1999 AP Physics C Mech: Conservation of momentum and energy
The discussion revolves around the conservation of momentum and energy in a scenario involving a dart colliding with a block. Participants are examining the validity of energy conservation equations in the context of elastic and inelastic collisions.
  • Conceptual clarification, Assumption checking, Problem interpretation
  • Participants question the validity of specific energy conservation equations and whether the collision is elastic. There is exploration of the implications of momentum conservation versus energy conservation in the context of the collision.
Some participants have provided insights into the nature of the collision, noting that momentum is conserved while energy is not. There is an ongoing exploration of the implications of these principles in different frames of reference.
There is a focus on the definitions of elastic versus inelastic collisions and the dimensions of the terms used in the energy equations. Participants are also considering the effects of the collision type on the overall problem setup.
j04015
Check image
Why is (1/2)(mv0)^2 = 1/2(M+m0)gh not a valid equation for conservation of energy?
Isn't the energy from when the dart is shot the same as when the two masses move at speed v?
j04015 said:
Homework Statement: Check image
Relevant Equations: Conservation of momentum and energy
View attachment 336233View attachment 336234
Why is (1/2)mv0 = 1/2(M+m0)gh not a valid equation for conservation of energy?
Your question is whether the collision between the dart and block is elastic or not?
To answer the first question,
Because ##\frac{1}{2}mv_0## has dimensions of momentum and not energy.
Whoops, typo. I meant (1/2)(mv0)^2
If the collision wasn't elastic the entire problem doesn't make sense.
That statement is false!
... the collision is manifestly and totally inelastic!
I see the issue now. Momentum is conserved but not energy. Thanks!
You can see that if you consider what's going on in the center of mass frame. Before the collision, both dart and block move with opposite momenta. Total momentum is zero and the kinetic energy is non-zero. After the collision, the dart and the block are at rest. Total momentum is zero (conserved) and total kinetic energy is also zero (not conserved).
The conservation of energy equations will not be compatible with conservation of energy in any frame if you assume that the dart sticks. However, I agree that considering the com frame makes it very explicit.
  • · Replies 18 ·
  • · Replies 44 ·
  • · Replies 20 ·
