Solve speed with the help of f (x) to f ' (x)
  • Thread starter Thread starter mimi.janson
    Speed
The discussion revolves around a function representing the relationship between time and distance for a person running, specifically f(x) = -0.8x^4 + 3.2x^3 + 0.4x^2. Participants are exploring how to derive the speed function from this position function and are addressing specific questions about calculating speed at a given time and determining when the maximum speed occurs during a three-hour run.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss differentiating the function to find the speed as a function of time, with some uncertainty about whether to evaluate the original function or its derivative for speed. Questions arise regarding the interpretation of negative values in the context of speed and velocity, as well as the conditions for maximum speed.
There is an ongoing exploration of the correct differentiation of the function and its implications for speed and velocity. Some participants have provided clarifications on the distinction between speed and velocity, while others have pointed out potential errors in calculations. Multiple interpretations of the problem are being discussed, particularly regarding the maximum speed and the behavior of the function over time.
Participants are working under the constraints of a homework assignment, which includes specific questions about speed and maximum velocity over a defined time period. There is also a noted confusion regarding the mathematical representation of speed versus velocity, which is contributing to the discussion.
mimi.janson
I need to solve questions about f (x) to f ' (x)
hi i have the function f(x) = -0,8 x^4 + 3,2 x^3 + 0,4 x^2
The function explains the realationsship between time and place while a person is running. (can also be called distance and time). Besides i got told that the person runs for three hours
A) First i get asked to write something that shows the speed as function of time.
So i thought of differentiating it, since that will tell me a lot about the slope.
f ' (x)=-32 x^3 + 9,6 x^2 + 0,8 x
B) so my second question was to find out how fast the person runs after 2 hours. Since i know that x is the time and y is the distance i know that i only have to put 2 in the place of x in my function ...i am though not sure if it is in f(x) or f ' (x) but i believe it is in f ' (x) since that was the one telling about the speed.
so i solved it this way
f ' (2)=-32 *2^3 + 9,6 *2^2 + 0,8*2
f ' (2)=-256 + 38,4 + 1,6
f '(2) = -216
but there is something wrong here since the speed cannot possibly end up being a negative result ? so i would like someone to show me what i am doing wrong here.
C) last i have a question that asks me to find out where out of the three hours the person runs with the fastest speed ...i don't really understand how i can solve it.
i think i might need to use a second quadratic equation but i don't really understand it so if someone could help me with understanding please
First i would like to say that I am sorry i firstly posted this thread on a wrong place. So i hope i put it right this time
f '(2) = -216
The bolded is not right. It should be -3.2.
While the answer for f'(2) will be positive, it's possible for the velocity to be negative (speed is the magnitude of velocity). In the case of a person running, he/she would be running backwards.
f '(2) = -216
You are confusing *speed* and *velocity*. Speed is the magnitude (absolute value) of velocity, so is always >= 0; however, velocity can be < 0. For example, if I measure positive distances as being to the East of the origin and negative distances to the West, then a positive velocity means traveling towards the East while a negative velocity means traveling towards the West. However, the speedometer in my car will always give a reading >= 0: it measures speed. In your case, if x = time and f(x) = position, then f'(x) = _velocity_, not speed.
You wrote f ' (x)=-32 x^3 + 9,6 x^2 + 0,8 x, which is not correct; it should be f '(x)= -3,2 x^3 + 9,6 x^2 + 0,8 x. Note that f '(2) > 0, but for larger x the velocity would be < 0; for example, look at x = 4.
RGV
Don't think of the derivative as "the slope". The derivative of a function f(x) is another function that represents the rate of change of f(x) at any point x. The rate of change is the slope of the tangent line to that graph of f(x) at point x.
Anyway, for part B: Do you know the relationship between the position (x) function and the velocity (v) function? Since your position function seems to be in terms of t, you can find the velocity at time t using the derivative assuming your units check out.
edit: speed cannot be negative, but velocity can, as long as your math is correct, and you represented v(t) as x'(t), you're good. edit 2: and your math is not correct, check that first :)
C: What happens to the position function when its derivative equals 0? What happens to the velocity function when the acceleration function equals 0?
Right idea, but check this step
Reported.
  • · Replies 25 ·
  • · Replies 17 ·
