Distance and acceleration problem
  • Context: Undergrad
  • Thread starter Thread starter quick
    Acceleration
The discussion centers on solving a distance and acceleration problem using the quadratic formula. The key conclusion is that for the minimum speed \( c \) to yield a real value for \( t_{catch} \), the discriminant must be non-negative, specifically \( c^2 - 2ab \geq 0 \). The expression for \( c_{min} \) is derived from setting the discriminant to zero, resulting in \( c_{min}^2 = 2ab \). This establishes the relationship between speed, acceleration, and distance in the context of the problem.
  • Understanding of quadratic equations and the quadratic formula
  • Knowledge of basic physics concepts such as distance, acceleration, and speed
  • Familiarity with discriminants in polynomial equations
  • Ability to manipulate algebraic expressions
  • Study the application of the quadratic formula in physics problems
  • Research the implications of discriminants in determining the nature of roots
  • Explore the relationship between acceleration, distance, and time in kinematics
  • Learn how to derive equations of motion from basic principles
Students and educators in physics, mathematicians dealing with quadratic equations, and anyone interested in solving kinematic problems involving distance and acceleration.
quick
this picture shows the problem:
http://s93755476.onlinehome.us/phys.jpg
i realize the discriminant must be positive for t_catch to have a real value. i just can't figure out how to write an expression with a and b. thanks in advance.
Realizing that the discriminant must be greater than or equal to 0 is really the whole problem. The minimum speed, c, will give a discriminant of 0 (i.e., cmin2 - 2ab = 0). Just solve for cmin and plug back into your expression for tcatch from the quadratic formula.
how do i solve for c_min?
cmin2 - 2ab = 0
sorry I am retarded, i didn't read your response correctly. thanks for your help!
if you have a quadratic formula:
ax^{2} + bx + c = 0
the solution for its roots is:
x = \frac {-b {+-} \sqrt{b^{2} - 4ac}}{2a}
now your equation is{
\frac{1}{2}at^{2} - ct + b = 0
so the solution to have a positive x walue would be easy to find, just sub in your constants in the equation above:
x = \frac {-(-c) {+-} \sqrt{(-c)^{2} - 4((\frac{1}{2}a)(b)}}{2(\frac{1}{2}a)}
x = \frac {c {+-} \sqrt{c^{2} - 2ab}}{a}
so in order to have a positive x value, there must be a positive root,
c^2 - 2ab > 0
there is your answer. Do you understand now?
Hmm, I don't see the connection to the original question.
what don't you see about it, the question is asking to express the minimum values of the mans speed in terms of a and b. As long as
c^2 - 2ab > 0
there is your answer. The min value would be:
c^2 - 2ab = 0
