Clock postulate and differential aging
74 replies · 12K views
ThomasT
In a recent thread about differential aging in the archetypal twin scenario, I suggested that the periods of oscillators are affected by accelerations, or in other words that a clock's tick rate is affected by changes in its speed.
This statement was disagreed with by some, who said that it was contradicted by the clock hypothesis or postulate.
However, the clock postulate just says that the rate of the earthbound clock is always related to the rate of the traveling clock by (1-v2)-1/2 .
From the above mentioned thread, when asked for an equation relating tick rate and acceleration, I replied:
ThomasT said:
What about this:
The tick rate is r(1-(v/c)2)0.5, where v is the relative velocity of the clock and the observer determining a tick rate, and r is the tick rate of the clock at rest.
When the velocity of the traveling clock changes (when it's accelerated), then its tick rate (wrt the stationary earthbound observer) changes.
To which DaleSpam replied:
DaleSpam said:
That is the same as the equation I gave, [tex]\frac {d\tau} {dt} = \sqrt {1-v^2/c^2}[/tex] . So if that is what you mean, then we are obviously in agreement. I am glad we straightened that out.
Note that v is speed.
Are we in agreement then? Has it been straightened out?
No.
I had already provided an example:
2 twin scenatio with identical acceleration, with the same distance where second twin is accelerated, but with 2 different "arms" - total travel distance where the accelerated twin is moving without acceleration
Based on your hypotesis, age difference will be the same in both cases (as acceleration is identical), while it is not (in a case with a longer arm there is more difference)
I believe so, yes. We use the same formula for making predictions about clock rates and elapsed time. Everything else is either a philosophical argument about alternative interpretations of the same equations or a semantic argument about the best way to translate the math into English.
"To translate the math into English..." Let me finish that for yah... "Which is basically impossible, and totally impossible right now for SQM."
It's true, but it does make life a little difficult sometimes.
For a couple of good discussions of this, see p. 9 of Dieks http://www.phys.uu.nl/igg/dieks/rotation.pdf and this page by Baez http://math.ucr.edu/home/baez/physics/Relativity/SR/clock.html . I find Dieks' argument very persuasive and physically enlightening; you don't need a separate postulate, because it follows directly from SR. Both Baez and Dieks agree that this statement of clocks holds iff the clocks are small enough (infinitesimally small).
I have seen in many places and accept that the traveling twin clock slows with respect to the Earth clock caused by relativity.
Can anyone explain or point to an explanation for how this mechanism works.
Thanks DaleSpam. I thought that my original statement that precipitated the confusion was really pretty innocuous and not very informative -- and, I'm glad you've helped confirm that. :smile:
And I remain absolutely amazed and fascinated by the physical phenomenon of differential aging.
Dmitry67 said:
No.
I agree that if you run one clock longer at the higher speed, even though the acceleration histories are otherwise identical, then that clock will accumulate less time.
Neither your scenario nor the clock postulate-hypothesis contradict the statement that changes in speed (accelerations) affect the periods of oscillators (the tick rates of clocks).
I think part of the original problem is the wording of statements like this. All changes in speed involve acceleration, but not all accelerations involve changes in speed. They are not always equivalent.
I think Baez said it well in the link bcrowell provided above, and I would highly recommend a careful reading of it. But in the end, if we use the same equation then in my book we agree on everything important.
The only thing that makes me want to point people to Dieks in addition to Baez is that Dieks explains how it's not necessary to make it a separate postulate. It follows logically from the usual postulates of SR.
If the clocks accumulate less time for longer periods at high speed, then the acceleration has to cause a permanent change in speed, not just a change in speed while the clock is accelerating. Is that what you mean, because your wording doesn't imply that to me.
Sure that's a true statement, but incomplete, since the following statement is just as true:
When the velocity (relative to the observer) of the traveling clock changes (when the clock is not accelerated), then its tick rate (wrt the observer) changes.
So while your statement is perfectly true, it would be just as true if the clock doesn't accelerate, and for the same reason.
So a more precise statement would be: If the relative velocity of a clock changes (whether it accelerates or not), then its tick rate (wrt the observer) changes.
As an example, in the start of the twins paradox, the ship accelerates away from earth. The tick rate of Earth's clock (the periods of oscillations of Earth's clock) changed relative to the ship observer due to the change in the relative velocity of Earth's clock relative to the ship. Would you say that the tick rate of Earth's clock was affected by the ship's acceleration?
