Need help finding spring constant
The discussion revolves around calculating the spring constant (k) for a scenario involving a ball dropped onto a spring. The ball's mass, drop height, and maximum spring compression are provided, alongside gravitational acceleration.
  • The original poster attempts to apply the conservation of energy principle using the equation mgh = 0.5kx^2 but encounters difficulties. Participants question the correct height to use in the equation and suggest considering the change in gravitational potential energy.
Participants are actively engaging in clarifying the approach to the problem. Some guidance has been offered regarding the height to use in calculations, with suggestions to measure from the lowest point of the spring's compression.
There is an ongoing discussion about the appropriate reference point for height in the energy conservation equation, indicating potential confusion about the setup of the problem.
Mustrdhead
A 147g ball is dropped from a height of 56.5cm above a spring of neglibible mass. The ball compresses the spring to a maximum displacement of 4.45393cm. The acceleration is 9.8m/s^2. calculate the spring force constant k. Answer in units of N/m.
Not sure
I converted the mass from 147g to .147kg the height from 56.5cm to .565m and the displacement from 4.45393cm to .0445393m.
Now I am stuck and don't know what to do
I tried mgh=.5kx^2 but didnt work
What did you use for h? (You need the change in height, from initial position to final position.)
what do you mean? i used the given height of .565m
Hint: What's the change in gravitational PE? Hint 2: Measure gravitational PE from the lowest point.
so use a zero height? or use .565+.0445393?
That's the height you need to use in that formula. This is just a consequence of conservation of energy.
Thanks you are a genius
You are very perceptive. :smile:
  • · Replies 58 ·
