Solving a Second Order Non-Linear PDE with Undetermined Coefficients
The discussion focuses on solving the second-order non-linear PDE given by d²y/dx² = 2xy(dy/dx). It notes that this equation does not fit common simplified forms that allow for straightforward solutions. An integrating factor is suggested as a potential method, although its specific form is unclear. Transforming the equation to y''/(yy') = 2x indicates that y may be a polynomial or rational function, leading to experimentation with undetermined coefficients for a solution. Ultimately, it is proposed that a solution could take the form of 1/x² based on polynomial degree analysis.
binbagsss
##\frac{d^2y}{dx^2}=2xy\frac{dy}{dx}##
This is second order non-linear pde of the 'form' ## f(y'',y',y,x) ## .
I have read that there are 2 simplified versions of a second order non-linear pde that can be solved easily and these are 1) when there is no y term 2) when there is no x term
[/B]
The above does not fit into these two categories, and as such I think it has no general sort of procedure or way to solve, but it is possible for an integrating factor to come for mind for this particular one? (i just have no idea what this could be !)
Many thanks
[/B]
Many thanks
Putting the equation in this form
##\frac{y''}{yy'}=2x##
suggests that ##y## is a polynomial or a rational function. Experiment with these forms using undetermined coefficients and you will quickly find a solution.
This type of suggestion would not work for the simpler similar case ##\frac{y'}{y} = 2x##.
Anyway, if ##y## is a polynomial of degree ##n##, the right-hand-side ##2 x y y'## is a polynomial of degree ##2n## while the left-hand-side ##y''## is a polynomial of degee ##n-2##. That requires ##2n = n-2##, hence ##n = -2##. That suggests a solution of the form ##1/x^2##!
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 36 ·
  • · Replies 21 ·