Hmmm... I suppose that would depend on which frame of reference you looked at. If you were born on that ship during its accelerating period you'd percieve the tr on Earth to be faster relative to your own clock. From the point of view of a third observer at rest relative to the ship and Earth, what would they percieve? Wouldn't the change in tick rate be purely a matter of which Intertial Frame you happen to be in? A third observer is still going to agree on the order of events and the way they unfold will be consistent, regardless of which tr you decide is valid. They are, after all... relative, aren't they?
DaleSpam said:
Hi DaleSpam,
Good reference. I am quite familiar with the different versions of the diagram shown in that reference.
But I have a problem.
When the earthbound twin is the observer (presumably inertial) I plot events for the earthbound twin using the orthagonal axes and for the astrounat twin plot events using rotated axes. That's what I see shown in the diagram.
So far so good.
But the skeptic wants to see corroboration. The skeptic asks "What about when the astronaut is the observer?" So I draw the diagram with the astonaut as the observer. So then the astronaut gets events ploted using the orthagonal axes and the earthbound twin gets events ploted using the rotated axes. The diagram looks the same but the people and agings are reversed.
I get a parodox.
But the time read by an ideal accelerated clock surely it requires an additional definition, as Dieks's limit, ie. the proper time. As I understand it, the clock hypothesis is a definition of an ideal clock.
MikeLizzi said:
Hi DaleSpam,
So far so good.
I get a parodox.
You're missing something. In the case of the astronaut both observers on Earth and "the rocket ship" agree that the rocket is accellerating in relation to a (relatively) stationary Earth. If you're going to invert the experiment the way you did, then you have to take into account that both Earthbound observers and the Astronaut need to "agree" that the EARTH to be accelerating away from the astronaut. It's one of those "lost in translation" issues between the math and the thought experiment.
What matters is what is under acceleration relative to the Intertial Frames you're comparing it to (returning to in the case of the astronaut, to Earth). The body under acceleration experiences the effect, and in this thought experiment we can't equivocate "velocity and acceleration", because an astronaut MUST undergo a period of acceleration and then braking in relation to his initial Frame.
Thanks for your reply Frame Dragger. I am familiar with the arguments you present. But I was talking about using a Minkowski Diagram to describe the the action when the astronaut is the observer. What do your arguments have to do with that? I'm asking how one draws a Minkowski Diagram for the Twins problem when the astronaut is the observer.
That's easy... http://en.wikipedia.org/wiki/Twin_paradox Halfway down this issue is addressed. Here is the relevant portion...
Wikipedia said:
Difference in elapsed times: how to calculate it from the ship
Note that the above formula
(here τ is another customary notation for the time of the non-inertial observer K') gives us the dependence of the proper time τ on the time elapsed in the inertial frame K, assumed the velocity v(t) is known. Actually, this equation answers the problem of the dependence between proper time and inertial time for the inertial observer at rest in K but not for the moving observer. Indeed, the data v(t) is not always easily accessible from the ship. The observer in the non-inertial frame K' may find it difficult to measure its velocity with respect to K, not to mention that this velocity has to be parametrized with respect to the inertial time of K, a step which needs the dependence between proper and inertial time to be known in advance. Can the non-inertial observer predict what will be the time elapsed for the twin which remained at home using only easily accessible data? The answer is affirmative and at least for a unidirectional motion has a simple answer given by[10]
where a(τ) is the acceleration of the non-inertial observer as measured by himself (for instance with an accelerometer) in the whole round-trip and should not be confused with the non-relativistic acceleration d2x / dt2. It can also be shown that the inequality Δt > Δτ follows from the previous expression by using the Cauchy-Schwarz inequality:
Check the page for the equations, I can't copy-paste them, and I'm not writing them out here when I can link lol.
Frame Dragger:
Your response and the wikipedia reference have nothing to do with the issue I presented.
MikeLizzi said:
Frame Dragger:
Both address the issue that no paradox arises from a formulation of diagram from the "traveler's" Intertial Frame.
Frame Dragger:
I sorry but that's not what I was asking about. I guess I didn't explain myself very well. I was asking how you draw a Minkowski Diagram for the twins problem with the astronaut as the observer. The diagram in the wikipedia article is with the earthboud twin as the orserver.
