Has CERN Confirmed the Existence of Antimatter?
  • Context: High School
  • Thread starter Thread starter Vitruvian Man
    Antimatter Cern
The discussion revolves around the existence and production of antimatter by CERN, its potential applications, and the implications of its use, particularly in energy generation and weaponry. Participants explore theoretical and practical aspects of antimatter, including its efficiency as an energy source and the challenges associated with its production and containment.
  • Some participants assert that CERN has confirmed the existence of antimatter and is producing it, albeit in minimal amounts, suggesting it could revolutionize energy sources.
  • Others argue that while antimatter annihilation is theoretically 100% efficient, practical energy generation is hindered by the energy required to produce antimatter, making it impractical as a power source on Earth.
  • One participant mentions the potential for antimatter to be used as a weapon, raising ethical concerns about its misuse.
  • There are discussions about the production rates of antimatter, with some citing figures of pico-grams to grams per year, and the feasibility of harvesting antimatter from solar phenomena.
  • Theoretical proposals include using solar wind protons to create antimatter, though challenges related to energy requirements and efficiency are noted.
  • Participants share historical context regarding antimatter, referencing early discoveries and its applications in medical imaging, such as Positron Emission Tomography.
  • Concerns are raised about the safety and implications of using positrons in medical procedures, with anecdotal experiences shared by participants.
Participants express a mix of agreement and disagreement regarding the efficiency of antimatter as an energy source, the practicality of its production, and the ethical implications of its potential uses. No consensus is reached on these points.
Limitations include unresolved questions about the energy balance in antimatter production, the definitions of efficiency in different contexts, and the practical challenges of large-scale antimatter generation.
Vitruvian Man
Humble apologies if a thread regarding this has already been started.
I was just browsing through the net and got to read about antimatter.It is already proven by CERN that it is not a rumour but truth that it does exist and CERN is producing it in minimal amounts.It is something which I believe would change the whole phase of the world as we finally have a 100% efficient energy source.But with it being so very volatile that when it comes in contact in with any sbstance in the air, it would lead to an annhilation.Hence, all those antimater specimens are kept under vacuum.
But the big debate is weather it would fall in the hands of the evil, i.e used to make the most dangeround wepon known to man.Loads to think about and look forward to I believe.
One may wish to refer to http://hussle.harvard.edu/~atrap/News/2002/PressRelease.pdf
Anti-matter/matter annhiliation is effectively 100% efficient, The main reactions of proton-antiproton (and neutron-antineutron) annihilations to several pions and photons, ie. p + \bar{p} and n + \bar{n} to multiple \pi^+, \pi^-, \pi^o, \gamma, and then the charged pions decay into appropriate muons and muon-associated anti-neutrinos and the muons then decay into electrons and neutrinos. The neutral pions decay into gammas or gammas/electrons.
See - http://hyperphysics.phy-astr.gsu.edu/hbase/particles/hadron.html#c2
Overall, anti-matter is not a practical energy source on Earth since it takes way more energy to make that one would recover. It does conceivably make a very nasty weapon, assuming one can confine a substantial quantity. (Personally, I think mankind has better things to do than devise ways of annihilating itself).
IIRC, maximum production rates of anti-matter are on the order of pico-grams per year, although I have seen one site that claims up to one gram/year, but that seems to high, and anyway it is certainly not confined, but rather in beam form.
For more practical applications of anti-matter see - http://www.engr.psu.edu/antimatter/documents.html
Nope, sorry but I (entropy) won't allow you to have 100% efficiency. :devil: Bwhahaha!
Although anti-matter is best fuel in terms of energy per unit mass. It probably won't have any use in producing power other than for spacecraft s. You see when anti-matter is created you need energy to create it. Energy that comes from solar, nuclear, coal, or what have you.
Entropy,
Entropy is a statistical mechanical phenomenon; it does not exist in the microscopic domain. The conversion of matter and antimatter into radiation is 100% efficient.
- Warren
chroot said:
Entropy,
- Warren
True.
But in the macroscopic domain, would you agree that a proporton of photons would be lost as heat in the process? Hence the efficiency of the system would be determined by this factor, and the entropy increase.
