Two Questions, one very complicated
  • Thread starter Thread starter KingNothing
The forum discussion revolves around two physics problems: the impact force of a paratrooper hitting the ground and the final velocity of a train car rolling down an incline. For the paratrooper, the impact force is calculated using the formula Fground = (1/2)mv2 + mgd / d, resulting in an impact force of 3237 N when considering gravitational force. The second problem involves a 4000 kg train car on a 5-degree incline, where the final velocity of the combined mass of the train and three carts is determined using energy conservation and momentum principles, yielding a final speed of approximately 2.4 m/s.
  • Understanding of Newton's laws of motion
  • Familiarity with energy conservation principles
  • Knowledge of momentum and its conservation
  • Basic calculus for solving equations of motion
  • Study the concept of impact forces in physics
  • Learn about energy conservation in mechanical systems
  • Explore the principles of momentum and its applications
  • Investigate the effects of friction on motion and energy loss
This discussion is beneficial for physics students, educators, and anyone interested in understanding the dynamics of motion, impact forces, and energy conservation in real-world scenarios.
KingNothing
Please help me with these two questions...I kinda know where to start, but If I just saw it worked out once I could do all of them of this style, so please help.
Question 1:
"A 65-kg paratrooper is falling, and hits the ground at 4 m/s. He makes an indentation 0.2 m deep in the ground. What force does he hit the ground with?"
Question 2: This one is complicated:
A 4000 kg train car is atop a 5 degree incline which is 5 m high (from baseline to top of hill, making it about 57 m long). It begins rolling down. The coefficient of the rolling frciton is 0.05 which is also static friction. At the bottom of the incline, it attaches to 3 identical carts. What is the final velocity of all 4 carts (when they form a train)?
Originally posted by Decker
Question 1:
3 energies are at work. The ground does work on the man over a distance, gravity does work over a distance (gravity is often forgotten), and he had an initial kinetic energy.
F_{ground}d = \frac{1}{2}mv^2 + F_{gravity}d
F_{ground} = \frac{\frac{1}{2}mv^2 + mgd}{d}
Write an equation for the energies
potential energy = friction + kinetic energy
mgh = Fd + \frac{1}{2}mv^2
mgh = \mu mg \cos(\theta)d + \frac{1}{2}mv^2
Then isolate for V. It will be easier if you just factor out the mass.
To find the velocity of all the carts, use the formula for momentum
m_1v_1 = m_2v_2
It looks good...but we haven't done anything yet with kinetic energy or 'work'. I don't even know what h is in the second one.
mgh=Fd+.5mv^2
(9.8)(5)=(0.05)(0.996)(57)+.5(v^2)
49=2.8386+.5v^2
92.3228=v^2
v=9.6 m/s?
Does that sound right?
Then the whole train would be going 2.4 m/s when they connect?
I still need lot of help on the other one, I don't know what work done by the ground is!
Perhaps we are making the dent in the ground problem to hard, the dent is a red herring, the paratrooper is FALLING therefore his acceleration = g so F= mg end of story.
Integral, that's not true at all. Ever notice that you can stand straight up but if you jump down from something maybe a meter high, you always need to bend your legs?
Actually try it.
I'll try to explain why that's not true... when you hit the ground, you feel the normal force, right? Usually the normal force is equal to your weight so you feel no acceleration:
\Sigma F = mg - N = 0
However, when you hit the ground with speed, the normal force is a lot stronger than your weight. If it were still equal to your weight, your acceleration would be zero and the speed with which you hit the ground will not go away (and of course, after the impact your velocity is zero so this can't be true).
What's the normal force got to do with anything?
cookiemonster
cookiemonster
Everything! That's what's stopping the paratrooper.
The best one can do with this problem is find the average force exerted by the ground in stopping the paratrooper within a distance d. ShawnD did that several posts ago.
cookiemonster
A lot... :smile: Do you have a scale around? Place it on the ground and step up on it. It will show your "real" weight, right? Now instead of stepping up on the scale, try jumping on it (without breaking it of course... don't try this if you ate too many cookies this morning!) while looking at its display. You will see that for a brief moment the scale, which measures the normal force, shows an extremely large number.