I should add a little more or I will appear impolite. The rule that I understand for building a minkowski diagram is that the observer gets the orthagonal axis. There is no way the person with the orthagonal axis can come out younger. The wikipedia article says that the observer must adjust the earthboud twins time during the turn around. That's llike saying "Well, we don't get the right answer if we follow the rules so let's add another rule." Time doesn't jump, not for anybody.
MikeLizzi said:
Frame Dragger:
Ah... I thought your problem was the apparent paradox. I see. I don't know how to draw a Minkowski Diagram from the TP from that point of view. I see why you're having a problem... sorry about the confusion on my end.
Here is an excerpt that might help: http://www.springerlink.com/content/j603l05128p27727/fulltext.pdf?page=1
Hi again,
Yep. I scanned the article that you reference. I've read so many of these I can't go through them anymore. That reference is just repeating, using slightly different language, what the wikipedia article said. They all require the astronaut to add a time jump to the earthbound twins clock. Now somebody's clock can go slower or faster than yours but it can't jump. It would lead to all kinds of paradoxes. Solving a problem by including an artificial jump to somebody's clock is not doing physics. Its playing games with a calculation to make sure the numbers come out right. What is really happening is that the astronaut determines the earthbound twin's clock is running FASTER than his during the spaceship turnaround. Skipping that calculation is why this artificial jump needs to be added.
Calculating proper-time
For those who want to do a proper-time calculation that doesn't involve jumps, and have access to Maxima, the script below does this. It calculates the position, velocity etc for a space-ship fillowing a worldline defined by
[tex] x = t^2(t^2-2)d[/tex]
d is a parameter ( actually the furthest point reached). This worldline describes a comfortable trip along the x-axis and back again to base. The journey will last 2 time units on the base clock.
The script plots the variables and works out the time on the ships clock.
( Warning : this script may be wrong. I cannot be held responsible for any problems it may cause)
Code:
This script calculates the velocity and acceleration
required to make a 'comfortable' return journey to a point
d units away in 2 time units. The proper length of the
trip is found.
/* plot the position function xt = d*(t^2-1)^4 */
/* d is the furthest point on the trip. The Romberg integration fails around d=1/2  */
d:1/100; /* change this to do different trips */
xt:d*t^4*(t-2)^4;
wxplot2d([xt], [t,0,2]);
/* Get velocity */
vt:diff(xt,t,1);
/* plot velocity */
wxplot2d([vt],[t,0,2]);
/* get acceleration */
diff(vt,t,1);
/* plot acceleration */
wxplot2d([%],[t,0,2]);
/* Proper time by numerical integration */
romberg(sqrt(1-(vt)^2), t, 0, 2);
/* try some different trips */
d:1/50;
xt:d*t^4*(t-2)^4;
vt:diff(xt,t,1);
d:1/20;
xt:d*t^4*(t-2)^4;
vt:diff(xt,t,1);
d:1/10;
xt:d*t^4*(t-2)^4;
vt:diff(xt,t,1);
d:1/5;
xt:d*t^4*(t-2)^4;
vt:diff(xt,t,1);
This is all very interesting... but what's the value in it? I understand the philosophical objection to cutting corners, but there is a reason the corner is often cut; it can afford to be.
Mentz has kindly and clearly showed the "how", but I'm still a bit confused as to the "why", except as a mental exercise.
The astronaut is a non-inertial observer. There is no Minkowski diagram in which his worldline is straight.
In Minkowski diagrams inertial observers have straight worldlines, and two Minkowski diagrams are related to one another via a Lorentz transform, which is a linear transform. Because it is a linear transform if a line is bent in one Minkowski diagram it will be bent in all of them.
I still reiterate my question about the purpose of this. A skeptic already has better direct observations which confirm SR/GR than a thought experiment. Is this just spinning the mental wheels?
Hi Frame Dragger:
The skeptic is asking for corroboration. We solve the problem from the point of view of the earthbound twin because its the easier task. Since we believe SR is internally consistent, we are satisfied. But the skeptic asks "How can you get a corroborating answer from the point of view of the astronaut?" To the skeptic, trying to work the problem on a Minkowski diagram, it looks like you draw the exact same diagram, only with the twins switch places. And that would be a paradoxical answer.
