Proving the Solution a=4 and n=2 for a^(1/n) = √a; a>0, n>1
  • Context: Undergrad
  • Thread starter Thread starter TylerH
The discussion revolves around proving that the equation \( a^{(1/n)} = \sqrt{a} \) has the unique solution \( a = 4 \) and \( n = 2 \) under the conditions \( a > 0 \) and \( n > 1 \). Participants explore various mathematical approaches and implications regarding the nature of solutions, particularly focusing on integer solutions.
  • One participant questions whether \( a = 4 \) and \( n = 2 \) is the only solution or if it is the only solution with natural numbers.
  • Another participant suggests plotting the functions to observe their behavior, indicating that the shape appears almost linear.
  • A mathematical transformation is presented, leading to the expression \( a = n^{(n/(n-1))} \), which is argued to have only one integer solution if \( n \) and \( a \) are natural numbers.
  • Concerns are raised about the dependency of the solution, questioning how it can be asserted that \( n^{(n/(n-1))} \) has only one integer solution.
  • Further mathematical manipulation leads to the conclusion that for integer values of \( n \), the only integer solution occurs when \( n = 2 \).
  • A participant reflects on their earlier question regarding the imposition of restrictions on possible values of \( a \) and \( b \), suggesting that \( a \) must be a power of \( b \) to avoid extraneous factors.
Participants express differing views on whether \( a = 4 \) and \( n = 2 \) is the only solution, with some suggesting there may be infinite solutions under broader conditions. The discussion remains unresolved regarding the uniqueness of the solution.
Participants note that the discussion is limited to integer solutions and that assumptions about the nature of \( a \) and \( b \) may affect the conclusions drawn.
TylerH
[tex]\frac{a}{n}=\sqrt[n]{a};a > 0;n>1[/tex]
How do I prove that a=4, and n=2 is the only solution? I'm pretty sure it is, but I don't know how to prove it.
the only solution or the onl solution with natural numbers??
If is the only solution you could try to plot it to see how they behave
a/n=b a^(1/n)=b
b*n = b^n
n=b^(n-1)
b=n ^(1/(n-1))
a= n^(n/(n-1))With this you can see that if n and a has to be natural there is only one sol and if they don't there are infinite ones.
You were correct in assuming that I meant integers. I also plotted it. The shape is interesting, it almost appears linear. Thanks for your help, much appreciated.
Wouldn't that result in a dependency? How can you say n^(n/(n-1)) has only one integer solution?
n^(n/(n-1))=n^(1+1/(n-1))=n+n^(1/(n-1))
for integers values of n
n= integrer
a=n^(1/(n-1))= only integrer for n=2;
dem: function is decreasing , for n=2 , a=2 for n -> inf a=1
Oh... that was a dumb question... Thanks. :)
Here's why I was asking:
(aside: how do I impose restrictions on the possible values of a and b? Like say that they must not be equal and that they must be integers?)
[tex]a^b=b^a[/tex]
Which implies that b must equal a, by a factor, n, and a must equal b by a power of 1/n. To make it easier, I'll switch the n and 1/n, since the actual value doesn't matter, just the relation. We can also assume a must be a power of b, because otherwise there would be extraneous factors, making it impossible for them to be equal. Thus we have:
[tex]\frac{b}{n}=a;a^n=b[/tex]
Which you can tell is very similar to the question posed, except the original was simplified.
[tex]an=a^n[/tex]
[tex]n=a^{n-1}[/tex]
[tex]a=\sqrt[n-1]{n}[/tex]
  • · Replies 21 ·
  • · Replies 25 ·
