for ice.
  • Explore practical applications of heat transfer in engineering, particularly in thermal insulation materials.
Students and professionals in physics, engineering, and thermodynamics, particularly those involved in heat transfer analysis and thermal system design.
verd
Hi, I have a problem here that I've done, and am not sure if I have it correct. Here's the question:
A mixture of water and ice is in thermal equilibrium at temperature TW in a thermally insulated container at atmospheric pressure. A rod of aluminum (thermal conductivity k) has one end immersed in the mixture and the other one in contact with a system that is kept at constant temperature TH>TW (see figure). The rod has radius R for a length x from the system and then its radius is reduced to R/2. The total distance from the system to the top of the water-ice mixture is h. Note: the section of the rod that is immersed in the mixture is at the same temperature of the mixture and does not contribute to the thermal conductivity.
a) What is the temperature of the mixture TW in degree Celsius?
b) Calculate the temperature T of the rod at point A, where the radius changes.
c) Calculate the total heat current H through the rod.
d) Calculate the amount of ice that melts per second due to the heat transmitted through the rod.
Here is what I've done:
http://www.synthdriven.com/images/deletable/hwk3.jpg
Does this seem to be correct?? I'm a little shaky with these concepts and don't feel confident in these answers...
Thanks
!Yes, your answers seem correct. However, you need to show the calculations that you used to arrive at the answers. That way, someone can check your work and make sure that your answers are correct.
