3 equations, 3 unknowns, how do i solve ?
  • Thread starter Thread starter bjr_jyd15
    Unknowns
The discussion focuses on solving a system of three equations with three unknowns: a, b, and c, defined as x = (a/b) + c, y = (a/(b+1)) + c, and z = (a/(b+7)) + c. Participants suggest using linear algebra techniques to isolate variables and convert the equations into a matrix form. The final approach involves rearranging the equations to eliminate one variable, allowing for straightforward substitution to find the values of a, b, and c. Caution is advised to avoid multiplying by zero during calculations.
  • Understanding of linear algebra concepts
  • Familiarity with matrix operations
  • Ability to manipulate algebraic equations
  • Knowledge of substitution methods in solving equations
  • Study methods for solving systems of linear equations using matrices
  • Learn about the Gaussian elimination technique for variable isolation
  • Explore the concept of determinants and their role in solving linear systems
  • Review substitution methods for solving equations in algebra
Students and professionals in mathematics, engineers, and anyone involved in problem-solving with algebraic equations.
bjr_jyd15
3 equations, 3 unknowns, how do i solve!?
hi everyone, i have 3 equations and 3 unknowns:
x = (a/b) + c
y = (a/(b+1)) + c
z = (a/(b+7)) + c
where x, y, z are given in the problem (real #'s), and we need to find the values of a, b, and c.
can anyone tell me how to go about this problem? i tried rigourous algebra of solving and substituting but it became too difficult to isolate one of the variables a, b, or c.
thank you in advance!
Multiply both sides by the denominator of the fraction. Then, define d=bc. You'll have three linear equations for a,b,d, and at the end you can get c from d and b.
hmm I'm not sure i follow. so would i have xb = a + bc ? and then replace bc with d? how do i go from there then when i have xb = a + d?
thanks
Right, do that for all three equations, and then you'll have linear equations (since x,y,z are constants). These should be easy to solve. If you know linear algebra, that helps, but if not, it's just straightforward eliminating variables.
okay so i have
bx = a + d
by + y = a + d + c
bz + 7z = a + d + 7c
where x,y,z are #'s and d=bc...
if i want to put this in a matrix, is it possible? because i see the b's on the left side of the equation that are unknown...
thank you for your patience.
Sorry, I kinda rushed through this before and made a mistake. You probably didn't need to introduce d. But it doesn't really matter, and it'll still work if you use the first equation to plug in bx for a+d in the other two equations. This will eliminate a in both of them, and that will leave you two linear equations for b and c. Just group all the b's and c's on one side.
so now i have two linear equations:
by - bx = c -y
bz - bx = 7c - 7z
which I'm not sure how set up from there as a linear eqn...should i factor a b out of the left side of the first equation then divide? please let me know!
thanks
You now have two equations in two unknowns (b and c). You've done that sort of thing before, right?
For example, you could solve one equation for c and substitute it for c in the other one. Then you have a single equation for b only. Solve it. Then substitute your solution for b back into one of those two equations. Either one will work. Solve for c. Finally, take your solutions for b and c and substitute them back into one of your original equations. Any one of them will work. Solve for a.
by - bx = c -y
bz - bx = 7c - 7z
thanks
You know, x, y, z. Rearrange a bit gives:
\left\{ \begin{array}{l} (x - y)b + c = y \\ (x - z)b + 7c = 7z \end{array} \right.
Now that you have your matrix. You can go from here, right? :smile:
thank you all for your help--it's appreciated! :!)
Be double careful that you don't multiply by zero and stumble across a solution that actually does not exist.
