Another proof: x^2 + xy +y^2 > 0
  • Thread starter Thread starter nietzsche
    Proof
The problem involves proving that the expression \(x^2 + xy + y^2 > 0\) holds true under the condition that \(x\) and \(y\) are not both zero. The discussion centers around algebraic manipulation and reasoning related to inequalities and properties of quadratic expressions.
  • Participants explore various algebraic manipulations, including completing the square and analyzing extrema of the function. Some question the implications of specific cases, such as when \(x\) and \(y\) are both positive or negative.
The discussion includes multiple attempts to approach the proof, with participants offering different methods and questioning assumptions. Some suggest that the problem may be more straightforward than initially perceived, while others provide alternative perspectives on the reasoning involved.
There are indications of confusion regarding the clarity of certain steps in the proofs, and some participants express a desire for further elaboration on specific methods. The original poster's attempts and the responses reflect a collaborative effort to dissect the problem without reaching a definitive conclusion.
nietzsche
Hello again, I have another proof that I can't figure out how to solve.
<br /> \text{Prove that if }\textit{x }\text{and }\textit{y }\text{are not both 0, then}<br /> \begin{equation*}<br /> x^2+xy+y^2&gt;0\tag{1}<br /> \end{equation*}<br />
N/A
Not sure if I'm on the right track here...
<br /> \text{Assume (1) is true:}<br /> \begin{align*}<br /> x^2+xy+y^2 &amp;&gt; 0\\<br /> x^2 +2xy + y^2 &amp;&gt; xy\\<br /> (x+y)^2 &amp;&gt; xy\\<br /> \end{align*}<br />
...not sure where to go from here.
I would say to look for the extrema of f(x,y)=x^2+xy+y^2. Find df/dx and df/dy and set them equal to zero and solve for x and y. Can you classify that as a min or a max or neither?
(x+y)2 = x2 + 2xy + y2 >= 0 You know that already
So
x2 + xy + y2 >= -xy
If x and y are both positive, the result is trivial. If x and y are both negative, the result is also trivial. (in both cases, each term in the summation is positive). When one of x or y is negative, -xy becomes positive. So what can you say?
Okay, here's another attempt.
<br /> \begin{align*}<br /> x^3 - y^3 &amp;= (x-y)(x^2+xy+y^2)\\<br /> \frac{x^3 - y^3}{x-y} &amp;= x^2+xy+y^2 \tag{1}\\<br /> \end{align*}<br /> \begin{align*}<br /> x^2 + xy + y^2 &amp;&gt; 0\\<br /> \frac{x^3 - y^3}{x-y} &amp;&gt; 0 \tag{2}<br /> \end{align*}<br /> \text{(2) is true for }<br /> \begin{math}x&lt;y\end{math}<br /> \text{, }<br /> \begin{math}x&gt;y\end{math}<br /> \text{,}<br /> \begin{math}x, y \in \mathbb{R}.\end{math}\\<br /> \\<br /> \text{For }<br /> \begin{math}x=y\end{math}<br /> \text{:}<br /> \begin{align*}<br /> x^2+xy+y^2 &amp;&gt; 0\\<br /> x^2 + x^2 + x^2 &amp;&gt; 0\\<br /> 3x^2 &amp;&gt; 0\tag{3}<br /> \end{align*}<br /> \text{(3)} is true for all<br /> \begin{math}x, y \in \mathbb{R}.\end{math}<br />
So
x2 + xy + y2 >= -xy
When one of x or y is negative, the LHS will be greater than a positive number and therefore greater than zero?
a worse idea for a proof used to live here.
Thank you all!
Well, I think you guys are complicating things a little bit here. :rolleyes:
We can use the idea of completing squares to solve this problem. It goes like this:
x ^ 2 + xy + y ^ 2 = \left[ x ^ 2 + 2 x \left( \frac{1}{2} y \right) + \left( \frac{1}{2}y \right) ^ 2 \right] + \frac{3}{4} y ^ 2
I'm almost spilling out the answer. Since the OP has already had his own solution, this is just another way to tackle the problem.
So, what left is to determine when the equation holds. :)
There is much easier way to do it:
x^2+xy+y^2=(x+y/2)^2-y^2/4+y^2=(x+y/2)^2+3/4(y^2)=(x+y/2)^2+(\frac{y\sqrt{3}}{2})^2
Now
(x+y/2)^2 + (\frac{y\sqrt{3}}{2})^2 \geq 0
Now
could you show your work please?
thanks
thanks
:smile: I've already showed it.
if a2 \geq 0 and b2 \geq 0 then a2+b2\geq 0
never mind, it was just from completing the square from above (I only skimmed through the thread sorry)
Now
applause
wow, that's so concise
  • · Replies 17 ·