As far as jumping off a chair and having to bend your legs, I believe that would fall under momentum, not force. p=mv so the increased velocity on impact when jumping from any given height would increase, increasing one's momentum. f = p/t so the ground would have to exert a greater force on the person in order to stop. By bending your legs you would be increasing t, reducing the force exerted on the body.
mrbill
can you assume that the deceleration as he hits the ground is constant?
If so use the formula v^2=u^2+2*a*s,
This will let you work out the acceleration and so using F=ma you can work out his force.
therefore 4^2/(2*0.2) =40
f=65*40=2600N
This looks a bit big so I may be wrong
for the other question f=mgsin5-0.05*mgcos5
f=ma therefore you can work out the acceleration of the single truck
then again use v^2=u^2+2as to work out the final speed
then use conservation of momentum at the bottom
i.e. mu=4mv and you can work out the final speed of all the cars
I certainly hope the paratrooper doesn't hit the ground with the same force as his normal force! He'd plow right through the ground! The normal force had better be significantly bigger than the impact force, but that still doesn't answer my question. What does the normal force have to do with the force with which the paratrooper hits the ground? The normal force only has to do with how quickly the paratrooper stops, no?
cookiemonster
Normal force = impact force!
The force that the ground hits the paratrooper is the normal force, by definition. And the paratrooper had better hit the ground with a force equal to the normal force--else Newton's 3rd law is in trouble!
He does! That's why he sinks down.
The normal force is the impact force! And, yes, the normal force is what determines how quickly he will stop.
Ah, we're running around with different definitions.
cookiemonster
I see...well, I think force normal is the force that the Earth applies to the paratrooper...I'm not sure, I never intended to think about it too much...
Anyhoo, this is what I did:
V^2=V^2+2AX
0=16+.4A
-16=.4A
A=-40
d=.5AT^2
.2=20T^2
.01=T^2
T=0.1 s
Change in momentum=F*T
(65)(4)=0.1F
260=0.1F
F=2600 N
Whereas the normal force when he's standing there would be m*a or 637 N.
Now, that also means that if a person who weighed 637 N or 143.3 pounds jumped about
d=4.9(4/9.8)^2
81.6 cm into the air, when he hits the scale, it would show about 585 pounds if the collision was totally elastic (I think that's the right way to say it...assuming he didn't slowly brace himself with bending of the knees). It would hurt to land with straight legs after jumping 81.6 cm into the air.
What do you know, the physics idiot knows how to do something!:P
Decker said:
V^2=V^2+2AX
0=16+.4A
-16=.4A
A=-40
d=.5AT^2
.2=20T^2
.01=T^2
T=0.1 s
(65)(4)=0.1F
260=0.1F
F=2600 N
You forgot the force of gravity. 2600 would be the answer if the velocities and distances were all horizontal such as a car hitting a wall. The added gravity force is 65 * 9.8 = 637N which would make the answer 3237.
Try it with the energy formula I posted at the top
F_{ground} = \frac{\frac{1}{2}(65)(4^2) + (65)(9.8)(0.2)}{0.2}
F_{ground} = 3237N
Any thoughts or flaws in my reasoning?
Perhaps your biggest flaw is your lack of flaws. It may pop other's self esteem balloons. ;)
Yeah, sorry about that :wink:
Actually, I can think of one potential problem - since the original question was about a paratrooper hitting the ground - wouldn't he reach terminal velocity before hitting the ground. I'm pretty sure a parachuting person would reach terminal velocity. So wouldn't that make his acceleration 0, and not 9.8?
If he was at terminal velocity, his acceleration was zero immediately before hitting the ground.
His acceleration history upon hitting the ground really depends on the soil mechanics. Imagine the top 8 centimeters is mud, and under that there is 6 centimeters of hard, dry clay, and then sand the rest of the way down. A graph of his acceleration (deceleration, if you prefer) vs. time would be pretty jagged. Probably they expect you to make an assumption of uniform soil composition.
11K
  • · Replies 16 ·
