How Far Does a Baseball Travel with Zero Acceleration?
  • Thread starter Thread starter e=mcahhhh
    Distance traveled
The discussion focuses on the physics of a baseball thrown by a pitcher, specifically analyzing the distance it accelerates before release and the force exerted by the pitcher. The key equations include displacement = vi + (1/2)at² for calculating distance and force = mass x acceleration for determining the pitcher's exerted force. The conversation clarifies that the baseball accelerates horizontally while gravity acts vertically, emphasizing the distinction between the phases of motion before and after release. Participants highlight the importance of understanding net forces and acceleration in both the x and y directions.
  • Understanding of Newton's laws of motion
  • Familiarity with kinematic equations
  • Basic knowledge of forces and acceleration
  • Concept of gravitational force (g)
  • Study kinematic equations in detail, focusing on displacement and acceleration
  • Explore Newton's second law of motion and its applications
  • Learn about the effects of gravitational force on projectile motion
  • Investigate the phases of motion in projectile dynamics
Physics students, educators, and anyone interested in understanding the mechanics of projectile motion and forces acting on objects in motion.
e=mcahhhh
The gravitational force on a baseball is -Fg. A pitcher throws the baseball with velocity v by uniformly accelerating it straight forward horizontally for a time interval Δt = t − 0 = t. If the ball starts from rest, determine the following: (Use any variable or symbol stated above along with the following as necessary: g for the acceleration due to gravity.)
a.Through what distance does it accelerate before its release?
b. What force does the pitcher exert on the ball?
displacement =vi+at^2 for (a.) And random variations that have not worked out as of yet. But i feel i am making it harder than it really is.
i thought -1/2 at^
You must have left out some information.
(a) displacement =vi+at^2 ... yes, but it starts from rest.
(b) a bit trikier: force = mass x acceleration. Your teacher might want you to include Fg, so the force have two components, one up and one forward, if not then just the forward force that the pitcher exerts to accelerate the ball.
Your post and its title is difficult to understand. The title says "Distance traveled when Accel= 0" but then you mention both gravitational acceleration, g, and a "uniform acceleration straight forward". So there is no "Accel= 0" in the problem?
You ask "Through what distance does it accelerate before its release?" If this is only "before its release" it is still in the pitcher's hand? That would imply that the acceleration due to gravity is offset by the pitcher's hand holding it and has no part in this problem.
Since the pitcher is throwing the ball exactly horizontally, during the pitch there is no net force in the y direction, but there is an acceleration (and hence a force) in the x direction.
The problem is giving you the final v in the x direction after the acceleration is 0 (ie the pitcher has already released the ball and there is no force in the x direction, only gravity pulling down).
You have to imagine the process and ask which 'phase' is being asked about. It reads to me like its asking about the phase prior to release of the ball.
Ball from rest (0 net force everywhere)
accelerates exactly horizontally (net force only in x direction) to a final velocity v, in time t. Phase 1.
the ball is released leading to the second phase where there is 0 force and 0 acceleration in the x direction but a non zero force in the y direction from gravity.
You have enough information to find the displacement (find acceleration first because we know v, vi, and t then you can find displacement knowing v, vi, a, t).
The question about the force on the ball I'm not exactly sure as it seems you need the mass unless, as stated above you need some kind of trig trick to find an expression. I doubt the latter because in each phase there is net force only in 1 direction so no trig necessary.
..."Use any variable or symbol stated above along with the following as necessary: g for the acceleration due to gravity."
No need to solve, just state formulas with symbols for the variables.
10K
11K
