How to work out frictional torque
  • Thread starter lew123189
    Torque Work
37 replies · 42K views · last reply
lew123189
how to work out "frictional torque"
A Mass of 0.5 kg is suspended from a flywheel. If the mass is released from rest and falls a distance of 0.5 m in 1.5 s, calculate
the tension on the rope
the frictional torque, resisting motion
Mass of flywheel = 3 kg
radius of wheel = 300mm
radius of gyration = 121mm
so this is what i have worked out so far
velocity = d/t = 0.5/1.5 = 0.33
angular acceleration = (max mass velocity - initial velocity)/time = 0.33- 0 / 1.5 = 0.22
now i think tension = mass X (gravity X acceleration)
however i am not sure what acceleration they mean is it the angular or linear acceleration.
Torque = moment of inertia X angular acceleration
= (0.5X0.212squared)X0.22
= 0.022472 X 0.22 = 4.94X10 to the power of -3
so what i need to know is how to find the "frictional torque" and the "resisting motion"
thanks in advance
Lewis
also, can you work out torque by:
Mass X radius of pulley
(0.5X9.81(gravity))X0.3 = 1.4715N
You need to apply Newton's 2nd law to the flywheel and to the hanging mass:
ƩTorque = I*alpha (for the flywheel)
ƩF = m*a (for the hanging mass)
Start by identifying the forces acting on each.
Note:
ƩTorque means net torque; there are two torques acting here.
Similarly, ƩF means net force.
This is not angular acceleration, This is the calculation for linear acceleration.
a) The linear acceleration of the mass.
v = s / t
a = v / t
b) The angular acceleration of the wheel
Omega = v / r
Knowning that v = Linear Velocity / r = radius of flywheel
This provides angular speed (rad s^-1)
Alpha = Omega / t
c) The tension in the rope.
F = mg - ma
Is this equation correct?
d) The frictional torque, resisting motion
T = m x k^2 x aplha. This is accelerating torque
Just struggling to understand how to calculate the Total Torque required.
Is Tnet F = ma, so mass of flywheel by a
Then frictional torque is
Tf = Tnet - Ta
Does this seem correct?
Ok so this is were I am so far after taking your advise
Linear acceleration = mass max velocity – initial velocity/ time
= 0.33-0/1.5 = 0.22 ms -2
Angular acceleration = max wheel speed – initial wheel speed / time
Max wheel speed = velocity / radius = 0.33/0.3 = 1.1 rad s -1
So angular acceleration = 1.1 – 0 / 1.5 = 0.73 rad s -2
Now is net torque = moment of inertia X angular acceleration
Moment of inertia = MK 2
= Mass of wheel X radius of gyration squared
= 3X0.212 squared
=0.134 KG m squared
Net torque = 0.134 X0.73
= 0.9842 NM
Net force = MXA
= 0.5 X 0.219
= 0.1095
So would frictional torque be net torque – force of hanging object
= 0.9842-0.1095 = 0.8747 NM
Frictional torque = 0.8747 NM ?
could the tension in the rope simply be mass X acceleration = 5 X 0.219 = 1.095
or does gravity have to play a part?
would this make more sense?
= 5 X(9.81 X 0.219) = 10.74 ?
That would be the average velocity, not the velocity after 1.5 seconds.
All forces acting on the hanging mass play a part. What forces act on it?
No.
As I suggested before, apply:
Start by figuring out the correct linear acceleration of the mass.
I see that makes sense. I am struggling to figure out maximum velocity.
How about this
VMAX
Potential energy of mass = MGH
=0.5X9.81X0.5
= 2.45 J
Kinetic energy at bottom = potential energy at top
Thus ½ MN 2 = 2.45J
Were V is velocity immediately before bottom
Therefore ½ X 0.5 X V 2 = 2.45
V = square root of 2.45 X2 /0.5
Velocity immediately before bottom = 3.13 ms -1
Maximum velocity of mass = 3.13 ms -1
Therefore maximum velocity of pully = Vmax / radius = 3.13 / 0.3 = 10.43 rad S –1
= 10.43 rad S-1
but I am not sure if this equation only applies when mass is falling free and hits the ground
You found the average velocity. How does that relate to the final velocity, since the object started from rest?
How about this
VMAX
=0.5X9.81X0.5
= 2.45 J
That won't work because you've neglected the kinetic energy of the flywheel. (Total mechanical energy is conserved.)
How about forgetting about the velocity and solving for the acceleration directly? What kinematic formula relates distance, time, and acceleration?
•d = vo • t + 0.5 • a • t2
•vf = vo + a • t
•vf2 = vo 2 + 2 • a • d
•d = (vo + vf)/ 2 • t
where
•d = displacement
•t = time
•a = acceleration
•vo = original or initial velocity
•vf = final velocity
these are the only kinematic equations i could find. seems hard to find the final velocity without accereration or the other way round.
