Convergent Lenses: 2-Part Problem and Solution | Focal Point and Image Location
  • Thread starter Thread starter DrMcDreamy
    Convergent Lenses
This discussion focuses on solving a two-part problem involving convergent lenses and image formation. The first part establishes that for an object placed at a distance of p = 4/3f from the first lens, the image location q1 is determined to be 4f, indicating a real image. The second part requires calculating the image location q2 for a second lens placed at a distance f behind the first lens, where the image formed by the first lens serves as the object for the second lens. The solution involves using the lens formula 1/f = 1/p + 1/q to find p2 and subsequently q2.
  • Understanding of convergent lenses and focal points
  • Proficiency in using the lens formula: 1/f = 1/p + 1/q
  • Knowledge of real and virtual images in optics
  • Ability to manipulate algebraic equations for problem-solving
  • Study the principles of lens systems and their applications in optics
  • Learn about the behavior of light through multiple lens systems
  • Explore advanced topics in geometric optics, such as ray tracing
  • Investigate the effects of lens aberrations on image quality
Students studying optics, physics educators, and anyone interested in understanding the principles of image formation using convergent lenses.
DrMcDreamy
This is a 2 part problem but I figure out the first part. Heres the 1st problem and the solution:
7- Given a convergent lens which has a focal point f. An object is placed at distance p = \frac{4}{3}f to the left of the lens. See the sketch.
Solution: q1 = 4f, and is a real image
8- Now place a convergent lens with a same focal length f at a distance d = f behind the first lens. Determine q2, i.e., the image location measured with respect to the second lens # 2.
I will upload the actual image later.
Given:
p1 = \frac{4}{3}f
q1 = 4f
f1 = f
p2 = ?
q2 = ?
f2 = f
\frac{1}{f} = \frac{1}{p}+\frac{1}{q}
I would show my attempt at the solution but I don't know what is p2. How do I get p2?
*bump*
The image formed by the first lens is now the object for the second lens. Find out where the image forms with respect to the second lens. Without drawing a picture it looks like p2 is -3f. That is:
|--|------q1/p2
where "|" is a lens and "--" is one distance f. As you can hopefully see, q1/p2 is 4f infront of lens one and 3f behind lens two. So do what you did in part one but with p2=-3f.
Thank you!
My work:
3\frac{1}{f}-\frac{1}{-3f} = \frac{3-1}{3f} = \frac{4}{3}f (inverse) = \frac{3}{4}f
I have a similar problem here's my work but its wrong cause its not one of the answer choices:
Problem:
Consider the setup of the two-lens system shown in the figure, where the separation of the two lenses is denoted by d = 1.5 a. Their focal lengths are respectively f1 = a and f2 = 2 a. An object is placed at a distance 2 a to the left of lens # 1. Find the location of the final image q2 with respect to lens #2. Take q2 to be positive if it is to the right of lens #2 and negative otherwise.
Formula:
My Work:
p1 = 2a
q1 = ?
f1 = a
p2 = ?
q2 = ?
f2 = 2a
\frac{1}{q1} = \frac{1}{f}-\frac{1}{p} = 2(\frac{1}{a}) - \frac{1}{2a} = \frac{2-1}{2a} = \frac{1}{2a} (inverse) = 2a = q1
\frac{q1}{p2} = q1 = \frac{2a}{p2} = 2a \rightarrow \frac{2a x p2}{2a}=\frac{2a}{2a} \rightarrow p2 = 1
\frac{1}{2a}-(\frac{1}{1})2 = \frac{1-2a}{2a} = \frac{a}{2a} = \frac{2a}{a} = 2 = q2
What am I doing wrong?
