2-sphere manifold intrinsic definition
44 replies · 9K views
lavinia said:
I tend not to agree that Differential Geometry started with Riemann. I guess in a sense, one could say this since the modern formalisms came out of his Habilitation Thesis but geometry was highly developed before Riemann and there was an entire school led by Gaspard Monge in the 18'th century. It was Gauss's research that led to the notions of intrinsic geometry and its relation to underlying topology.
I actually agree although I said I date the birth of differential geometry with Riemann. This was more a rhetorical remark to pinpoint a date. Achievements in science are - as far as I could see always, but definitely mostly - the result of many previous results. Even Einstein already knew that the speed of light was finite, and Noether explicitly mentioned Lie in her papers of 1918. Riemann personally knew and studied Gauß who already introduced the idea of local coordinates almost three decades earlier. I wouldn't go as far as the Euler characteristic which in my opinion is algebraic topology. Gauß-Bonnet was published in 1848, i.e. only six years before Riemann's habilitation. Gauß-Bonnet is very interesting concerning complex analysis where triangulations play a major role and in my sloppy language: another of the many - whilst brilliant - versions of the fundamental theorem of calculus. Is it geometry or is it analysis? Or is it only a corollary to Gauß's considerations about curved surfaces? All this lies in the eyes of the beholder. What it does show once more, is that science is a road, more than it is the sequence of its milestones.
Reply
My guess is that in the 18'th century mathematicians were beginning to question what is meant by a geometry. They certainly were wondering why the Parallel Postulate had never been proved and perhaps questioned the intuition of straightness. In Struik's book on Classical Differential Geometry, Gauss is said to have spoken of "lines of least constraint " on a surface as generalizations of the idea of straightness. If the Euclidean straight line was not sufficient, especially after it was known that there was a plane geometry with infinitely many parallels through a point to a give line, Gauss seems to have been trying to come up with an new idea of straightness. A line of least constant had the property that when viewed as the path of a particle moving at constant speed, its acceleration vector always pointed perpendicular to the surface. In other words, an observer moving along the line would experience no acceleration tangent to the surface and if one imagined that the surface was the only thing he could observe and the embedding was unknowable to him i.e. he was a flatlander on a curved surface so to speak, then he would experience no accelerations and his path would seem inertial. And I would guess that he also imagined that an elastic band constrained only to lie on the surface would release tension until it reached equilibrium and become a line of least constraint. This idea is the idea of a geodesic and seems to be the outcome of inquiry into the nature of straightness in the 18'th century.
Reply
DYK that Gauß has worked as a cartographer! Non-Euclidean geometry was literally his daily bread!
Our former 10 DM bill:
Our former 10 DM note:
I didn't know that. Although I once read that when he discovered the non-Euclidean plane geometry,he tried to determine whether it or Euclidean geometry held for space by measuring the sum of the angles of huge triangles on the Earth. I think he decided that he could not measure a triangle large enough to detect a deviation from 180 degrees.
I wonder if he thought that if non-Euclidean geometry were the actual geometry of the universe whether that meant that Newtonian physics could not be correct and was valid only approximately in small regions. That must have been a mind bending possibility to contemplate.
Given the size of about 150 kilometers in that little diagram on the bill that triangulates parts of the Kingdom of Hanover (of twice that size) which he has been paid for, he must have known.
Reply
cianfa72 said:
Sorry, I believe your equivalence relation ##\sim## first glues the vertical edges together to form a vertically laid down cylinder.
Yes, I meant the vertical sides.
Then, starting from this intrinsic definition of the 2-sphere as quotient, one can define an embedding in ##\mathbb R^3##.
By the obvious [itex](\theta, \phi) = (\pi(1 - y),2\pi x)[/itex].
Btw, in your definition of equivalence relation ##\sim##, why there is the last term ##x_1=x_2 \text { and } y_1=y_2## ?
An equivalence relation is by definition reflexive, so [itex](x,y) \sim (x,y)[/itex] must always hold.
From 1821 until the mid-1840s, Gauß was in charge of the surveying and later the land surveying in the Kingdom of Hanover. At the end of this project, over 3,000 triangulation points had been determined, almost all of which had been corrected by Gauß or later by people he trusted. The overview map shows the triangular networks in northern Germany.
The impetus to survey the Kingdom of Hanover came from its northern neighbor. From 1816 onwards, Gauß's friend and colleague Heinrich Christian Schumacher had carried out a survey of the Kingdom of Denmark. At that time, Denmark also included the duchies of Schleswig and Holstein.
