The discussion revolves around the converse to Rouche's Theorem, particularly as presented in a paper by Challener and Rubel. Participants explore the implications and validity of this converse in the context of complex analysis, specifically regarding the number of zeros of holomorphic functions within certain contours.
Debate/contested
Technical explanation
Mathematical reasoning
Edwin inquires about the converse to Rouche's Theorem and references a specific paper on the topic.
Some participants express skepticism about the validity of a straightforward converse, noting that it would not hold true in all cases, as illustrated by a counterexample involving the functions f(x) = g(x) = x.
Another participant discusses the conditions under which Rouche's Theorem applies, emphasizing the convexity condition necessary for the theorem's validity.
One participant suggests that the converse presented in the paper does not align with their understanding of Rouche's Theorem, particularly regarding the conditions on the paths involved.
There is a discussion about the implications of the theorem and whether it can be generalized beyond the unit circle, with references to Blaschke products and their properties.
Participants mention the potential for a more interesting converse that could expand the conditions or types of loops considered in the theorem.
Edwin shares a detailed summary of the theorem and lemma from the Challener and Rubel paper, indicating that it may suggest Rouche's Theorem does not admit a general converse.
There is curiosity about whether the converse mentioned by Mathwonk can be constructed based on the information provided.
Participants generally do not agree on the validity of the converse to Rouche's Theorem, with multiple competing views on its implications and the conditions necessary for its application. The discussion remains unresolved regarding the potential for a more general converse.
Participants note limitations in the applicability of Rouche's Theorem and its converse, particularly concerning the specific conditions required for the functions and paths involved. There is also mention of unresolved mathematical steps related to the generalization of the theorem.
#1
Edwin
159
Hello,
I was wondering if anyone is familiar with the converse to Rouche's Theorem published in a paper titled "A Converse to Rouche's Theorem," in American Mathematcal Monthly, Vol. 89, No. 5 (May, 1982), pp. 302-305 by David Challener and Lee Rubel?
I'd be kind of curious as to how it's worded, since a straight converse wouldn't be true. For example the converse of this version wouldn't be true:
Original Theorem:
If the complex-valued functions f and g are holomorphic inside and on some closed contour C, with |g(z)| < |f(z)| on C, then f and f + g have the same number of zeros inside C, where each zero is counted as many times as its multiplicity.
If the complex-valued functions f and g are holomorphic inside and on some closed contour C, and f and f + g have the same number of zeros inside C, where each zero is counted as many times as its multiplicity, then |g(z)| < |f(z)| on C.
Take for example f(x) = g(x) = x. Then f(x) = x and (f + g)(x) = 2x both have one zero, but it is not true that |g(z)| < |f(z)| on C.
#3
cogito²
96
Here's the beginning to that article you mentioned:
as observed above, the strict converse of rouche is false.
zeroes of holomorphic functioins are computed by the argument principle, i.e. by integrating a certain closed differential form, df/f for analytic f, around a loop missing all zeroes of f.
the fundamental theorem is that two loops yield the same integrals for all closed differential forms iff they are "homologous".
rouches theorem has a strong convexity hypothesis that guarantees two paths are homologous, namely that for all instants t of time, the two path points r(t), s(t), lie in some common hyperplane missing the origin.
this condition is certainly not necessary for homology of the paths. In fact I cannot think of a natural converse of rouche that has remotely the same condition as rouche uses. i will look at the reference if possible.
well its not a converse to (my version of) rouche at all. the conclusion is not a condition on the paths since the path is fixed as the unit circle, a convex curve.
but i probably do not know what rouches theorem says. ill look it up.
no I am right, ropuche is a statement about an arbitrary loop, plus a convexity condition on the values, which translates into a convexity conditioin on the image of the path under the two functions.
i.e. given a loop and a function defined on and inside the loop, with no zeroes on the loop, look at the image of the loop under the function. this is a loop not passing through the origin,m and the number of zeroes of the original function inside the loop equals the winding number of this loop around the origin, i.e. essentially the integral of dw/w, which translates back under f to the integral of df/f.so the converse is saying something like, if the original path is already convex, then the only way the image paths can have the same winding numbers is if the functions also satisfy some kind of convexity property.
but it is much weaker than that since it is proved only for the unit circle. still it seems sort of interesting.
so rouche says here is condition on the values of two functions on a path that guarantees the same winding number. the "converse" says there is at least one path such that the condition is actually necessary. not much of a converse, but still interesting.
well i don't know what a balshke product is, although of course it was defiend right there, but the esterman "strengthening" of rouches theiorem sems to me to be exactly the original theorem. i.e. the hypothesis still just means geometrically that the two values f(z), g(z) are in the same open hyperplane missing zero, for all points of the circle, so the straight line homotoyp shows they HVE THE same number of zeroes.
the generalization is some kind of generalized hyperplane?
#10
Edwin
159
I was able to print out the full text...Challener and Rubel proved the following theorem.
"Theorem 1. Suppose f and g are analytic in a |z| <= 1+epsilon,
Epsilon > 0, with no zero's on |z| = 1. If the Z_f and Z_g are the number of zero's of f and g in |z| < 1, then: Z_f = Z_g if and only if there exist finite Blaschke products A, B of the same order such that
|Af + Bg| < |f| + |g| on |z| = 1" (Challener; Rubel 304).
Challener and Rubel included the following Lemma in their proof:
"Lemma 1 given f, g analytic in |z| <= 1 + epsilon, epsilon > 0, f and g having no zeros on |z| = 1, then there exist finite Blaschke products A, B such that |Af + Bg| < max{|f|,|g|} on |z| = 1." (Challener;Rubel 303)
Challener and Rubel stated
"Our proof rests on the following fact proved by Helson and Sarason in [4].
Fact: Any continuous unimodular function y on |z| = 1 is the uniform limit of finite Blaschke products." (Challener;Rubel 303)
I think that they also prove that Rouche's Theorem doesn't admit a converse in general, but I'm not sure...
I imagine that if one can prove that "Any continues unimodular function y on |z - k| = C, is the uniform limit of finite Blaschke products, where C is any real number >= 1, k is any complex number," then one can maybe extend the proof created by Challener and Rubel to any circular disc in the complex plane.
Mathwonk Wrote:
Code:
a more interesting converse would expand the list of admissible loops or prove that it cannot be expanded.
I would be very interested in learning the answer to that question that Mathwonk posed. Can anyone tell, based on the information above, if such a converse, mentioned by Mathwonk in the quote above, can be constructed?
Inquisitively,
Edwin
Source of Quotes
David Challener and Lee Rubel, The American Mathematical Monthly, Vol. 89, No. 5. (May, 1982) pp. 302-305.
4. H. Helsom and D. Sarason, Past and future, Math. Scand.,21 (1967) Lemma on page 9.