This would be unavoidable on the large scale reactions that may be required to produce energy in the future. Ultimately 100% efficiency is pretty much unattainable in practicality.
The manufacturing problem is indeed formidable, here on Earth. However, it may be possible (in the distant future) to harvest antimatter from a nearby, solar-powered antimatter generator: the sun. Solar astronomers have observed phenomena which indicate that some solar eruptions can produce more than a pound of antimatter.
I was thinking, wouldn't it be theoretically possible to set up a large array, made up of the same material used to produce antimatter on earth, and harness the huge amount of protons in the solar wind to create antimatter. The high volume of protons should produce at least grams of antimatter over the course of a year, depending on how close the array is to the Sun.
It takes at least a 6 GeV proton hitting a stationary target to produce an antiproton. This is equivalent to about 2 GeV in the center of mass. This is what Segre and Chamberlain did about 1956 to discover antiprotons. The solar protons are very low energy.
Bob S
this is like the film angels and demons, but you would need a heck of a lot of time and energy t make nearly enough, cern has only made a tiny amount :D
Antimatter is nothing new. The first experimental observation was by Carl Anderson in 1932 for which he receive the 1936 Nobel prize.
Copius beams of antimatter have been used at Stanford and elsewhere for many years, and for medical purposes as well.
The CERN LHC is just the newest of many antimatter factories.
Vitruvian Man said:
...minimal amounts.But with it being so very volatile that when it comes in contact in with any sbstance in the air, it would lead to an annhilation.Hence, all those antimater specimens are kept under vacuum.
Certain radioisotopes provide a good source for anti-matter .
You're not evil are you? :))
OK; Sodium 22 is a positron emitter, and you get gammas and neutrinos to boot.
http://discover.positron.edu.au/making-our-own-antimatter/radioactive-decay/
Fluorine-18 is another ...positrons...had it put in my blood one time...not fun.
Be careful...
Creator
Be careful...
Creator
Dare I ask why?
MathematicalPhysicist said:
Dare I ask why?
They tell me I will die if I don't let them do it. They call themselves radiation oncologists ... I call them terrorists.
They inject me with radionuclides, tell me not to move for 1 hour, positrons get into all my organs, the resultant gamma rays shoot out from everywhere inside my body...I pray... they take pictures.
$6500 per pop.
If you are wondering why your Mediacal insurance premiums are going up, you can blame me...and Obama of course. :))
$6500 per pop.
If they inject positrons into your body, shouldn't you be anihlated in a matter of minute seconds?!
Er...no; they may have tried to annihilate me, but I'm still here.
Positrons only annihilate with electrons...so they didn't get my neutrons and protons, he, he. :)) I may have become a little more electropositive than before, but not annihilated.
I was far more concerned with the coincident gammas that blasted through my organs... hopefully my DNA survived, and I won't grow an extra ear or something.
The F(18) half-life is just under 2 hours, so I wasn't emitting gammas for more than a day or so.
However, I did think about walking through the (heavily populated) airport security system to see if I could produce enough panic to "clear out" the airport. :smile:
Creator
It's been addressed already but making 1 gram of antimatter would cost you more than the energy released from that 1 gram of antimatter being annihilated. However whilst it doesn't represent the perfect energy source antimatter would be a great battery, a few grams of antimatter properly contained and able to be released in minute (pico/nanogram) quantities could keep things like deep space probes and the like operational for hundreds of years.
You've potentially stumbled on an answer to the Fermi paradox there (if space is so big and old and life is possible it should have happened many times, that being the case where the hell is everybody?). The energies needed to run an interstellar civilisation complete with relativistic transport implies antimatter production on the order of megatonnes per year. It would be like if every plane on Earth was fitted with a nuclear bomb that went off when the plane crashed. To easy for nutters to destroy worlds and wars to progress from opening-fire to genocide
Bob S
Is this reaction equation perfectly matched experimental results?
high energy ------->N proton + N anti-proton
or
high energy ------->N quark + N anti-quark
i.e., Has the same moles of proton(or quark) and anti-proton(or anti-quark) production been already proved experimentally?