The Danish triangulation thus extended to the gates of Hamburg, which was to be followed by the Hanover survey. King George IV entrusted Carl Friedrich Gauß with this task in 1820. Like Schumacher, Gauß also used the triangulation method, in which the country is covered with a network of triangles that meet at their sides.
Source.
This brings up a fun fact:
Maybe it was Georg IV who finitely was responsible for the beginning of differential geometry! Or was it Frederick VI of Denmark who initiated the measurement in Denmark and Holstein?
Sorry, the embedding is in ##\mathbb R^3## so the embedding map should go to ##x,y,z##.
Ok yes. ##(x,y)## and ##(x,y)## are always related by ##\sim## and belong to the same equivalence class.
pasmith said:
Consider spherical polar coordinates [itex](r, \theta, \phi)[/itex] with [itex]r = 1[/itex].
Ah ok, so ##\pi## in your map in post #36 is not the projection map, it is actually the irrational 3,14159... and ##x,y,z \in \mathbb R^3##.
just a remark about embedding abstract manifolds. this is not at all difficult, and not as sophisticated as Whitney's theorems, which precisely bound the embedding dimension.
As suggested above, if f1,...,fj, is a covering set of charts, and if g1,...,gj is a corresponding partition of unity, then (f1g1,...,fjgj, g1,...,gj) embeds the (compact) manifold. qed.
Riemann may not have known exactly about partitions of unity, or even topological spaces, but I believe he would have understood at least intuitively, that one can extend a chart to a global function. This makes me wonder if there was ever actually any confusion as to whether embedded and abstract manifolds are the same, as it is hard to believe any expert could have missed this simple argument.
Or maybe it was believed, but an actual proof awaited the development of the necessary language? Or maybe it was the non -compact case that was more challenging? I note that Whitney also embeds his manifolds as analytic sub manifolds, but makes no mention in his introduction (to his 1936 Annals paper) that any instance of the general embedding result was previously known. I have not read the later sections, which require some privileged access.
According to wikipedia, Poincare' already defined local overlapping atlases on manifolds.
Aha: My search for the origin of partitions of unity turns up Whitney, in 1934. maybe that technical tool for extending functions was the key? Hard to believe Riemann would not have known this sort of thing, if only in his intuitive way.
well, the topological case seems covered by the tietze urysohn extension lemma and urysohn seems to have died in 1924, so I would think everyone knew a compact topological manifold embeds in Euclidean space well before Whitney.
here is a lecture note going through the easy construction of a partition of unity from urysohn's lemma, applied to embedding compact manifolds, but he makes it look as if there is possibly a little technical supplement needed to apply urysohn. It is really hard though for me to believe that the topological embedding theorem could have been considered news in 1936. Maybe the "smooth urysohn lemma", i.e. smooth PofU, was the new wrinkle, and the consequent smooth embedding theorem?
http://staff.ustc.edu.cn/~wangzuoq/Courses/21S-Topology/Notes/Lec15.pdf
Speaking of Riemann, the sphere is genus zero Riemann surface, no embedding used.
Thinking again about it, I believe ##x,y## in your map are actually coordinates for the square ##[0,1]^2## that is quotiented according ##\sim## to "intrinsically" define the 2-sphere. So the above is a map from it to the ##\theta, \phi## region and its composition with the following map into ##\mathbb R^3##
$$\begin {align}
x & = \sin \theta \cos \phi \nonumber \\
y & = \sin \theta \sin \phi \nonumber \\
z & = \cos \theta \nonumber
\end {align}$$ define an embedding for the 2-sphere (intrinsically defined as quotient space).
cianfa72 said:
About the 2-sphere manifold intrinsic definition without looking at its embedding in ##\mathbb R^3##
- Constant intrinsic curvature
- All geodesics closed and of the same length
Does this uniquely define a sphere?
I am not expert, but it seems already the only Riemannian surfaces on which all geodesics can be closed are the sphere and the projective plane. Moreover, for the sphere, having all geodesics closed implies they are all the same length. I do not know about the projective plane. However there are apparently Riemannian structures on the sphere where not all geodesics are closed, and where it is only known that at least 3 geodesics are closed. I do not know what is added by requiring the constancy of the curvature. I would guess the projective plane may have these properties as well as the sphere, (presumably a geodesic on the projective plane is doubly covered by a geodesic on the sphere), but I don't know.
https://www.imaginary.org/sites/default/files/snapshots/snapshots-2017-005.pdf
For a sphere it would be positive constant curvature. And the geodesics would be required to have finite equal length.
Reply
