How Fast Can a Trebuchet Fling a Light Object?
The discussion revolves around calculating the maximum speed of a light object flung by a trebuchet, modeled as a stiff rod with two masses at its ends. The larger mass is 60.0 kg, while the smaller mass is 0.120 kg, with the system pivoting on a frictionless axle. The moment of inertia is calculated using the formula I_cm = (M + m) * l^2/12, resulting in 20.25 kg*m^2. The kinetic energy equation K = 1/2 I_cm w^2 + 1/2 M v_cm^2 is applied, but the user expresses uncertainty about how to proceed with the calculations. The thread highlights the complexities involved in modeling the dynamics of a trebuchet.
KvnBushi
A war-wolf, or trebuchet, is a device used during the Middle Ages to throw rocks at castles and now sometimes used to fling pumpkins and pianos. A simple trebuchet is shown in Figure P8.77. Model it as a stiff rod of negligible mass 3.00 m long and joining particles of mass 60.0 kg and 0.120 kg at its ends. It can turn on a frictionless horizontal axle perpendicular to the rod and 14.0 cm from the particle of larger mass. The rod is released from rest in a horizontal orientation. Find the maximum speed that the object of smaller mass attains.
Pic: www.s-consolidated.com/graphics/trebuchet.jpg[/URL]
[h2]Homework Equations[/h2]
[tex]K = \frac{1}{2} I_{cm} w^2 + \frac{1}{2} M v_{cm}^2[/tex]
[h2]The Attempt at a Solution[/h2]
I am not even sure how to model it yet. I will attempt some things and write them as I go.
I_{cm} = (M + m) * l^2/12where M is the 60kg, m is the 0.12kg and l is 3mI_{cm} = 20.25 kg*m^2v_{cm} = (M + m)*v/(M + m)v_{cm} = vK = \frac{1}{2} I_{cm} w^2 + \frac{1}{2} M v_{cm}^2 K = \frac{1}{2} * 20.25 * w^2 + \frac{1}{2} * 60 * v^2I am not sure where to go from here.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
