8051 Microcontroller Descending Order
  • Thread starter Thread starter tyogav
    Microcontroller
12 replies · 18K views · last reply
tyogav
I have written a program for sorting an array in memory using 8051 microcontroller. But when I modify it for descending order(Replace JNC by JC). It doesn't work.
What is the point that I am missing?
I suspect that your "JNC" version didn't really work either. The numbers may have ended up sorted only because they were partially sorted to begin with.
Perhaps you should post the full sort program - not just the first page.
I would also be good if you could post it right-side up.
Full Program
Sorry, I couldn't post it with correct orientation. Somehow I get it posted wrongly.
@tyogav, all three of the images you uploaded are sideways. It would be much better if you typed your program and entered it as text directly into the input pane here. Many helpers won't bother to comment if they have to click an image, especially one that isn't oriented correctly.
Having your code appear as text rather than as an image has the advantage that helpers can identify a line of code that is incorrect. When the code is posted as an image, helpers need to type the line or lines where a problem occurs.
MOV R0, #(N-1)
MOV A,R0
MOV R1,A
L3: MOV DPTR, 4150
L1: MOVX A,@DPTR
MOV B,A
INC DPTR
MOVX A,@DPTR
MOV R4,A
CLR C
SUBB A,B
MOV A,R4
JNC L2
XCH A,B
L2: MOVX @DPTR,A
MOV R0,DPL
DEC R0
MOV DPL,R0
MOV A,B
MOVX @DPTR,A
INC DPTR
DJNZ R0,L1
DJNZ R1,L3
HLT: SJMP HLT
For everyones information: DPL is the low-order byte of DPTR.
You are overwriting R0 with it - which may be you're intention. I can't tell.
I think the problem is that when you loop from DJNZ R1,L3, R0 is not reset.
This isn't a bubble sort. DPTR should only be incremented once per loop. After a compare (subtract and restore A), if the elements are not in order, then decrement DPTR, store the smaller (or larger if descending) number, increment DPTR and store the larger (or smaller if descending). If the elements are in order, then skip to the end of the next inner loop. The idea here is to move the largest (or smallest if descending) element to the end of the array on each loop. The "size" of the array can be decremented on each loop since the largest (or smallest) values are already moved to the end.
rcgldr said:
This isn't a bubble sort. The code increments DPTR twice on each loop. It should only increment DPTR once on each loop.
That's why I put the note about DPL in my last post.
He increments DPTR twice and decrements the low order byte once. As long as his list is less than 160 bytes long, he's okay.
Why not use this to decrement DPTR, and also avoid overwriting R0?
Code:
        XCH     A,DPL
        JNZ     D1
        DEC     DPH
D1:     DEC     A
        XCH     A,DPL
Thanks. So overwriting R0 has been the problem. I will replace R0 with another register and check.
I wonder how it worked for ascending order.
:oldconfused:
Could anyone suggest a good 8051 simulator to use in Windows as I don't have access a 8051 microcontroller kit right now? I am using EdSim51 right now. But it doesn't support MOVX command :L.