The first one will do just fine, since you have the time and the distance. Plug in the values and solve for the acceleration.
If you wanted to find the final velocity, you could use the fourth equation in your list. But you don't have to.
I see I guess I have to make a the subject?
I'm not very good at this
D-1/2xaxt2=v1xt
1/2xaxt2=[v1xt2]+d
So
1/2a = (v1xt2)+d/t2
How does that look? Also by t2 are they referring to time again?
Cheers
Yes, you need to solve for a.
Better to write this as:
d = v0t + 0.5at2
I would plug in the values and then solving for a will be easy.
What are the values of d, v0, and t?
Apologise in advance I'm not good at these
D=volt+0.5at2
=0.5=0x1.5+0.5xax1.5(2)
=0.5=0.5xax1.5(2)
=ax1.5(2)=0.5/0.5
=ax1.5(2)=1
=a=1/1.5(2)
=a=1/2.25
=a=0.44
Cheers
OK so
Linear accereration = V/T
=0.33/1.5 = 0.22
2 (D-volt)/T(2) = A
A = 2(0.5-0)/1.5(2) = 0.44
Angular acceleration = 0.44
VF= final velocity
VF=Vi+AT
VF=0+0.44X1.5
VF=0.66
Moment of inertia =
=MXradius of gyration (2)
=0.5X0.212(2) = 0.022472
Net torque of wheel = IXalpha
= 0.22472X0.44
=0.0988 N
Net force of hanging mass = MxA
= 0.5X0.22
=0.11 N
How does this all look?
still not sure how "frictional torque" and the "resisting motion" goes into it.
thanks a lot
D=volt+0.5at2
=0.5=0.5xax1.5(2)
=ax1.5(2)=0.5/0.5
=ax1.5(2)=1
=a=1/1.5(2)
=a=1/2.25
=a=0.44
Cheers
OK, this is the linear acceleration of the falling mass (in m/s^2).
Use this to:
Figure out the angular acceleration of the flywheel.
Figure out the tension in the rope.
Hi, can I continue with this question?
Using the last post I find:
Angular acceleration = linear accel / radius
=0.44/0.3 = 1.481 rad/s^2
Then Doc as you said previously find net force and torque:
Net Force = ma = 0.5*0.44 = 0.22N
Net Torque = I*alpha = mk^2 *alpha = 0.636 * 1.481 = 0.942NmSo, providing this is correct, how do I then find the frictional torque? or which one is which etc?Would I just need to add the two together?
Good.
Use this to find the tension in the rope. Once you find the rope tension, then you can find the torque it produces.
Redo this calculation.
You'll solve for the frictional torque using Newton's 2nd law for rotation:
ƩT = I*alpha
You have two torques acting: Trope & Tfriction (acting in opposite directions).
So ƩT = Trope - Tfriction = I*alpha
Thanks for the reply!
So,
Tension in rope F = ma + mg = (0.5*0.44)+(0.5*9.81) = 5.127N
The torque for the rope is therefore Trope = 5.127*0.212 = 1.087Nm
Then, from my mistake at squaring earlier (thanks for pointing out):
Net Torque = I*alpha = mk^2 *alpha = 0.135 * 1.481 = 0.199935Nm = 0.2Nm
So therefore TFriction = 1.087 - 0.2 = 0.887Nm
Does that sound right? I was expecting a bit less friction I suppose...But maybe I'm just doubting my own competence now. haha
saucysaunders said:
So,
Careful with signs:
ƩF = ma
F - mg = ma
But the acceleration is downward, thus negative. (Using the up = + convention.)
I understand acceleration is downwards, but using the neg figure would give tension as -5.127N
Can you have a negative tension? Should I therefore be using this negative answer to work out the Rope torque?
That's not correct. Show how you got that. (Only the 'a' is negative.)
If your using the Newton's second law for rotational motion
τ=αI
You have to make sure the units are correct.
Torque is not Nm it's J/rad.
1 Nm is 2π J/rad
Moment of Inertia stays as kg.m2
Going back to basic units
[(kg.m^2)/(s^2)]/(rad)=(kg.m^2)(rad/s^2)
τ=αI
1 Nm is 2π J/rad
Standard units for torque are N-m. (You can use J/rad, but that isn't helpful here.)
I was confusing myself, by ignoring the fact that the wheel turning actually makes the tension in the rope less. It's all coming together now I think...
Tension in the rope Ft = (0.5* -0.44) + (0.5*9.81) = 4.685N
Torque in the rope = 4.685 * 0.212 = 0.993Nm
So Frictional Torque = 0.993 - 0.2 = 0.793Nm (Lower than previous answer as I said before)
If I then convert to J/rad as moto explains:
0.793Nm * 2π = 4.98 J/rad
It is if you're using angular acceleration rad/s2 not m/s2
Torque = I*alpha, where torque units are N-m and alpha units are rad/s2.
Good.
Don't do that!
Your wish is my command oh great one :P
Thanks for the help!
