242.7x.25 Find the derivative of y with respect to x
  • Context: MHB
  • Thread starter Thread starter karush
    Derivative
The discussion revolves around finding the derivative of the function \( y = 8\ln{x} + \sqrt{1-x^2}\arccos{x} \) with respect to \( x \). Participants explore the differentiation of both terms, focusing particularly on the second term, which involves the product of two functions.
  • One participant notes that the second term requires the Product Rule for differentiation.
  • Another participant proposes using implicit differentiation for the term involving \( \arccos(x) \).
  • Several participants discuss the derivative of \( u = \sqrt{1-x^2} \) and provide differing expressions for \( u' \), with corrections made regarding sign errors.
  • There is a suggestion to treat \( v \) as a function of \( x \) and apply the chain rule in the differentiation process.
  • Participants derive expressions for \( \frac{du}{dx} \) and \( \frac{dv}{dx} \), leading to a formulation of the product rule for the derivative of \( uv \).
  • One participant expresses uncertainty about how to simplify the resulting derivative expression.
  • Another participant confirms that a simplification has been achieved, although the exact nature of this simplification is not detailed.
  • A later reply introduces an alternative approach to the problem, using a different representation of the function and confirming the derivative obtained matches previous results.
Participants engage in a collaborative exploration of the derivative, with some corrections and refinements made along the way. However, there is no clear consensus on the simplification of the final derivative expression, and some uncertainty remains regarding the steps taken.
Participants highlight potential sign errors and the need for careful application of differentiation rules, particularly in the context of implicit differentiation and the Product Rule. There are unresolved aspects regarding the simplification of the derivative expression.
This discussion may be useful for students or individuals interested in calculus, particularly those looking to understand the differentiation of composite and product functions.
karush
MHB
$\tiny{242.7x.25}$
$\textsf{Find the derivative of y with respect to x}$
\begin{align*}\displaystyle
y&=8\ln{x}+\sqrt{1-x^2}\arccos{x} \\
y'&=\frac{8}{x}+?
\end{align*}
the first term was easy but the second😰
The second term is a product, so we'll need to use the Product Rule to differentiate it. The first factor could be written as:
$$u=\left(1-x^2\right)^{\frac{1}{2}}$$
So, to differentiate that, we'll need the Power Rule and the Chain Rule.
The second factor is:
$$v=\arccos(x)\implies x=\cos(v)$$
Can you use implicit differentiation on the implication to derive the needed formula?
so..
$\displaystyle u'=\dfrac{x}{\sqrt{x^2+1}}$
karush said:
so..
How did you obtain that result?
sign error ?
$\displaystyle u=\left(1-x^2\right)^{\frac{1}{2}}\\$
$\frac{1}{2}(1-x^2)^{-1/2}(-2x)\\$
$\displaystyle u'=-\frac{2x}{2\sqrt{1-x^2}}
= -\dfrac{x}{\sqrt{1-x^2}}$
karush said:
sign error ?
Yes, that's much better. (Yes)
Okay, now let's look at:
$$x=\cos(v)$$
What do you get when you implicitly differentiate w.r.t $x$?
$$x=\cos(v)$$
do you mean
where $\displaystyle u=\left(1-x^2\right)^{\frac{1}{2}}$ and $u'=-\dfrac{x}{\sqrt{1-x^2}}$
and $x=\cos(v)$ and $x'=-\sin\left(v\right)$
$$ux'+u'x$$
karush said:
do you mean
$$ux'+u'x$$
You need to treat $v$ as a function of $x$, and therefore use the chain rule...
Let's look at:
$$x=\cos(v)$$
Implicitly differentiating w.r.t $x$, we obtain:
$$1=-\sin(v)\d{v}{x}\implies \d{v}{x}=-\frac{1}{\sin(v)}$$
Now, let's go back to:
$$v=\arccos(x)$$
We now have:
$$\d{v}{x}=-\frac{1}{\sin(\arccos(x))}=-\frac{1}{\sqrt{1-x^2}}$$
Okay, we are now ready to write:
$$\frac{d}{dx}(uv)=\d{u}{x}v+u\d{v}{x}=?$$
kinda maybe??
$$\frac{d}{dx}(uv)=\left[-\dfrac{x}{\sqrt{1-x^2}}\right] \left[\arccos(x)\right]
+\left[\left(1-x^2\right)^{\frac{1}{2}}\right]\left[ -\frac{1}{\sqrt{1-x^2}} \right]$$
karush said:
kinda maybe??
Yes...can you simplify? :D
is:
$\displaystyle\arccos(x) =\frac{1}{\sqrt{1-{x}^{2}}}$
karush said:
is:
No, but there is an algebraic simplification that can be made in the expression you posted for the derivative of the product $uv$. :D
$y'=\dfrac{8}{x}-\dfrac{x\arccos\left(x\right)}{\sqrt{1-x^2}}-1$
not sure how this could be simplified??
You did the simplification I was talking about...great job! (Yes)
Interesting problem!
$$\cos(u)=x$$
$$\frac{du}{dx}\sin(u)=-1$$
$$\frac{du}{dx}=-\frac{1}{\sqrt{1-x^2}}$$
(We use the positive root as $u\in[0,\pi]$)
$$y=\sqrt{1-x^2}\arccos(x)=u\sin(u)$$
$$y'=u\cos(u)\frac{du}{dx}+\sin(u)\frac{du}{dx}=\frac{du}{dx}\left(u\cos(u)+\sin(u)\right)=-\frac{x\arccos(x)}{\sqrt{1-x^2}}-1$$
