Question about Gram-Schmidt orthogonalization
  • Context: Graduate
  • Thread starter Thread starter pamparana
The discussion centers on the Gram-Schmidt orthogonalization process, specifically addressing the orthogonality of vectors generated from independent vectors u, v, and w. It is established that the resulting orthonormal vectors U, V, and W are orthogonal to each other, with V being orthogonal to u and W being orthogonal to both u and v. The mathematical reasoning involves understanding the null space of the subspace spanned by u and v, confirming that W lies in this null space. The discussion also touches on the QR factorization and its relation to the orthogonality of these vectors.
  • Understanding of linear independence and vector spaces
  • Familiarity with the Gram-Schmidt orthogonalization process
  • Knowledge of inner product spaces
  • Basic concepts of QR factorization
  • Study the detailed steps of the Gram-Schmidt process for three vectors
  • Explore the concept of null spaces in linear algebra
  • Learn about the implications of orthogonality in vector spaces
  • Investigate the relationship between QR factorization and orthogonal matrices
Students and professionals in mathematics, particularly those studying linear algebra, as well as data scientists and engineers working with algorithms that involve vector spaces and orthogonalization techniques.
pamparana
Hello everyone,
I have a query regarding the Gram-Schmidt factorization:
Say I have 3 independent vectors, u, v, w and I used the factorization scheme to get U, V, W vectors that are orthonormal to each other.
So U, V, W are orthogonal to each other.
Is it also true that V is orthogonal to u (small u)
and W is orthogonal to small u and v.
In my mind, I am quite convinced it is so. However, what is the exact mathematical reason for this. I think that W is going to be orthogonal to the whole plane described by u and v and V is going to be orthogonal to the line described by u. I am just a tad unsure why this would be.
I am trying to understand that when we do QR factorization why we get an upper triangular matrix and that seems to depend on the above statement being true.
Many thanks,
Luca
Edit: I thought about this a bit more and have the following explanation. Please let me know if it sounds plausible
If we consider the vectors U and V. They form the basis for a 2D subspace in a higher dimension space. So, the vector W lies in the null space of this 2D subspace and this null space will be orthogonal to the row space of the 2D subspace. Hence, W is orthogonal to u and v as well as they lie in the same subspace.
Does this make sense?
Yes, it is true. When you look at the process you can see two things going on (I'm assuming you maintain the vectors in their current order of u,v,w)
1) You orthogonalize your current vector by removing the components in the space spanned by your previous (now orthonormal) vectors
2) You normalize your vector
Ignore step 2. Here's your job:
Prove that if you have a set of vectors u1, u2,..., uk linearly independent and you do Grahm Schmidt to get U1,..., Uk then the spaces spanned by u1,...ur and U1[/sub,...Ur are the same for each r (use induction. The base case is trivial).
Then since Ur+1 when inner producted with any element of the space spanned by U1,...Ur must come out to 0 (since it's orthogonal to each of those) Ur+1 must be orthogonal to u1,... ur as you suspected
If you're really and truly only interested in the case of three vectors, you don't even have to do induction, and can just prove the above directly, but it's not as satisfying
The Gram-Schmidt process starts with vector u and finds U that has length 1 and is in the same direction as u. It then, given vector v, finds v' that is orthogonal to vector U and then V that has length 1 and is in the same direction as v', not v. Finally, given vector w, it finds w' that is orthogonal to both U and V and then W that has length 1 and is in the same direction as w', not w. U is in the same direction as u, V and W are not necessarily in the same direction as v and w.
Of course, you could do the Gram-Schmidt orthogonalization process starting with v or w instead of u which would change the result.
  • · Replies 20 ·
