What direction will the force from acceleration act in this scenario?
  • Thread starter Thread starter t_n_p
    Friction
The discussion centers on calculating the coefficient of kinetic friction for a 60kg cart that falls off a truck traveling at 80 km/h and slides 45m before stopping. The user correctly calculates the acceleration as -4000/729 m/s², indicating deceleration. The participants clarify that the frictional force acts opposite to the direction of motion, and the relationship between acceleration and friction is established as µ = a/g. Additionally, the importance of the height from which the cart falls is emphasized, as it significantly affects the calculations.
  • Understanding of Newton's laws of motion, specifically F=ma.
  • Knowledge of kinematic equations, particularly Vf² = Vi² + 2as.
  • Familiarity with the concept of friction, including the coefficient of kinetic friction (µ).
  • Basic principles of conservation of energy in physics.
  • Learn how to derive the coefficient of kinetic friction using experimental data.
  • Study the effects of height on the velocity of falling objects using conservation of energy.
  • Explore advanced kinematic equations and their applications in real-world scenarios.
  • Investigate the relationship between normal force and friction in dynamic systems.
Students studying physics, particularly those focusing on mechanics, as well as educators looking to enhance their understanding of friction and motion dynamics.
t_n_p
I have a 60kg cart on the back of my truck (travelling at 80km/h) which falls off the back and slides 45m before coming to a stop. I want to find coefficient of kinetic friction
http://img9.imageshack.us/img9/4356/38603897.jpg
Vf = 0km/h
Vi = 80km/h = 200/9 m/s
s = 45m
using Vf^2 = Vi^2 + 2as,
I find acceleration to be = - 4000/729 m/s^2 which I think is correct up to this point as the negative indicates decelleration
This is where I get confused,
I draw my free body diagram, which way will the force created by acceleration (i.e. F=ma) force act? Will it be to the right or to the left?
t_n_p said:
Vf = 0km/h
s = 45m
Your velocity is left. The acceleration is right. The friction acts against the direction of motion.
so if i draw a FBD...
http://img10.imageshack.us/img10/9336/41243042.jpg
frictional force = µN
I know N, I want µ, which means I need to know frictional force.
is frictional force equal and opposite to the F=ma force?
my qualm is that if it is equal and opposite, doesn't this suggest the box is static, rather than moving?
Once the box falls off the vehicle the force of friction is the force responsible for the acceleration. So in your case once it hits the ground µN=ma and it will be static once it comes to rest because the deceleration from friction is a reactionary force that resists motion.
No as DClancy says what you have labeled m*a is your µ*m*g. Your situation is not static if there is acceleration. It's only static when it comes to rest 45m later. So your a = µ*g and it is directed to the right in your drawing.
right, so its more like...
http://img15.imageshack.us/img15/9466/83450616.jpg
which results in µ=a/g
I'm just a little confused as to how velocity can be left and acceleration can be to the right
thanks for the help
Ok, your diagram looks good. So now let's think about what is happening. The box falls off the truck and right before it hits the ground and begins to slow it is going 80 km/h. That velocity is in the same direction the truck was going, based on the orientation of your diagram the velocity is to the left. Once the box touches the ground the force of friction acts on it, the force of friction is directed to the right, opposite of the velocity, since the box comes to a stop the FF must be opposite the velocity in order to slow it down and eventually stop it.
ok cool, that makes things clear.
thanks for the help guys
There is a huge mistake in the problem. The answer depends also on the height from which the cart falls. Suppose that the cart falls from a height of H. Then the velocity in the vertical direction just before the cart hits the ground, Vv, satisfies by conservation of energy:
1/2 Vv^2 = g H -------->
Vv = sqrt[2 g H]
When the cart makes contact with the ground, there will be a very large normal force acting on the cart for a short time (tau) which will cause the momentum of the cart in the vertical direction to become zero. tau will be of the order of the thickness of the cart divided by the speed of sound. The integral of the magnitude of the normal force over this short time will be equal to
m Vf +m g tau= m sqrt[2 g H] + m g tau
Since tau will be very small, we can ignore the last term. Now, mu times the normal force is the friction force. So, the integral of the friction force over the time from the moment when the cart makes contact with the ground till a time tau later when the vertical motion of the cart has relaxed to zero is given by:
mu m sqrt[2 g H]
This is equal to the change of momentum in the horizontal direction. So, the speed decreases by an amount:
mu sqrt[2 g H]
This then means that Vi should be replaced by:
Vi - mu sqrt[2 g H]
This then gives you a quadratic equation for mu.
no value for height is given in the question, therefore for all intensive purposes I think it has been ignored
Yes, but if you take H to be of the order of 1 meter, you see that it already has a very significant effect. Thing is that the cart is dropped and has to stop moving in the vertical direction, so it is an essential effect and not at all like ignoring air friction in ball throwing problems.
A similar mistake in a similar problem was spotted by me here:
https://www.physicsforums.com/showthread.php?t=297204
well i have no value to work with, what would you do?
I will seek clarification in the meantime
I would first explain in the solution that the height is important. Then I would simply assume a realistic value for the height , like H = 2 meters. Then I work out the solution.
What matters is that you understand the physics of the problem and are able to compute the answer. In some cases a teacher can overlook an essential part of the physics involved. So, if a student spots that and changes the formulaton of the problem to take that into account, then all the teacher can do is give that student some bonus points.
There is also the counter view that a teacher might do some off balance sheet accounting at grade time and evaluations if a student has raised specious and smart alec considerations and disrupts the learning process for others.
One would be advised to balance the risks I'd think.
  • · Replies 17 ·
  • · Replies 23 ·
  • · Replies 22 ·
