Connection between ppm and length?
  • Context: Graduate
  • Thread starter Thread starter mjdwyer23
    Connection Length
The discussion centers on converting thermal expansion data from parts per million (ppm) to percent for a dilatometer software developed in the 1980s. The user, Matt Dwyer, seeks to calculate the thermal expansion coefficient (alpha) but faces challenges due to the software's lack of original length measurement. The conversion formula provided is x (ppm) = x/10^4 (percent), allowing for the transformation of ppm data into a percentage format.
  • Understanding of thermal expansion concepts
  • Familiarity with dilatometer operation
  • Basic knowledge of data conversion techniques
  • Proficiency in interpreting scientific measurements
  • Research the principles of thermal expansion in materials
  • Learn about the operation and calibration of dilatometers
  • Explore data conversion methods in scientific software
  • Investigate the calculation of thermal expansion coefficients
Researchers in materials science, particularly those studying thermal properties of complex perovskites, as well as engineers and technicians working with dilatometric measurements.
mjdwyer23
Hi everyone-
I'm a junior at U. Penn doing a research project on thermal expansion in complex perovskites. I'm having trouble with a computer program that I'm using to control and obtain data from our dilatometer. The problem is that the software was made in the mid to late 80's, and it only gives data in ppm. What I need to do is convert the expansion to a percent. The program, however, seems to not measure the original length at all. It looks like it tares the sensor at the programmed reference temperature and goes from there, but the alpha (thermal expansion coefficient) needs to be calculated with the original length. Is there any way I can convert from ppm to cm to get a percent change somehow? Thanks
Matt Dwyer
ppm = parts per million
ppm means parts per million, so you should be able to convert it to a percent: x (ppm) = [itex]x/10^4[/itex] (percent).
17K
  • · Replies 24 ·
  • · Replies 31 ·
  • · Replies 17 ·
