2.3 Exercises from the Feynman Lectures on Physics
33 replies · 3K views · last reply
new90
a body is acted upon by n forces and is in static equilibrium.Use the principle of virtual work t prove that
if n = 1 the magnitude of the force must be zero
no equation
i don't know what's the answer but I think that the force needs to be gravity because is going down to the floor
What if the body is the middle of outer space?
then there willl be work because there there will be a force pusing in some direction
Please try to understand what Professor Feynman meant by the words 'static equilibrium'.
new90 said:
i think it means that the body its not moving
It means that any force acting on the body in any direction is counter-balanced by a force acting in an oppositional direction.
Somewhere in your analysis you must use the principle of virtual work as the problem directs you to do. Write an expression in the case of a body at equilibrium when acted upon by ##n## forces and then see what happens when you set ##n=1##.
Also remember that the principle of virtual work says the virtual work must be zero for any infinitesimal displacement. Because you could easily choose ##d\vec{r}## to be orthogonal to the resultant force!
Well, equally true is that it must be non-zero for any non-zero force -- if it is infinitesimal it is still infinitesimally non-zero. Let's please not abuse zero while we are petting our pet inconsistencies . . .
Are you able to do it just by condition implied by static equilibrium? I mean do you know that ##\Sigma## notation for statics?
My apologies, I was being careless. I meant to say "for any virtual displacement".
In my view, the sigma notation, in this instance, refers to sum, I think that I don't quite fully understand your question . . .
but there's its says only one force
Does OP know this ## \sum_{i=1}^{n} \vec{F_i} =0## ?
new90 said:
I DINT KNOW THANKS
Do you know for Static Equilibrium we should have $$ \sum_{i =1}^{n} \vec{F_i} =0 $$ ?
new90 said:
i don't know what it means the n
$$\sum_{i=1}^{n} \vec{F_i} = \vec{F_1}+ \vec{F_2} + \vec{F_3} +... + \vec{F_n} =0$$ Are things a little clearer now?
new90 said:
but in this case its just
Fi= 0
If ##n=1## we have $$ \sum_{i=1}^{1} \vec{F_i} = F_1 = 0$$ How about now?
new90 said:
yes its clear
thanks
But you don’t have to do it like this 😅
You have to do it by the Principle of virtual work.
Principle of virtual work = the force x the virtual
displacement?
thanks I answered with principle of virtual work
Adesh said:
$$\sum_{i=1}^{n} \vec{F_i} = \vec{F_1}+ \vec{F_2} + \vec{F_3} +\dots+ \vec{F_n} =0$$
I 'corrected' your ##\LaTeX## ##-## you had 4 dots instead of 3 ##-## :wink: your math was just fine ##\dots##
  • Haha
It seems that you have adjusted it’s height too!
